Question about Quantum Audio Car Audio & Video
My screw that holds in the power wire screw in, how can keep the wire in.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
Use a larger screw. rethread the hole and use the proper screw for it.
Posted on Nov 15, 2013
What type of screws do I need for a Kenmore 80 series dryer power cord (where the three screws hold the wire to the terminal)
They are machine screws. Remove the terminal block and take it to the hardware store to match the size of the "lugs." Terminal Block 5304409888
Oct 14, 2016 | Kenmore Dryers
How to wire a 220 volt switch
Turn off the main breaker controlling the power to the home. This will ensure that the wires at the 220-volt switch are not powered before working on them
Remove the cover from the old 220-volt switch with your straight screwdriver. Also, remove the screws that are holding the switch into the box. Pull the switch and wires out of the box so that the connections are accessible.
Identify the two sets of wires in the switch box, a red and a black pair, in the same conduit or insulated sheath. You should be able to see which wires are going to the device, or load. The line side is the other set of wires coming from the breaker.
Loosen the screws that hold the wires onto the switch. Pull all of the wires off of the old switch. Inspect the new 220-volt switch and identify the connection screws marked line and load.
Strip 3/4-inch of insulation from the ends of all four wires if they aren't already. Curl the tips of the stripped wires. Wrap the curled ends clockwise around the screws so that tightening the screw makes the wires wrap tighter.
Connect the black and red hot wires, or line, to the side of the switch marked "Line," usually the darker set of screws. Connect the two wires that are going to the device, or load, to the two screws marked as "Load" on the switch, usually the lighter colored screws on the switch.
Connect the bare ground wire, if there is one, to the green grounding screw on the switch. Push the wires and switch into the electrical box. Install the two screws that hold the switch into the box. Replace the switch cover and turn the main breaker back on.
Read more : http://www.ehow.com/how_8270481_hook-up-220volt-switch.html
Dec 13, 2014 | Electrical Supplies
I have a Canon eos Rebel XT. Once powered on it will take photos for a short time, get hot and power off by itself and won't power back on till it cools off. Additionally once powered on even when
Remove back cover and check for missing screw - especially check if it is touching the orange wire that powers the back light for the rear LCD that s part f the rear cover. Screw that is loose is almost always the bottom right screw that holds on rear circuit board. If it is not there and you see the empty hole, it could be anywhere in the camera, so you will have to keep on disassembling until you find it.
Jan 15, 2013 | Canon Rebel XT / EOS 350D Digital Camera
How do u change a house hold light switch on a wall
Turn off power.
Unscrew cover plate.
Unscrew both screws holding switch into wall box.
Pull switch outward to stretch wires.
Take photos so you can reconstruct wiring if necessary.
Note color of each screw.
Green is for ground wire.
There are many different kinds of switches.
Single pole switch has two wires plus ground, and both screws will be same brass color, plus green ground screw.
3-way switch has 3 wires plus ground, and one screw will be different color than other two screws, plus green ground screw.
Remove wires from switch.
If wires are attached into holes on back of switch, notice there is small slot next to each hole.
Insert small screwdriver or metal nail file into slot while pulling on wire. This takes 3 hands, and then wire will come out of hole.
Replace each wire onto new switch, matching the old switch, tighten screws very tight, and then put switch back into box.
When pushing wires back into box, you want to keep the wires folded behind the switch as much as possible.
Wires are not harmed when scrunched back into box.
Put switch cover over switch so no possible spark can exit box.
Turn power ON, and try the switch.
http://waterheatertimer.org/How-to-wire-switches.html
Jul 17, 2012 | Electrical Supplies
Dpsr483ea1ww how to replace thermostat
  • Unplug the dryer's power cord from the wall connection. You will be working around the dryer's wiring, which can be dangerous if the power is connected.
  • 2
    Remove the rear cover of the dryer. Most dryers have four screws, one at each corner. Flathead screwdrivers will work for most models, but some require Phillips-head screwdrivers.
  • 3
    Locate the thermostat. The thermostat is circular or oval with a wire connection on each side. Remove the screws keeping the wires connected to the thermostat. Set them aside--you will be reusing them to install the new thermostat.
  • 4
    Disconnect the thermostat from the wires, then unscrew the thermostat from its mounting bracket. The thermostat will easily pull away from the wires once you have removed the screws. Discard the old thermostat.
  • 5
    Install the new thermostat on the mounting bracket. Be sure to tighten the screw enough to keep it secured. Connect the wiring to the thermostat and reinstall the screws to hold the wiring in place.
Jan 13, 2012 | GE Dryers
I have fender passport pd-250 the protect light on and the power light geos off
One or more of the power transistors are shorted. There are eight transistors in the amplifier section - 2 high & 2 low for each channel. This unit is difficult to open up to work on.
Unplug unit and check speakers with a multimeter to make sure they are not shorted.
Take off front panel (8 screws).
Remove power supply shield with yellow tape (2 screws).
Remove 2 screws holding top of power supply, loosen bottom screws.
Replace front and hold in place with a couple screws.
Turn unit around.
Remove screws holding heatsink (6 screws)
Open rear storage door.
Carefully pull amp section out, being careful of tightly routed wires. Note any connectors you disconnect.
The amplifier is the board on the top, the power supply is in the silver box.
Push the power supply forward and loose the black screws holding the amplifier board bracket closest to the heatsink.
Loosen the top brass screws holding bracket to heatsink and remove the bottom screws.
Remove all eight of the screws holding the transistor brackets & transistors to the heatsink. Look and take careful note of how the plastic insulators weave through the transistors. If you get this wrong, you can short out the whole amplifier when you turn it on.
Slide the amplifier board down and out where you can get to the bottom. Note the wires and connectors going to the small protect board over the amplifier.
Check the transistors with a multimeter to find the shorted ones. Remove and replace bad transistors. These are connected in pairs.
Reassemble in reverse. Be careful of reconnecting wires and insulators. Don't test until the amplifier PCB is back in place and you're sure of all wires. If the PCB is touching the power supply, you'll short it out.
Good luck, I told you this wouldn't be easy!
Mar 04, 2011 | Lectrosonics FENDER PD-250 PASSPORT SYSTEM...
I have the passport p-250 i left it on over night and when you turn it on the red comes on that said protect thanks jimmy
Turn unit around.
Sep 08, 2010 | Lectrosonics FENDER PD-250 PASSPORT SYSTEM...
My Schwin 430 power cord socket went inside the machine. Please advice how to power the machine.
There should be a series of phillips head screws (star) holding the black casing together. If you remove the 2 or 3 screws along the immediate front of the case, you should be able to open it up just enough to see the outlet. It's a small plastic piece about the size of a grape attached by two wires (red and black). The outside of the outlet is threaded so when it's pushed through the hole, you thread a nut on the outside to hold it in place. If you've lost the nut, you can easily tape the outlet in place, or just run the ac adapter cord in through the hole in the case, use the opening at the front you made by removing the screws and plug it in on the inside to power it. Replace the screws and just make sure you keep anyone from yanking on the power cord.
Jul 06, 2010 | Schwinn 430 Elliptical Trainer
How to replace belts
First, don't assume it is the belt. They seem pretty durable. But there's an issue with the nuts that hold the paddle rotors from the bottom. If they are loose, the paddles won't turn, or will turn weakly with no kneading power. Here's how to get at them:
First, forget the screws on the bottom. They just hold on the feet. Remove all the screws around the top of the baking chamber, the two that hold the control panel on, and the remaining screws under it. There are about 12 screws. Remove the 6 at the bottom of the baking chamber, but not the 2 that hold down the element. Remove the metal sides of the baking chamber (it's one piece). All this is to get access to the screws that really hold the works to the base. They're around the perimeter of the metal chassis on which the motor and element are mounted. Remove them (get help or arrange something to keep the control panel from exerting too much pull on the wires to the element. You could unplug the control unit but I didn't need to.)
Once you lift the motor assembly exposing the belts underneath, you'll see what's loose. (of course if the belts are bad, you'll see that too) Each nut holds down a metal plate beneath the rotor. If it gets loose, the rotor can move more or less freely and won't turn. It looks like they applied an inadequate dab of glue to hold those in place. I should have put in a star washer to keep the nut from loosening again. Next time.
Jun 27, 2010 | Zojirushi BBCC-X20 Home Bakery Supreme...
Replace a cord on a grinder
take the handle screws out and there will be 2 screws on the trigger holding 2 wires in and 2 screws holding a bracket to keep the wire from being pulled out. replace it with a new cord and 2 new connectors. the wire is a 14-2 and you will need about 4' of it.
when putting a new plug-in on the end put the black wire to the brass side and the white wire to the chrome side.
Aug 10, 2009 | Dewalt D28114 Angle Grinder
Car Audio & Video Logo
19 people viewed this question
Top Quantum Audio Car Audio & Video Experts
xxxxxx xxx
Are you a Quantum Audio Car Audio and Video Expert? Answer questions, earn points and help others
