Question about Canon FAXPHONE L80 Laser
Line in use flashing
The machine makes a clicking noise and the dial tone is interupted. Screen alternates between line in use and the date.
  • Anonymous May 14, 2008
    Machine is making a clicking noise. "LINE IN USE" is flashing. Have checked to make sure the phone cord is plugged in to the proper outlet.
  • HeroBam May 14, 2008
    Machine is "clicking". LED read-out flashes between LINE IN USE and the date.
  • 186 Answers
Is the phone cord from the wall plugged into the jack on the back of the machine, marked "line" and not "phone"?
Posted on Sep 27, 2007
SOURCE:
I cannot send fax
Hi there!
For you to send a fax with the Brother Fax you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook/speakerphone button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still, connect it to another working outlet. If you don't have a dial tone still, connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Apr 02, 2011 | Brother IntelliFAX 2600 Fax
Inoperative fax and telephone line
try connecting line 2 to a simple phone and chk for dial tone.
Sep 22, 2008 | Canon FAXPHONE L80 Laser
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
I have a Brother 775 intelli fax machine. I can't send a fax. After loading the document, when I go to push in the fax number, the numbers do not register. I unplugged the machine from the power and the...
Hi there!
For you to send a fax with the Brother Fax 775 you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still connect it to another working outlet. If you don't have a dial tone still connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
Thanks!
Mar 30, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
I pick the phone up, no dial tone. Display says
We called the phone company.....There was a problem up on the telephone pole. They fixed it, no charge.
Jan 21, 2010 | Vtech Cordless 6041 Phone
FAX function stopped working
honestly, it sounds like you have the phone cord and the fax jack swapped backwards, make sure you have the fax line plugged into the correct jack on the machine. 1 is for the handheld phone and the other is for the telephone line... give this a shot...
Mar 10, 2008 | Brother MFC-7220 All-In-One Laser Printer
HISSS on line; no dial-tone; no fax in or out
it sounds like you may not have any dial tone. the hiss [white noise] you are hearing is from the dsl modem.try plugging a regular corded phone into the jack to check for dial tone.if there is none,call your phone company.also try plugging the fax machine into another jack where you know there is dial tone.
good luck
wg
Feb 02, 2008 | Brother FAX-2920 Plain Paper Laser
No dial tone, clicking sound
It most likely is the LIU (Line Interface Unit). or you might have it plugged in the wrong port on the fax itself. Make sure it's plugged into the LINE plug. If it's the LIU it would be cheaper to replace then calling for service. Unless it's under warranty still (usually 90 days)
Jan 29, 2008 | Canon FAXPHONE L170 Plain Paper Laser
Incoming telephone calls
Refer to your manual. It may be under RX(recieve settings). Go disable FAX/Tel SW and make sure it is fax mode only
Jan 11, 2007 | Canon FAX-B820 Plain Paper Bubblejet
Canon FAXPHONE L80 Laser Logo
90 people viewed this question
Clive
Clive
old marine
old marine
Ekse
