No! the main fuse is okay because you would not have any power. I would check all door switches because they control light, fan, and turntable. If you are handy with a meter, set to ohms, disconnect one wire on side of switch, use meter to test, readings should show open/short when pressing the button and releasing it, replace wire to switch and repeat, if you hit one with the same readings pressed in or out, change the switch.
yes theres a fuse just behind the clock on the right han side near the top, take the back off and the top comes off with it the fuse sits in the right hand side near the front at the top you can buy them from maplins electronics
sounds like the cooling fan has came adrift or stopped working , this will cause the magnatron ( the microwave generator ) to overheat tripping the over temperature stat ,so fix the cooling , but be sooooooooooooo carefull in there , microwaves + really high voltages , not really a job for a non electrician/microwave tech
It looks like the part of your computer board on microwave which responsible for controlling light and fan stop working. In this case you have to replace computer board.
