Question about HP Pavilion N5415 Notebook
Laptop screen went out/bad
I have a hp pavillion 5200/5240 laptop w/pentium four that had the monitor go out. The rest of the computer turns on but the monitor does not. Is this a monitor problem /software? Anything I can fix myself? The computer was only about two years old when it died. Its been sitting in the closet for about two years plus. thanks
  • 33 Answers
Hi falcon30, first thing I would suggest you do is plug the laptop into an external monitor to check that the graphics card/the laptop itself is functioning ok. All your need is a standard PC monitor with a VGA cable, plug the VGA cable into the blue port labeled 19 on the picture below. Turn on the laptop and if nothing appears on the screen, hold down the 'Fn' key and press f5. If nothing still shows than this suggests a different problem. If it shows ok on the screen however, and boots fine then it would suggest that something has failed screen-wise. This could possibly be fixed yourself if you feel confident enough, but without having access to the laptop I am unable to tell you which part of the screen has failed, so the whole screen part of your laptop would need to be replaced, spares for this sort of thing can be found on ebay, and disassembly instructions can be found at this link: http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=299255&cc=us&lc=en&dlc=en&product=299255&dlc=en&lang=en , you need to download the PC service manual. Otherwise you can continue to use the laptop with a normal PC monitor. If you need any more help just let me know, good luck and all the best. Si :)
Posted on Sep 26, 2007
I have had the same problem at work with 3 different HP pavillion zv5000 series. For some reason the laptop screen goes into sleep mode and it appears to be a bios corruption thing. In my case, what we did was to turn the computer off for at least 15 minutes, then turn on. Sometimes the screen comes up for 5 minutes before shutting off, sometimes it never comes on. Press the little button the turns the screen off when you close the laptop. Press many times real quick. You will see the screen flickering and can see the image, enough for you to know what it's in display. Download a new bios version and upgrade or reset your bios (keep pressing on and off the laptop button that turns off the screen when you close it if you want to know what is on the screen. The quick flickering on the screen will give you time to read what is on the screen and monitor the bios upgrade. Once youy reboot your laptop will be to normal
Posted on Jun 16, 2008
6ya staff
SOURCE:
HP Pavillion a1514n Won't Turn On
Hook a monitor to the video output, if no change! the video graphics chip is bad located on the motherboard.
Jun 29, 2012 | HP Pavillion dv9740us Notebook
Ihave an hp pavillion laptop where the screen went black and need a solution to fix
First hook a spare monitor to the video output jack usually on the back, if picture comes up! it indicates a bad inverter board, or the backlight has stopped working, if the spare shows the same problem, it means the video graphics card is defective and normally built into the motherboard.
Mar 05, 2012 | HP Computers & Internet
HP Pavillion dv900 no longer has visual--Daughter's computer--I can hear the hard drive kick in, but no visual whatsoever. Cna I use a separate monitor for the visual? Someone told me the HD is "fried". I...
I wouldnt think the hard drive is bad. Even without a hard drive you should have something on the screen.
What I would do, is look on the back of the computer. And there is a monitor port. Hook up an external monitor like for a desktop. To that port.
Then turn the computer off and on. If it picks up the monitor. Then you have an issue with the lcd screen.
If you dont see anything. Then it could be the motherboard or the graphics card has went out.
To back up my thoughts, read over the forum link below and see if it sounds similar.
http://h30434.www3.hp.com/t5/Hardware/Hp-Pavilion-dv900-wont-boot-up/td-p/140411
Aug 03, 2010 | Computers & Internet
HP Pavillion Entertainment computer (laptop)
now u put out to another monitor by cable if u see screen in there ur lcd have problem, if black too it from ur motherboard , checking
Jan 14, 2010 | Computers & Internet
My monitor will not wake up
I wm having this same issue. Dis you ever get this resolved? [email protected]
Oct 17, 2009 | HP W2007 LCD Monitor
I have a hp pavillion dv4 1225 dx , my display is really bad , like almost gone, i would like to back up my documents before shipping laptop to hp for repairs, so i was thinking of connecting an external...
You can connect any HDMI or VGA (15 pin) compatible monitor or TV, almost every monitor has VGA connector or VGA adapter at the end of connector and you can use it.
Sep 28, 2009 | HP NB199UA Pavilion Notebook
My HP Pavillion laptop turns on but the screen doesn't show.
You could be expierencing a problem with your monitor screen. try this.... connect another monitor screen to the VGA port of your laptop. Now try booting up. Look for and push Fn + the key that turns on a secondary display. if the monitor screen comes on. you need
another laptop monitor. At least you can use your laptop with the second monitor for now.
Jun 16, 2009 | HP Pavilion dv9000z Notebook
Screen is dark
DID YOU TRY EXTERNAL MONITOR TO SEE IF IT IS A SCREEN ISSUE
ROD
Feb 09, 2009 | HP Pavilion zd8000 Notebook
HP Pavillion dv9000 fatal error
On the windows boot screen you should be getting choices for safe mode, safe mode with networking, etc ...
Select "Disable automatic restart on system failure'
And let me know what error message(s) you have ... write it all down
Jan 14, 2009 | HP Pavilion dv9000z Notebook
Screen dim to black
This will be a problem with either the screen inverter or screen backlight. You will need to take it to a shop for diagnosis, in order to find out which one it is. If it turns out to be the backlight, then the entire screen will have to be replaced. They are considered a sealed unit, and the backlight can't be changed out.
Jul 24, 2008 | HP Pavillion ZV6000 Notebook
HP Pavilion N5415 Notebook Logo
398 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
