Question about Frigidaire Refrigerators
Compressor kicks on intermittently, I thought it was short cycling so I replaced the start relay. this did not help. fridge sits at 60 and the freezer is at 37. The compressor will kick on for a short time and the temps will go down but only for about 10 minutes or so. All the fans seem to be working. Not sure where to go from here.
    Sergeant:
  • 304 Answers
Sounds like you have a freon leak or dirty condenser coils
Posted on Oct 19, 2013
the dr
  • 447 Answers
SOURCE: I have ? for model # ET1MHKXMQ00
Sounds like you need a new thermostat to me. They are kinda expensive, not too hard to replace though.
Posted on Jan 24, 2008
  • 236 Answers
SOURCE: Kenmore compressor cycles and does not cool
It sounds like you have a stuck compressor or bad start capacitor.
Stargazer
Posted on Mar 16, 2008
aborcass
  • 2651 Answers
SOURCE: buzzing noise from compressor start relay
sounds like your compressor is going bad, getting to hot , pull the unit from the wall and cleanall vents under and behind rear cover, make sure fan is running ot cool of the compressor, youll have 5 yr coverage on your compressor if needing repaired
Posted on Nov 11, 2008
  • 163 Answers
SOURCE: Compressor non start, overload cycling
you may want to try a 3-n-1 hard start for your compressor.the 3-n-1 has overload,relay and capacitor in one unit.very easy to install.it is possible your compressor has froze up.but worth a try.you can pick one up a your local appliance parts store.directions are on the bag.
Posted on Mar 25, 2009
  • 531 Answers
SOURCE: Frigidaire Side by Side Refrigerator/Freezer start cycle problem
check and see if fan working next to compressor
Posted on Apr 02, 2009
Model# 253.61821014 compressor keeps kicking off
Feel the top of the compressor is it hot? Usually when a compressor will start and stop this is called short cycling and it is caused by a defective start relay, overload and capacitor. Sometimes it it cause by a defective fan which when this happens all parts including a new fan must be replaced
241941004 Start Relay
218909913 Run Capacitor and a
242018301 Condenser Fan Motor
APPLIANCE911
It is not stuck in defrost mode with those symptoms
Apr 30, 2016 | Kenmore Refrigerators
Why does the compressor starts off with short cycles then kicks on?
Could be a compressor start relay, overload and run capacitor. What is the model number of the fridge?
APPLIANCE 911
Dec 07, 2015 | Refrigerators
Neither the freezer or fridge get cold. In fact, both compartments are warmer the room temp. The light comedy on and you can hear it run but you can hear a click like the compressor is trying to kick on. ...
the clicking is the compressor overload tripping. you can try a relay kit part number RCO410 available at any appliance parts supplier. this replaces the relay, overload and start capacitor. you might want to check continuity on the compressor terminals first and check for a short to ground. If shorted or open then the compressor is bad.
Mar 21, 2011 | Magic Chef Refrigerators
Comperssor kicks on but quickly cuts off intermittently every 5 minutes on my frigidaire fridge side by side
Freezer defrosted everything fan continues to run but will not freeze. Compressor is cycling enough to keep refigerator section cold. 106 Series Kenmore. Turned up thermostat to keep fridge cold and a shorter intermittent compressor cycle run
Jun 06, 2009 | Frigidaire FRS26H5AS Side by Side...
Replacing a relay switch on a Kenmore Side by Side
The start run relay kicks the compressor on. If your compressor is running this is not your problem.
There are a number of things that can cause a fridge not to cool. A bad defrost system.. Check to see if you have ice build up in the freezer, or a lot of frost. Also a bad compressor. The relay switch sits on the compressor at the back of the fridge. If you put a new relay on and it won't start the compressor you have a bad compressor. Most compressors are warrantied through the manufacturer for at least 5 years. So if it's that call the manufacturer for replacement.
Apr 15, 2009 | Kenmore Refrigerators
After moving frigde and freezer quit.
Your compressor start relay has become loose or possibly defective.
Push it back on for a good connection.
Watch it when you plug the fridge in.
If it sparks replace it.
Mar 12, 2009 | Frigidaire FRS23KF7AB Side by Side...
Problem has returned to Maytag fridge
I note this is a very old post. The compressor is not starting and what you were hearing was the PTC relay energizing followed by the KilXon thermal overload kicking off the compressor start sequence. What happens is that the PTC relays sometimes get a heated contact. Due to the weakened state of the contact it can cause a buzz. Even with a goo PTC relay you would hear the compressor buzz if it was not starting. In that case the run capacitor may have failed or the compresor rotor is internally locked at which point the start cycle will repeat every 3 to 4 minutes as the thermal overload cycles and the compressor will not start.
Thanks for choosing FixYa
Kelly
Jun 18, 2008 | Refrigerators
Compressor short cycling
If the compressor is run off of a relay then you could install a delay timer to prevent short cycling.
http://www.climatedoctors.com/items/item.aspx?itemid=429504
Jun 04, 2008 | Dometic Heating & Cooling
Refrigerators Logo
87 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
