Question about Cuisinart Coffee Makers & Espresso Machines
Where to buy replacement hot water plug for Cuisinart CHW-12
  • 2,113 Answers
Define plug. Electrical cord?
Posted on Oct 19, 2013
Testimonial: "The rubber (silicone) plug in the bottom of machine the allows the water to be drained from the hot water tank."
2 Suggested Answers
SOURCE: need replacement carafe for Cuisinart CUI CHW-12
cuisinart chw-12 replacement carafe is Cuisinart DCC-1200PRC 12 cup replacement carafe.
Posted on Jul 17, 2012
The hot water system on my Cuisinart CHW 12 coffee maker comes on by itself. I have unplugged and replugged the power cord. I have also drained the reservoir and refilled it. What can I do to keep it from...
Try leaving the device unplugged for 30 minutes before trying again. In older Cuisanart coffee makers it took that long before the internal computer would reset itself when electrical power is reapplied.
If the problem persists and you have verified the controls are set properly then likely the heater circuit control has failed.
Dec 09, 2017 | Cuisinart Coffee Makers & Espresso...
How do i get the bottom cover off of a chw 12 cusinart coffee maker?
Here's the manual:
https://www.cuisinart.com/share/pdf/manuals/chw-12.pdf
Nov 17, 2017 | Kitchen Appliances - Others
Makes popping noises
If the wires are shorting out you would either experience a power interruption, circuit breaker or fuse blow, and/or a smell of some sorts. If this is under warranty I suggest you turn it in for a new one. On the other hand, remember it is a percolator device and when water is heated to the desired temperature the action is for the hot water to rise and flow over the basket containing the coffee grounds. Percolation makes a popping sound, at that is a normal condition.
Dec 22, 2013 | Cuisinart CHW-12 Coffee Plus 12-Cup...
Cuisinart CHW-12 goes dead before completing brew. No lights, no clock- just dead as if a fuse were blown, but outlet is still live.
My first guess would be that the control panel above the carafe has a thermally sensitive component or poor contact that acts like a fuse when it heats up but is fine after a cool-down. If this is the cause, disassembly and detailed inspection are required. If you're handy with a low-wattage soldering iron (30W), you could resolder connections on on the controller.
My second guess would be that there may be an over-temperature circuit in this unit that removes power if the unit gets too hot (you don't want a fire and Cuisinart has has some history here). If this is the cause, there is a failed thermostat in the heating system.
Sep 29, 2013 | Cuisinart CHW-12 12-Cup Coffee Maker
No display on panel. It is blank and I can not turn the coffeemaker on.
Check your breaker first. Plug in something you know that works. Next , check your off on switch. This is likely the problem. the switch may feel soft. remove the cover to it and you may see a wire that is burned off the terminal. with no lights, there could be just avloosecwire. t
Mar 14, 2013 | Cuisinart Chw-12 Coffee Plus 12-cup...
Coffeemaker shuts off in the auto brew cycle
Your Cuisinart coffee maker probably is defective, though new.
Jan 10, 2018 | Cuisinart Chw-12 Coffee Plus 12-cup...
Coffee Makers & Espresso Machines Logo
89 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
