Question about Panasonic Sa-pt750 Multi 5 Dvd Player Wireless Home Theater Surround System
Sa-pt750 not sure how to hook up to samsung hdtv for surround sound
5 Suggested Answers
bstimpy
  • 47 Answers
SOURCE: no sound through Panasonic SA-HT930 surround system
I've had similar problems in the past. With audio problems trace the problem from the source to the amp.
1. What output is the cable box using for audio, digital or analog?
2. Is there a setting in the cable box to switch between digital and analog?
3. Once you have determined the output of the cable box check to make sure that it's going into the right output on the panasonic
4. This is where the problem usually is...what is the receiver expecting for sound, analog or digital?
5. Switching between the sources...the sound should be on one of them.
Posted on Mar 19, 2008
  • 120 Answers
SOURCE: I have a Samsung HDTV and am trying to get
hook the ps3 sound cables to the Panasonic system or get some of the splitters and hook one end to the tv and the other to the sound system, im pretty sure the tv doesn't have an out for the sound so without a couple splitters its either the tv or the sound system
Posted on Mar 06, 2010
tunde007
  • 2382 Answers
SOURCE: Have an SA-HT400 surround sound
Hi, you can use this guideline to help setup your PS3 with the surround sound system...
  • Determine the connection that you have available. The PS3 is equipped with HDMI and optical outputs, both of which can transmit a digital surround sound signal to your home theater receiver. You may not have an HDMI connection on your receiver, but you should have an optical connection. If you use HDMI for audio, you'll need to connect the HDMI from the PS3 to the receiver's HDMI input, then connect a second HDMI cable from the receiver's HDMI output to the television, in order to get video to your TV.
  • Purchase the appropriate cables for the connection that you've determined.
  • Connect the cable from the digital output on your PS3 to the input on your home theater receiver. Use a connection designated for a game system, when available, or use other connection such as "Video 1" or "Aux."
  • Connect the video. If you didn't use HDMI to connect to your receiver, run a separate HDMI, component or composite video connection from your PS3 directly into your TV. If you connected HDMI to your receiver, run an HDMI cable from the receiver to the TV.
  • Adjust your audio settings in your PS3 options menu. Switch your television to the input mode that corresponds with where you connected the PS3. In the home menu, go to "Settings/Sound" then "Settings/Audio Output Settings." Then, adjust the audio settings to reflect the connections you've made (HDMI or optical).
  • Select audio formats. Once you've selected the audio output type, you will be prompted to choose from various formats (2 channel, Dolby 5.1, DTS 5.1, 7.1). Refer to your home theater receiver to find out which formats it processes and consider how many speakers you'll be using when selecting formats.
  • Connect the speakers. If you have not yet already set up your speakers, connect each speaker to the appropriate output terminals on your receiver with speaker cable, matching the positive and negative terminals of the speaker with the matching terminals on the receiver.
Posted on Nov 26, 2010
SOURCE: sa-pt750 panasonic theater system remote codes
I cannot remember how to get my T.V. sound to play thru my panasonic home theater system sa bpt 750.
Posted on Jan 23, 2011
Cannot get the tv audio working. Radio iPod all work fine Panasonic surround sound sa-pt750
Hi. Make sure you get audio from tv from the right place. Ie audio out not audio in.
Nov 05, 2016 | Panasonic Sa-pt750 Multi 5 Dvd Player...
Would like to have a owner user manualand a product manualfor a panasonic universal remote control EUR7662YWO
You are likely to find the instructions for the EUR7662YWO remote in the manual for the home theater system. The main unit is the SA-PT750. The entire home theater system is SC-PT750, see the support page: http://shop.panasonic.com/support-only/SC-PT750.html . The direct link to the manual is ftp://ftp.panasonic.com/hometheater/om/sc-pt750_en_om.pdf . The code list for the remote is on page 10. Page 15 has more on using the remote control.
I hope this helps.
Sep 06, 2016 | Panasonic Audio Players & Recorders
How to connect a Panasonic SA PT950 home theater syst. to a Samsung flat TV UN65JU650D?
Samsung 40'' 720p tv and Panasonic home theatre system ...
? 5:30
https://www.youtube.com/watch?v=zDG-PZtqCNE
Jan 4, 2012 - Uploaded by Nazil Rahman
Samsung 40'' 720p tv and Panasonic home theatre system ...How to Connect an HDTV to Your Sound ...
New way to connect TV to Surround sound using HDMI ARC ...
? 4:46
https://www.youtube.com/watch?v=fFNEKnlQd6I
Dec 13, 2013 - Uploaded by Tampatec
How to Connect TV to Surround sound receiver system setupusing HDMI ... to Samsung, LG, Sony, Vizio ...
Unable to connect Samsung smart TV with Panasonic home ...
www.tomsguide.com/.../unable-connect-samsung-smart-panasonic-home...
Dec 16, 2014 - hi I bought Panasonic SC-BTT405 blue ray disk 5.1 home theater and ... Unable to connect Samsung smart TV with Panasonic home theater ... I have an LG55LA9650 smart TV hooked up to a Bose 3-2-1 home theater system.
Jan 23, 2016 | Samsung Audio Players & Recorders
Error Code F61. Do I need a new fan?
it is fault of cooling system, and sound output error, if fan is disconnected or not running F61 comes on screen then nothing happends, power sound ic is the main cause of the device, not only cleaning works, may need to change the the power sound out put ic.
Nov 02, 2015 | Panasonic Sa-pt750 Multi 5 Dvd Player...
I hooked up a new lg hd tv via hdmi through my digital cable box. I am not receiving true surround sound, only dolby II. I have my box digitally hooked up to the receiver and the HDTV digitally hooked up...
It's possible that the TV broadcast isn't in true surround, and is only dolby encoded.
You can try going back to the component hookups, but I am not sure that will solve your issue.
Feb 27, 2011 | Panasonic SA-HE100 Receiver
I have a Samsung HDTV and am trying to get Surround Sound for the PS3 Have the Panasonic SA-HT65 system any help
Mar 06, 2010 | Panasonic SC-HT65 System
Need hook up diagram for Samsung HDTV using HDMI with Cable box and Samsung 5.1 Surround Theater System
you can run a fiber optic cable out of the tv into the surround system if the sytem has a fiber optic input, or your tv should at least have red and white rca cables for audio out, then you just pick any input on the surround sound and any audio from dvd players ect thats hooked up to the tv will be sent through that one input on the surround sound. The only thing you'll have to do is turn the volume up or down on your sound system.
Jul 09, 2008 | Televison & Video
Sc-pt750
As far as I know there isn't any composite IN ports on the back of the SC-pt750 so that would mean you would have to directly hook it up to the TV. I have an SA-pt750, which has an S/PDIF port on the receiver so I would run a cable from the TV to the receiver, from there if the SC-pt750 is set to AUX then it should output the sound from the TV to the speakers. Hope that helps, if you don't have that S/PDIF port I think you might be out of luck!!
Nov 12, 2007 | Panasonic Home Theater System System
Panasonic Sa-pt750 Multi 5 Dvd Player Wireless Home Theater Surround System Logo
173 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
