Question about Emerson Humidifiers
I can't find the owner's manual and I need to know how to operate the humidifier. How do I turn it on? How do I set the desired humidity
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Emerson Master
  • 102,366 Answers
What model Emerson humidifier?
Posted on Oct 19, 2013
  • 104 Answers
SOURCE: Am looking for the owner's manual for the
you can download here
http://rapidshare.com/files/225370310/4858c9fccc48b69c50a7b921cff38680.pdf.html
Posted on Apr 24, 2009
SOURCE: Vicks v4500 humidifier stopped working.
i know why. clean the small long tubular thing that is sucking the water. put a q tip in there and get the gunk out. thats what you need to do -- try it and let me know if it worked. msoobhawan@gmail.com it worked for me!
Posted on Feb 06, 2010
SOURCE: How to adjust settings
You can get a PDF version of the manual here...
http://homeappliance.manualsonline.com/manuals/mfg/honeywell/dh835.html
Posted on Sep 05, 2010
Sparky2012
  • 102 Answers
SOURCE: The humidifier says "desired humidity" when turned
I would say, either the humidity level in the room is hi or the humidifier is defective, In my house the humidity is about 42% to 45% when we use the humidifier, and can drop to 30% or less if we don't, we leave in DC area,
I hope this helps.
Posted on Jan 15, 2011
gargac
  • 39 Answers
SOURCE: After cleaning everything the humidifier no longer
The humidstat controler has failed. By cleaning the humidfier you introduced moisture into the system. Dry the humidstat controler with a hair dryer and try the humifier again. If the unit still does not shut off at maxium setting. Replace the humidfier controler.
Posted on Jan 27, 2011
After cleaning everything the humidifier no longer runs. When I turn it on no matter what level I set the desired humidity to the green light goes on indicating that it is at the desired humidity. Before...
Jan 26, 2011 | Hunter 32300 Humidifier
I hope this helps.
Jan 14, 2011 | Vicks V4500 1 Gallon Humidifier
I purchased a home with a aprilaire model 224. How do I know if its working?
Here is a link to the owners manual. http://www.aprilaire.com/themes/aa/en/manuals/Humidifiers_Owners_Manual.pdf
You can also pickup some cheap humidity gauges at a hardware store to check the settings on your unit verses the actual humidity in the house.
Dec 19, 2010 | Aprilaire Humidifiers
Aprilaire 700. It works on fan on mode but not otherwise. It's never on and the humidity reading is always way below the setting. It should turn on automatically to bring the humidity up, right?
It appears your Aprilaire model 700 is wired to only operate when your HVAC fan is operated by your thermostat. Your HVAC installer can wire the humidifier control to operate the humidifier during a heat call, fan call or to turn on the fan when there is a need for humidification. Please contact your HVAC installer to have them change the wiring.
Thank you for giving us the opportunity to be of service
Sincerely,
Brad Uselmann
Technical Support
Research Products Corporation
www.aprilaire.com
Nov 01, 2010 | Aprilaire 700 Humidifier
Mar 16, 2010 | Honeywell DH835 Humidifier
Vicks v4500 humidifier stopped working. Indicates that 'desired humidity reached' but it clearly hasn't been reached. Lights are functioning but humidifier does not operate.
Jan 10, 2010 | Vicks V4500 1 Gallon Humidifier
No matter what setting is put on furnace humidifier, moisture forms on windows.House is only 6 years old and does have a lot of windows.
Hello WPwilkers, Well there's good news and good news!
First off, you should probably use the lowest possible setting as your house being so new, is likely pretty "air-tight" and as such, doesn't have a lot of air infiltration (gaps and drafts) hence the reason you're seeing moisture on the windows.
Now, I would also use a hygrometer, just like your parents likely had hanging on a wall somewhere in their house. It will give you a better idea of the moistur (humidity) around the house. My guess is that you're already at the 60%+ level of humidity.
I suggest that you turn "OFF" the furnace mounted humidifier, until you no longer see moisture on the windows. That will allow the house to adjust and get back to normal humidity levels.
Then you can start by setting the humidifier on the lowest possible setting and keep an eye on the moisture levels in your coldest room of the house, as that is where you'll first notice the excessive moisture on the windows (just the way it works - cold rooms get condensation on the cooler windows first).
If you don't have the humistat (the control for the furnance mounted humidifer) mounted next to your heating and cooling system thermostat, you should do that - it will make it easier to adjust and also will provide a more accurate reading for the humifier to operate properly.
Some Thermostats have the ability to add a humidifier on it for integrated controlling of the furnace humidifer. Check your Thermostat and Furnance owner's manual for details.
I used to have the same problem and found that by moving the humidifer control from the utility room (mine was in the basement of my house) to the living space, it made a big difference. Since most people's homes have unfinished basements and that's where the HVAC system is located, it doesn't get the same humidty readings as an occupied living space.
The other reason that you tend to get moisture (condensation) forming on windows is that the Percentage of humiditfication is set manually with the humidifier control, and yet, the outside (and inside) air temperature vary and the difference between them can cause the humidity levels to go from very dry to very moist, in a day or two.
I tend to wait until I notice that the air inside the house is getting dry and then turn on my humidifier, once the cold winter days have taken hold. In summary, nothing wrong with your unit, just mother nature and a well built (most air-tight) home are giving you higher levels of condensation than most older homes. Gradual adjustments, once you turn the humidifier off for awhile, should get you the desired results.
I hope you find this Very Helpful and best regards!
Dec 17, 2009 | Honeywell HE365 Humidifier
Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
DO NOT LET WATER SIT IN TANK FOR LONG. THIS CAN ENCOURAGE BACTERIAL GROWTH.
Place unit on level surface away from direct sunlight.
DO NOT ADD MEDICATION OF ANY TYPE INTO THE NOZZLE, BASE, OR WATER TANK.
ALWAYS LEAVE ROOM DOOR PARTLY OPEN. DO NOT MOVE, TILT, OR EMPTY WHILE OPERATING.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
Sep 22, 2008 | Sunbeam Ultrasonic Humidifier
Humidifiers Logo
160 people viewed this question
Top Emerson Humidifiers Experts
Paul Carew
Dennis
Are you an Emerson Humidifier Expert? Answer questions, earn points and help others
