Question about Mcintosh MC300 Amplifier
Blown amplifier. My MC300 turns on for a split second and then it shuts off. I had changed the fuse and the same thing happens. Is it merely a fuse issue or is the power supply problem and how can I fix it. Please help
  • 2,113 Answers
Open it up and look for bulging electrolytic capacitors... even if none are bulging then are probably dry as a bone by now and need to be replaced with newer ones. look for burnt solder traces. I had an amplifier where the main power switch was acting up... i had to straighten the frame slightly so that the long plastic push rod didn't bind on it. Most things in electronics repair is somewhat obvious. Burned resistors etc. Make sure to use the correct ohms speakers and not to double them up.
Posted on Oct 19, 2013
  • PDiddy
    PDiddy Oct 19, 2013
    Did not see any bulding electrolytic caps or see any burned wires. Still not working.
98 BMW 528I MY RADIO DOESN'T WORK AND MY TURN SIGNALS COME ON BUT IT DOESN'T SHOW ON MY DASH. THE CAR DOESN'T SHOW UP PN MY DASH EITHER
if the fuse has not blown it could be the ignition control module it controls the dash and a few other things.
Nov 29, 2013 | Cars & Trucks
Is there a fuse in this amp? is it replaceable without soldering?
Hi, blowing a fuse in an amplifier is a problem that most guitarists face at one time or another. If an amp won't turn on, or it turns on for a second, then makes a popping sound and turns off, the problem is usually a blown fuse. Though a blown fuse can be a hassle, especially during a performance, it does not have to put a stop to your musical enjoyment. With a spare fuse you can be back jamming to your favorite tunes in no time flat.
Things You'll Need
Fuse.
Instructions
Turn off the amplifier and unplug it from the wall.
Locate the fuse, which is usually found at the back of the amp. The fuse will look like a small black wheel sticking out of the amp with a number and the letter V next to it. For example, 9V.
Gently turn the fuse counter-clockwise to remove it from the amp.
Discard the old fuse.
Insert the new fuse into the empty fuse slot and turn it clockwise until it is firmly in place.
Plug in the amplifier; make sure the power switch is in the off position.
Turn the amplifier on to make sure the new fuse is working properly.
Hope it helped..
Jun 14, 2011 | Crate FlexWave FW15 Guitar Amp Combo, 15...
MY AMP WAS WORKING UNTIL IT JUST STOPPED WORKIN AND WHEN I CHECKED THERE WAS A FUSE BLOWN UP BUT NOW AS I HAVE A NEW FUSE ITS STILL NOT WORKING ANY ADVICE WHAT TO DO THIS IS THE SECOND AMP IN A MONTH
Sounds to me like one of your positive cables keeps hitting metal somehow and causeing the fuse to blow. Ive had it happen to me when i had one of those amp splitter boxes that i didnt have mounted down properly and it slid into the metal on a seat post and same thing happened.
Apr 26, 2010 | Pioneer Car Amplifier GM-7100M - Mono Bass...
Hiss hight pich in the right
The part that's gone should be easy to spot if it had smoke comming out of it. If you can't read the numbers on it due to damage, remember that their will be another one excatly the same in the left channel.
Feb 20, 2010 | Mcintosh MC300 Amplifier
Changed speakers and now red protect light stays on? why?
the sub might have a short or is blown or the ohms are different
Mar 30, 2009 | Crunch PZi1000.1 Car Audio Amplifier
Amplifier lack of power supply
there is short circuit check the transformer and big capasitor for tanrsformer
Mar 21, 2009 | Jl Audio E1200 Car Audio Amplifier
Amp turns off after about 5-10 minutes of use for a few seconds
One of two things...Amp is going into overload protection (should be indicated by a light on the amp), or you have insufficient power going to the amp....if this is the problem, try a 2 farad capacitor on the input power line to the amp.
Mar 12, 2009 | Kenwood KAC-8104D Car Audio Amplifier
Amp and LED turn on for a split sec but the dies
Well you obviously aren't getting a signal to the amp telling to turn on. You need to take the amp to an audio shop who has a test bench and ask them to determine what other problems you might have. Quite honestly though there are better amps out there maybe you should just upgrade.
May 30, 2008 | Sony XM-2100GTX Car Audio Amplifier
Amplifier Not powering on.
Amplifier power problems are generally pretty easy to troubleshoot as long as you have access to a digital multimeter. You need to check the DC volts on the power terminal and on the remote terminal. For the amplifier to turn on, each terminal needs to show around 12 volts. From the sound of it, I suspect a problem with your main power wire, but the multimeter will make certain. If you show voltage on both terminals (with the black probe on the ground terminal) and the amp still doesn't turn on, then there's a defect in the amplifier.
Jun 25, 2007 | Alpine PDX-4.100 Car Audio Amplifier
Amp shutting off
Check your speaker load and/or bridging impedence. You didn't say anything about what kind of speaker load you were applying. Also make sure you have a large enough wire for both your battery input and ground connection. If you can pull all your speakers off this unit (after turning it off, of course)and it then will stay on, then either one of the previous suggestions may be the problem. If it still shuts off, then you have a blown amp probably. Good luck.
Mar 03, 2007 | Sony XM-502Z Car Audio Amplifier
93 people viewed this question
Top Mcintosh Audio Players & Recorders Experts
sean tan
Level 1 Expert
 Grubhead
Grubhead
Jay Plesset
Are you a Mcintosh Audio Player and Recorder Expert? Answer questions, earn points and help others
