Question about Electrical Supplies
Honda generator My Honda EU2000i generation starts on the first pull with the choke on but as soon as you turn the choke off it shuts down. Also after starting if I leave the choke on, the generator will also shut down after a few seconds. Any ideas on the problem? Thanks in advance.
    Sergeant:
    Champion:
  • 320 Answers
The running on choke is caused by a fuel restriction. Check the fuel flow from the tank to the carburetor.Change the fuel filter if it has one. If its good, then the restriction is in the carburetor. The generator is shutting down due to the low rpm coming from the engine. A carburetor rebuild may need to be done.
Posted on Oct 19, 2013
SOURCE: honda em2500 starts, runs 1 minute, quits and will not restart
If the oil level is low it will do this, but I also know this to happen when the oil is very cold (thick) an won't fow back own o the crankcase where the oil sensor is. The slow return results in a low oil level. My solution is to start it, when it dies wait a couple of minutes and retry... after a few starts, the oil will warm up, thus flowing back down faster and it then will run. Another option is to use a thinner oil ie;5-30w.
Posted on Apr 29, 2009
deme-tri
  • 90 Answers
SOURCE: I have added oil to the enginn as directed on my
clean out the cabrateor
clean out the tank
Posted on Aug 02, 2009
deme-tri
  • 90 Answers
SOURCE: New NorthStar generator with Honda GX620 runs only a few seconds.
caborator needs cleaning
protek480
  • 1723 Answers
SOURCE: E29 Trouble Code for a Honda Generator
Honda is pretty tight with the codes. You have to call a 'Authorized Dealer' to get it
Posted on Aug 05, 2009
  • 7 Answers
SOURCE: I have a Honda 7000 EM inverter generator. When it
ARE SURE ITS THE OVERLOAD LIGHT AND NOT THE NOIL ALERT? IF ITS THE OIL ALERT ITS CAUSE YOUR LOW ON OIL OR THE SENSOR INSIDE THE GENERATER IS BAD?
Posted on Sep 10, 2009
I have a deep eu2000i inverter, the problem is to remove the carburetor throttle, it takes some kind of setting as to start the engine low speed, and connect a tool fails ....
if your question is that my Honda generator wont idle up when I connect a load (tool) and it stalls then . first see if unit will run on constant setting (switch on front) if nothing or still barely runs or stalls , then your problem is carb or fuel filter (inside tank) one or both is most likely dirty and needs replaced/cleaned
Oct 15, 2016 | Honda EU2000i Companion Inverter Generator...
What do I check? i have a honda eu2000i that starts and runs but no generator power
The internal monitor is sensing a load does a load make it change tone? Check the 12 v output and see if it is loaded.
Kevin H
Sep 08, 2014 | Honda Eu2000i 2000w Generator
My EU 2000I ran my half ton AC unit for over a year. It now all of a sudden starts popping the 20 amp breaker anytime I turn it on. It only pulls 10 amps at startup. What's with this? Is it time to...
Make sure it isn't trying to start the HVAC with a locked compressor (IE it just turned off and is now trying to cycle on again) If it is shutting down due to low freq there is too much load for the HP the engine can deliver. That will cause too much current to flow and trip the breaker. Also be aware it takes 6 times current to start HVAC than to run it. How old is the generator? it may have normal engine wear and can no longer generate HP, Also when was it tunes up
Sep 30, 2013 | Honda EU2000i/Companion Parallel Cable/RV...
If my generator shut off due to low lubricant will it reset automatically? If not is there a reset valve/button?
The pull cord is like a starter on a car (separate from the motor/engine). If the pull cord will not turn it could be because the motor/engine is seized.
Mar 04, 2013 | BlackMax 3000 Watt Gas Generator - Powered...
I have a eu2000i honda generator that will not start. It is getting spark and will fire when I put a little gas in the cylinder. It is obviously not getting gas, but I don't know what to do about
needle valve stuck.on the bottom of the carb there is a bolt holding the bowl. inside there is a needle valve attached to the float. hondas have a spring loaded rubber tipped needle valve and tends to get stuck in storage(unless it is left empty this will happen almost every time) check seals on bolt and bowl before re installing .
Jan 27, 2013 | Motorcycles
Screeching sound-Honda eu2000i
Sounds like a bearing has failed or something has gotten inside the generator or engine area where it spins and is now rubbing against it. There is a bearing at the far end of the generator from the motor and it is most likely to be where the noise is coming from. Best to repair it before it seizes and wears out parts you don't want to have to try to find!
Oct 30, 2012 | Honda Eu2000i 2000w Generator
How to start the generator
Hi Joe, I had asked for a little clarification and have not received any information. I will answer this question based on the generator is in good working order and it is a recoil start. Open the petcock, (this is the fuel valve) and give it about a minute to fill the fuel bowl on the carburetor. If your generator has an engine an on/off kill switch, set to on. If the generator has an auto idle switch set it to off. If the engine has a throttle lever located under the carburetor, push it all the way down (full throttle). Pull the choke knob out completely, there is a detent on the choke for half choke, pull it past this for full choke. pull the recoil starter rapidly. As soon as the engine starts running push the choke knob to half choke, this will allow the engine to run smooth while it's warming up. Depending on the climate that you are in, warm up time will vary. After a minute or two in cold climates start pushing the choke knob in, if it starts to run poorly pull it back out too the half position and let it warm up some more. When you can posh the choke in without the engine faltering it is ready to go. In warmer climates you might be able to start the engine without the choke or in the halfway position. Robin Subaru makes some of the finest small engines available. I would choose a Robin over a Honda every time. I hope this gets your generator going, and once again this is based on the generator being in good working order. Good luck, Michael Burke.
Dec 03, 2011 | Coleman Powermate Subaru 5000W Portable...
Eu2000i lopes while idling. If i slide the choke
This is NOT uncommon when no load is on the units.
The "gain" of the govenor is designed for maintaining speed under load and will "hunt" a bit without a load on the unit.
Apr 02, 2010 | Electrical Supplies
Honda EU2000i with a washing machine
Yes - it will be a fine machine to have and do well.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 10, 2009 | Kenmore Washing Machines
Electrical Supplies Logo
154 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
