Question about Emerson Lands Phones
Cant Hear No Dial Tone On Emerson 2516 - Emerson Lands Phones
  • 4 Answers
SOURCE: When i dial and press the talk butto, i still hear a dial tone...please help
Please follow these troubleshooting steps;
Tip 1 of 9
Move the handset closer to the base. The operating range may vary with environmental conditions and time of use. There may be places within your environment that a cordless phone will not work well. If the problem only occurs in certain areas of your environment, you can conclude that there is nothing wrong with the phone. Consider trying a phone that operates on a different wireless frequency.
Tip 2 of 9
If you subscribe to DSL service for this telephone line, DSL filters must be plugged into EVERY phone jack that has a phone. The DSL signal can cause static/noise, squealing (similar to fax tones), caller ID disruption and other issues on your line. DSL filters block the high frequency DSL signals from being transmitted to the telephone. If you are not using the DSL filters provided by the telephone company, this will cause static/noise and possibly caller id issues on your phones.
In most cases, we recommend you connect the plug end of the DSL filter into the telephone jack, then connect a telephone cord between the filter and your phone.
Please contact your service provider to obtain DSL filters and installation information.
Tip 3 of 9
Other electronic products (i.e., 802.11 wireless networking products, radios, radio towers, pager towers, cell phones, intercoms, room monitors, televisions, personal computers, kitchen appliances and other cordless phones) can cause interference with your cordless phone. Try installing your phone as far away as possible from these types of electronic devices.
Tip 4 of 9
To get better reception, try moving the telephone base to higher location. Relocate telephone base near a window if using telephone outside.
Tip 5 of 9
Excessive background noise will cause a speakerphone to fade in and out. Try controlling the background noise by turning off any audio devices near the speakerphone. Also, try to avoid interrupting the person at the other end of the conversation while they are speaking. If background noise cannot be controlled, you should terminate speakerphone operation and return to normal handset mode.
Tip 6 of 9
Disconnect any other equipment that is connected in series with your phone. If you phone begins to perform normally, there is a compatability issue with your other equipment.
Tip 7 of 9
If your phone shares a power outlet with a modem, or if it is plugged in to a shared surge protector, try plugging the phone (or modem/surge protector) in at a different location. If this solves the problem, re-locate your phone or modem farther apart from one another, or use separate surge protectors.
Tip 8 of 9
There may be places within your environment that a cordless phone will not work well. If the problem only occurs in certain areas of your environment, there is nothing wrong with the phone. This is normal radio operation.
Tip 9 of 9
You may have a line problem. To test for a line problem, test your unit at another location such as your neighbor’s or relative’s house. If your unit works at another location, contact your local telephone company
Posted on May 08, 2008
SOURCE: Dial Tone but won't call out.
The problem was the main phone line not the phone itself
Posted on Jan 08, 2009
  • 84 Answers
SOURCE: Dial tone is active as I'm dialing, callers cannot hear me speak
Your phone is broken, the only solution is to replace it. Call Uniden Customer Service and they should be able to help you. 1-800-297-1023. ( I'm serious, there is no way you can fix this problem with out opening the base unit up and replacing a bad transistor)
Posted on Feb 27, 2009
  • 8404 Answers
SOURCE: no dial tone
Generic answer
You MUST get dial tone to talk or listen. Your base may ring but this may be unrelated to the telephone signal.
Check all wires and all settings. Are yoju certain your hand set is a member of your telephone group?
Posted on Sep 23, 2009
SOURCE: Cannot hear any dial tone, but base works OK - callers get busy s
Headset says ringer off, cannot hear dial tone
Posted on Nov 14, 2009
WHEN I CALL MY HOUSE PHONE IT DOES RING BUT YOU CANT HEAR ANYTHING AND THERE IS NO DIAL TONE IN IT
you have a line fault. Phone your telecoms company. Often they can fix it at the exchange or on a pole, or the junction box outside your house.
Feb 02, 2016 | Lands Phones
Emerson Model No EM 2516
The EM2516 is not an answering machine. The Delete button is for deleting numbers from its speed-dialing memory.
Nov 25, 2012 | Emerson Lands Phones
Cant get the phone off pulse when dialing model#EM6113-BK
Tone/Pulse
You can switch the dial mode. In most situations the TONE option should be selected.
Press the "Menu OK" button. Select BASE using "
May 30, 2010 | Emerson EMSEM2646WH Phone
Have an Emerson cordless phone EM6113-BK. We can
On that model you need to press and hold the FLASH button, after it beeps it will be in tone mode and not pulse.
Apr 16, 2010 | Emerson Smartset Clock Radio
My phone wont dial out and when someone calls they can hear me but i cant hear them
Does your phone play songs?I guess your phone's speaker isnt working. That is why you cant hear to people and if you dial a call you are not able to hear the tone.
Feb 28, 2010 | Cell Phones
I have a Emerson DECT 6.0 with 3 head sets and i cant get the dial tone back from pulse.
It was easy for my Emerson Dect 6.0 to be switched either rotary / pulse by just pressing the "FLASH" button for 3 seconds until it beeped. Problem solved.
Or if that doesn't work, you have to:
Tone/Pulse
• Press the MENU button. Select BASE using <FLASH - or - CID> and press the MENU button again.
• Using <FLASH - or - CID> select DIAL MODE and press the MENU button.
• Using <FLASH - or - CID> select TONE or PULSE and press the MENU button.
OR
Press and HOLD the "<FLASH" button for approximately 3 seconds. T (Tone) or P (Pulse) appears in the display.
Feb 12, 2010 | Uniden DECT 6.0 Cordless Telephone...
No dial tone ,gets incoming, but cant hear anything, they cant hear me
Generic answer
Sep 23, 2009 | Uniden DECT 6.0 Cordless Telephone...
Cant send a fax
Confirm dialing the correct fax number?
Any 0s to get an outside line, any special area codes?
What happens when you try to send a fax, can you hear a dial tone? can you hear the fax ringing? can you hear a response from the recipiant?
Jul 17, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
Mute is turned on cannot hear phone ring. How to turn mute off Mute is turned on . Have no dial tone can't call any one and can't answer the Phone How do you turn mute off?
I can't talk or hear outta my phone. I can dial people but i cant hear them and they cant hear. My phone model Cordless 5.8GHz Edge Dual Handset Phone System with Caller ID:
Jun 08, 2008 | Uniden Cordless Phone
Can not hear dial tone or anyone on other line
your problem is not about the monitor,but i'm sure speaker in the phone is defective.try to replace it with a new one.
Oct 19, 2007 | Gateway FPD2275W LCD Monitor
Lands Phones Logo
35 people viewed this question
Top Emerson Lands Phones Experts
Computer Repairing
Computer Repairing
george  peters
george peters
Are you an Emerson Lands Phone Expert? Answer questions, earn points and help others
