Question about DeLonghi EAM3500 Espresso Machine/Coffee Maker
Water is not registering displays says no water when tank is full. what can i do?
  • 55 Answers
Check and see. If there is a float still in the water tank.. It's a magnet. Sometimes they stop floating then machine thinks there is no water..
Posted on Oct 19, 2013
Display fill water only but water full help
check small float in tank is not stuck in the down position
Dec 29, 2013 | Jura Capresso Impressa S90 Espresso...
Register water heater
Whirlpool water heaters are made by AOSmith company, which owns American, Reliance, State, Craftmaster and makes water heaters for Kenmore and Whirlpool.
These are good heaters.
Register Whirlpool product at following link:
http://www.whirlpoolwaterheaters.com/support/warrantyreg.aspx
It is not necessary to register product for warranty to be valid.
And if you move to new home and take water heater, then warranty does not follow. So it might be disadvantageous to register product in that circumstance.
You can see brand, model number, and serial number located on label on side of tank.
The serial number is unique and is key for warranty coverage, even if you lost receipt. Serial number shows year of manufacture in first two digits.
http://waterheatertimer.org/pdf/Find-Age-of-water-heater.pdf
It is not necessary to register water heater for warranty to be valid, as long as following applies: Original owner, single-family non-commercial residential installation, and installation that conforms to instructions shown in product manual, and water heater is maintained as shown in product manual.
If you purchased extended warranty, then remember the warranty is carried by a third party that also requires same as above.
And the warranty may be pro-rated, rendering it nearly valueless in later years.
Typical water heater warranty:
First year of warranty covers tank-parts-labor.
After first year, the warranty shrinks to tank-parts.
The math shows that shorter warranty tank has greater percentage of full coverage.
Convert ordinary 6 year tank into 9-12-15 year tank by maintaining water heater. Especially cleaning air intake located on bottom of tank, inspecting anode rod to prevent rusting, and following maintenance schedule shown in product manual.
http://waterheatertimer.org/How-to-maintain-water-heater.html
Oct 27, 2012 | Whirlpool 6th Sense 40-Gallon 6-Year Tall...
Display on Saeco Magic Comfort+ says "Fill Watertank" even when tank is full. Removing and resetting does not help.
Hi
This is usually a magnet in the water tank or sensor inside the machine. First do you have the grey magnet in the water tank? If no magnet in the tank, that is the problem. The magnet floats when the tank is full and sinks when its empty. It sends a flux signal to the sensor inside the machine. If the sensor is bad inside it doesn't pick up the flux field and you get the "water tank empty" display.
May 23, 2011 | Saeco Magic Comfort Plus Espresso Machine
What is the P2 code on an everstar mpk 10cr1
<b>Unit Displays P1</b><br /> P1 error indicates that:<br /> <ol type="A"> <li>The water tank on the side of the unit is full. <li>The water tank in not properly seated in the housing. <li>The switch at the back of the water tank housing is not engaged or is loose </li></ol> <br /> <i>Solution</i>:<br /> <ol type="A"> <li>Empty the water tank. <li>Make sure the water tank is properly secured in the housing <li>Remove the water tank for the housing and gently tilt the switch at the upper left hand corner of the housing towards you. This should allow the tab on the water tank cover to engage the switch. </li></ol> <br /> <b>Unit Displays P2</b><br /> P2 error indicates that the spill reservoir in the base of the unit is full.<br /> <i>Solution</i>:<br />Move the unit to a location that is suitable for draining water from the unit.<br />Remove the plug in the lower center of the back of the unit and allow the water to completely drain <br />(Remember to replace plug.)<br /> <hr color="#cccccc" size="1" /> <b>Unit Does Not Cool/The Green Light is not on. </b><br /> Is the unit in the Cooling mode?<br /> <i>Solution</i>:<br />Press the mode button until cooling mode is selected. <br />Lower the temperature setting on the unit to the minimum setting. <br />(The temperature setting of the unit has to be lower that that of the room)<br />Wait 3 to five minutes for the compressor to start running.
Jul 06, 2010 | Danby DPAC8020 Air Conditioner
Solis palazzo espresso maker / water tank problem
HI
Did you push the water button, before you opened the knob? When you finished descaling did the lights change? On any compact machine you need the let the pump stop on its own. Then go to the next part, rinsing. Again letting the machine stop on its own. Pump will stop and the lights will change. Once the machine has finished rinsing. You will have a steady water light and a blinking green light. Put your tank back on with fresh water, then push the water button(far right), then open the knob for water. The red light should go out, and the machine will heat again.
Dec 22, 2009 | Coffee Makers & Espresso Machines
I have an Incanto s class de luxe and it is telling me to fill the watertank and it is already full?I have turned it off and back on, and it is still not registering that the watertank is full?
Hi
There should be a grey cylinder in the bottom of the water tank that will rise and fall with the level of the water. When the tank gets low the cylinder will sink and the water light will come on. If the cylinder is missing the light will come on also. If the magnet in the cylinder is bad the light will come on. Some time it takes replacing the water tank.
Aug 18, 2009 | Saeco Coffee Makers & Espresso Machines
Krups XP9000 won't recognise water tank is full
I have just had the same problem with my Krups XP7240 and I discovered (quite by accident!) that it was the magnetic float inside the water tank which was causing it. I think the float must have let some water in and always stayed on the bottom even when the tank was full. As the float was in an enclosed plastic column it was a bit hard to access, but through sheer desperation I snapped a plastic fork in half and wedged the handle section under the float to keep it off the bottom and this works nicely. It is not professional by any means but I was quite pleased with my innovation :)
The only down side to this 'method' is that the opposite is now true and when the tank is empty it doesn't register so you would really have to keep an eye on the water level to avoid killing the element completely.
I would imagine that the only professional way to get this sorted out is to replace the tank (or float if it is accessible?). Good luck!!
Feb 04, 2009 | Krups Small Appliances Espresso Machine
I Have a Krups Espresseria automatic coffee machine & my problem is the water indicator in the water tank does not rise when the water tank is full so the machines keeps telling me to take the water...
Inside the water tank there is a magnetic float which is causing the problem. This float is moving always on the top of the water tank as you fill it with water and in reverse as the water level goes down then the float is moving down to bottom also. So as the magnetic float is moving up and down is giving the signal for the water level if it is full or empty.
So possibly now the float is stuck in the bottom and even if you have refill the tank this is still on the bottom of the tank. This can happen from many reasons. First could be that the plastic column that the float is moving is full of scale and it can not move up and down freely any more so you can clean it from scale by decaling it and even clean it with a wire brush.
A second possibility could be that float have a tiny hole and some water enter in the float and this make it to stay on the bottom of the tank. You can visually inspect it and if possible you can dry out the water and weld with a super glue the hole if possible, if it can not be fixed then you need a new float.
If you wand to fix it temporary until you find a new float you can a plastic clip or similar to secure it always on the top however you when the tank is empty it doesn't register so you would really have to keep an eye on the water level to avoid any other problems with the machine.
Good luck
Nov 17, 2008 | Krups Small Appliances Espresso Machine
Fill Water Tank But Water Tank is Full
hello in the water tank they is a float it was probably out of water for a while and the float is stuck take the container in our hand and tap it gently by doing that the float gonna get loose move the container you gonna ear the float move put it back fill with water enjoy cheers
Jan 14, 2008 | Gaggia Titanium Espresso Machine
DeLonghi EAM3500 Espresso Machine/Coffee Maker Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
