Question about Air Conditioning and Heat for Saturn Aura
I have a 2009 Saturn Aura and the heat nor air works just blows out warm air
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 68 Answers
Flush the heater core
Posted on Oct 21, 2013
    Champion:
  • 473 Answers
It is a Saturn, they have LOTS of issues with the Body control modules. The heat/air is directly controlled by it. Take it in to a GM dealer to have them diagnose it. Wish there was another way.
I have a 2007 Saturn, Aura. Heater does not blow hot, slow coolant leak, & it also over heats. Please help! I'm freezing when I'm in my car!!!
You need to fix the coolant leak, then refill and bleed cooling system, then you will get heat and cure overheating problem too
Dec 16, 2015 | Cars & Trucks
I have a 2009 saurn aura with a 2.4l ecotech. I had a shop replace the headgasket and waterpump. It still overheated and now I have replaced the thermostat and temp sensor my self. It is still holding the...
Air in the coolant system. Purge it. Next would be, replace the heater core. I would have taken it back to the shop and had them fix the problem. Unless you said replace the gasket. And not let them diagnose it.
Mar 15, 2015 | 2009 Saturn Aura
How to fix code p1682 Saturn aura 2009?
Look here about that code
http://engine-codes.com/p1682_saturn.html
Have you (or the dealer) checked the FUSES ???
Is the starter switch ok.?
Does it run OK ?
I dont think much of your so called dealer !!! "ECM will not ground powertrain relay" What sort of a report is that ??????
Sep 20, 2014 | Saturn 2009 Aura XE
09 saturn temperature gauge will not move
maybe a new thermostat is needed?
Sep 07, 2012 | 2009 Saturn Aura
When the temp outside gets above 95 and I first start my 2009 Saturn Aura, the air conditioner blows very hot air for up to 30 minutes with short durations of cool (not cold) air occasionally. After 15 to...
You might want to see if it might be low on 134a . Testing gauge can be bought at any auto parts store. Always check your a[c ounces ratio first. Auto parts store can do that. Refer to instructions for proper use. Use proper tools when working with things that are under preasure.
Jun 08, 2011 | Saturn Aura Cars & Trucks
I turn on heater and it sounds plugged when on front defrost? When I turn it to the feet it seems to work fine. Does not defrost front window while set that way. Where can I look. It is a 2009 Saturn...
There is internal vent flaps in the venting system to direct the air flow. The flaps can get stuck in one position. Sometimes the little motors that move the flaps can go bad. I would try to manually move the vent flaps. Pain to get to though as you have to pull some venting apart to access it.
May 14, 2011 | 2009 Saturn Aura
2009 Saturn aura: cigarette lighters/power ports
You likely have a blown fuse. I have heard using the cigarette lighter for charging your cell phone can blow the fuse - was told to use the charger inside the center console for charging my cell phone.
Mar 16, 2010 | 2009 Saturn Aura
Lights aren't staying on for the defrost, air etc...
I too have had this problem on very cold mornings, but have not been able to get this looked at yet since it's now summer.
Jan 27, 2010 | 2009 Saturn Aura
Brake lights stopped working 2009 saturn aura
take back 2 the dealer its under its under warienty
Feb 11, 2009 | 2009 Saturn Aura
Air Conditioning and Heat for Saturn Aura Logo
78 people viewed this question
Top Saturn Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Tim Garcia
Tim Garcia
Lawrence Oravetz
Are you a Saturn Vehicle Part and Accessory Expert? Answer questions, earn points and help others
