Question about Bobcat Miller 225 Welder Generator 907209 Or 907210
My welding machine does not want to turn on. it makes noises as you tried turning it on
    New Friend:
I had the same problem a few days ago try taken off the air filter to where u can see the choke get a spray bottle put a lil gas in it as u start ur welder spray the choke if it starts set ur machine to run it workd for me my uncle showd me this
Posted on Nov 18, 2013
Broken Fan Blade
No usually original equipment parts only.
Oct 03, 2013 | Hunter 30735 Air Purifier
How make tig welder to mig welder
switch from tig welding to mig by switching your current from AC to DC for mig. change from your tig gun to your mig gun. turn water flow off. proper ground and weld away.
Mar 29, 2013 | Miller Welding Tools
I purchased an older 250G trailblazer 88'-89'. Trying to weld with it but not doing too good. When I try a 1/8" 7018 the voltage is way too low, I can max out the settings or turn them to the
make sure you work area is clean and you have a good ground. ive welded with those machines and they are real touchy. just keep adjusting your amperage till its just right. once you get it tuned in they weld beautifully.
Feb 23, 2013 | Miller Welding Tools
I have had my ampeg svt 6 pro for a few years, never any problems until now. I just had a tone pot replaced. Now when i turn it on the fan is blowing at the max and the power light does not turn on and it...
first about the pop noise it caused by the Board inside the AMPEG need to be welding
second the power light simply check the 5v in your power supply
Jul 27, 2011 | Ampeg Svt 6 Pro Amplifier
Noise from the rear of my 97 crv when turning left and right
Hi
Sounds more a rear wheel bearing problem ?
Check for excessive play, and noise from both rear wheel bearings and hubs, with the vehicle jacked up and supported safely.
Good Luck !
A FixYa rating would be nice...Thanks... John.
Feb 27, 2009 | 1997 Honda CR-V
Miller syncrowave 200 makes buzzing noise from spark gaps.
Odd noises other than the normal sound of the spark gap working are often the result of dust and junk inside the case of your welder. That it also bogs down when it gets warmed up (fan comes on), also points to a need for some "annual maintenance" stuff being done.
Completely isolate the machine from the building power supply, pul the plug, open the circuit breaker, do whatever it is that makes the machine have no connection to any power.
Take off the covers with a 10mm or 3/8 inch socket (can't remember which)
Use a shop vac to **** out all of the dust and debris out of the machine. Low pressure (40 psi) air can sometimes be helpful to dislodge caked on dirt. Avoid any metal tools near the capacitor bank inside the welder.
Wipe off the fan blades.
Clean the spark gap electrodes by inserting and removing a matchbook cover, a business card, or a piece of white cardboard several times. Inspect the electrodes and adjust them according to the manual that came with the welder.
Check all of the power wiring connections for tightness by gently tugging on them. Look for signs of overheating on the power connections and on the internal connections to the welding terminals. Check the range switch for heating too.
With the cover still off, reconnect the power and turn the welder on. Look for obviously vibrating laminations on the main input transformer. If you see one buzzing back and forth, or if you notice lots of wear and tear on the varnish coating of the laminations, shut everything down and repair the loose laminations with some anti-fungal high voltage varnish.
Turn the welder off, disconnect the power, and put it all back together. Then turn the power back on and weld something, if htere is still a buzzing noise you'll need a Miller tech to solve the problem, you likely have a bad input transfirmer.
Regards,
Carl
Dec 16, 2008 | Miller Syncrowave 200 Tig Welder Cover...
Clicking noises. Mixer doesn't have enough power to mix.
You have a drive gear that runs off the motor gear. That gear has a problem. It has either broke away from the weld or you have a pin or key sheared.
Oct 28, 2008 | Hobart N50 Stand Mixer
Clunking noise
The clunking noise may be a broken weld on the drum.  Every time it turns and passes through the guide wheel supports, it makes a thunk thunk noise.  You will need to have a qualified LG technician diagnose the problem correctly but that's what it sounds like.
Jun 07, 2008 | LG DLG5988 Stainless Steel Gas Dryer
Bobcat Miller  225 Welder Generator 907209 Or 907210 Logo
Top Bobcat Welding Tools Experts
Lawrence Oravetz
wadingriver
wadingriver
Are you a Bobcat Welding Tool Expert? Answer questions, earn points and help others
