Question about Liebherr KES4260 Refrigerator
Lights and pump turning on and off rapidly in succession
Lights and pump turn on and off every 1-2seconds. Led lights on ventilation control and on temperature gauge also flash
    Problem Solver:
  • 19 Answers
I had this, there are two circuit boards, one on the front under the switches the second in the back near the compressor. which is really hard to reach, your guessed it, its the one near the compressor that needs replacing, its around 70 pounds stirling..
Posted on Oct 22, 2013
Defiant flood light 180 degree led: 1. Instruction manual says to put a maximum of one such light on a wall switch. Why can I not have 2? 2.it has photo sensor in addition to a motion sensor? Thx.
Maybe two light fixtures each with photo sensors and the lights being near each other, might trigger both sensors to react to each other and turn lights on and off rapidly.
Jul 09, 2016 | Home Security
Hp laptop synaptics touchpad light comes on and shuts off pointer
Had this problem before, very annoying! On mine the idea was double tap to disable the track pad and then double tap again to activate it... In reality tapping rapidly in the area around the LED until the LED shut off seemed to work.
In short; double tap the LED to reactivate the track pad. If that doesn't work tap several times in quick succession until the LED turns off.
Dec 18, 2012 | HP Computers & Internet
Turn single flasher
I beleve u just need a load resistor on the led. Fairly cheap at autozone or equivalent.
Jun 13, 2012 | GMC C2500 Cars & Trucks
My S107G is fully charged, I turn on and off transmitter on different frequencies, turn the heli on and off according to my instruction manuel, but the lights on the heli are on,the circuit board red led...
I have similar problem with my LS-208 heli.
Helicopter leds are blinking red/green, front white led is on, and tail leds are blinking too.
Remote controller red led is on as should be but helicopter doesn't respond to controller at all.
I followed instructions above with no success.
Anyone has a suggestion?
Regards, Yaron.
Jun 12, 2012 | SYMA Toys industrial New Syma S107 Radio...
Reset code for dishwasher
In order to reset the dishwasher you need to key in this sequence rapidly within 6-8 secs.
Hi Temp/ Heat Dry/ Hi Temp/ Heat Dry/ High Temp/ Heat Dry
All lights should turn on if reset is successful. Press Cancel to exit.
If this does not happen then most likely the controller or the keypad is faulty.
Oct 18, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Just replaced fuel pump now rear lights are goofy. If the engine is off the rear turn signals work fine but no running lights. With engine on, the left turn signal causes both lights to blink rapidly with...
YOU HAVE A BAD GROUND FOR FLASHERS OR FRONT YTURN IS OUT AND RUNNING LITES HAVE FUSE GOOD LUCK LOOK AROUND FUEL TANK FOR TORN OR PINCHED WIRES
Oct 06, 2011 | 1998 GMC Sierra
Rapidly flashing turn signal continues even after I replace bulb
And all lights flash? Is this with or without a trailer and its lights connected? LED lights installed?
Many times when there is a slow or fast rate that the signals flash its due to a chaneg in current being drawn. Either from hooking up trailer lights or changing the bulbs to LED. LEDs will draw less currenct and more lights more current.
There are electronic flashers that automaticaly adjust for different current draws to make the lights flash at a normal rate and they plug right in to replace your stock mechanical flasher.
Aug 30, 2011 | 2002 Chevrolet TrailBlazer
I have a type c wireless controller how to connect it to the ps3 it dont indacate
From the Manual:
1. With your Playstation 3 game Console on and the ON/OFF switch on the bottom of the controller set to on. Plug in the USB receiver into a USB port in the Playstation 3. The LED will flash slowly.
2. Press the "connect" button on the receiver. The LED will flash rapidly.
3. Press the "menu" button on the controller. The four channel lights will flash rapidly until the sync process is done. When the sync process is done one of the channel lights will remain solidly lit.
The manual can be found here in PDF format. http://assets.dreamgear.net/manuals/DGPS3-1324.pdf
Jan 07, 2011 | DreamGear TYPE 6 2.4 GHz Wireless...
Apex Digital GB4308 remote
Programming the Remote Control Remote-control switchover Press VCR/DVD, SAT/CABLE or AUX to select the device you want to control. To program the remote control Press and hold VCR.DVD, SAT/CABLE or AUX for over 2 seconds until the LED on the remote control turns off. Release the button the LED will light again (the remote control enters the PROGRAMMING mode). Enter three-digit code number for your equipment. If the correct code number is entered, the LED blinks three times. If you enter a code not listed below, or you press any other buttons than SEARCH and 100+, the LED turns off. To search codes Press ad hold VCR/DVD,SAT/CABLE or AUX for over 2 seconds unil the LED turns off. Release the button (the LED wil light again) and the remote control enters the PROGRAMMING mode. Press SEARCH. Press CH+/- to search codes downwards or upwards. Each time you press CH+/-, the code number decreases or increases by 1 while the remote control sends the code number for POWER button on your device. If the desired code number is found,press 100+ to program the code for your device until the LED blinks three times.Then the remote control exits from the PROGRAMMING mode and returns to norml operation. Or press any other button to exit from the PROGRAMMING mode after the LED blinks rapidly eight times, and the operation is not active. To check the current code number Press and hold VCR/DVD, SAT/CABLE or AUX for over 2 seconds until the LED turns off. Release the button (the LED will light again) and the remote control enters the PROGRAMMING mode. Press 100+ . You may read the code numder according to the LED display status as follows. * If there is no operation within 20 seconds during the steps mentioned above, the remote control will automatically exit from the appropriate operation. Code Number First - digit 0 1 0 1 Second - digit 0 0 4 5 Third - digit 0 6 3 0 First - digit Blinks rapidly once Blinks once Blinks rapidly once Bliks once Secod - digit Blinks rapidly once Blinks rapidly once Blinks four times Bliks five times Third - digit Blinks rapidly once Blinks six times Blinks three times Bliks rapidly once
Jan 05, 2007 | Apex Digital GB4308 43" Rear Projection...
Liebherr KES4260 Refrigerator Logo
200 people viewed this question
Top Liebherr Refrigerators Experts
Dan Webster
Dan Webster
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
