Question about Cell Phones
What is the secret menu code for rooted Kyocera 5170
My Kyocera hydro wave C6740N started flickering with what seems like static and little lines through my whole screen.the My question is "Is there any solution to fixing my problem? No water damage
My phone malfunctioned a few weeks ago to fix it they had ...
www.fixya.com/.../t26009599-phone_malfunctioned_few_weeks_ago_fi...
2 hours ago - my Kyocera hydro wave C6740N started flickering with what seems like static and little lines through my whole screen.the My question is "Is ...
Kyocera hydro system recovery? ' Android Forums
androidforums.com > ... > Kyocera Hydro > Root - Kyocera Hydro
Jan 2, 2015 - I rooted my hydro and installed beats audio but now my sound does ... of something like this happening... without a working recovery like CWM.Missing: flickering ‎static
Dec 16, 2015 | Kyocera Cell Phones
Tip
BenQ-Siemens secret tips
Language Menu for BenQ-Siemens mobile
English menu:
*#0001#
Deutsch menu:
*#0049#
Secret Code for BenQ
*#0606# remove sim card before
Unlock Sim:
*#0003*(secret code)#
Bonus Screen:
*12022243121
Factory settings:
Type *#9999# to reset factory settings.
on Mar 08, 2010 | Cell Phones
How to root my KYOCERA ANDROID to update MY KYOCERA ANDROID C52125
Rooting is a hacking process and you need a software that can do it for you because its a lot of coding. you need to google search it BTW if this is a contract phone or what ever it is your going to void any warrenty with it because when you root something your overwriting the android system.
Nov 26, 2014 | Cell Phones
What is qmicm on kyocera hydro vibe
QMICM is a debugging program specifically for Kyocera phones, generally used by software developers for debugging. Also QMICM is used when rooting some Kyocera phones.
Nov 25, 2014 | Kyocera Cell Phones
Forgot secret code to access restart
CLEARING THE SECRET NUMBER
If you forget the secret number, clear the secret number using the following procedure.
1 Select an item from the list below to display the secret number input screen. (For operating the on-screen
display menu, see page 17.)
• "EZ Setup", "CH Setup", "Parental CTRL" or "Reset" on the Setup menu.
• "Color System" on the Option menu.
• "Software Update" on the Digital Setup menu.
2 Press and hold both CHr and VOLk on the TV simultaneously until the message appears on the screen.
Jan 27, 2014 | Sharp LC52SB57UN LCD TV
Kyocera hydro secret codes
Hello My Dear Friend::
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Jan 04, 2013 | Cell Phones
How to unlock the bootloader for my kyocera milano so i can root it
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Sep 24, 2012 | Kyocera Milano
Ec325 on ubuntu7.1 can not connect net exit code = 16
check the permissions for /etc/ppp/pap-secrets !!!
it shold be owned by root !!!
owner : root
access : read and write
group: root
access: none
others:
access: none
Jan 07, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Cell Phones Logo
19 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
