Question about Toshiba Computers & Internet
How to test the power button on Toshiba l655d-s5050
    Master:
  • 680 Answers
Take it in and have it bench tested. If they need to make repairs they shouldnt charge you for the test of they make the repairs.
Terry
Posted on Oct 19, 2013
Laptop to HDTV
... you can probably buy a usb adapter for your computer... might try ebay
Oct 13, 2013 | Toshiba Satellite L655d-s5050 2.1ghz 3gb...
No display when turned on?
Try to turn it off, remove all power source (battery,adapter). Press and hold power button for 10-15 seconds. Power it on, tap on F2 right after you power it on, if a BIOS screen appears tap on F9 select Yes, then tap on F10 to Save and restart. If these wont work try to connect an external monitor.
Sep 20, 2013 | Toshiba Satellite L655d-s5050 2.1ghz 3gb...
Will a laptop light up an external monitor if hdd is bad?
Yes. The computer will indicate hard drive missing or load some other information even if the hard drive is missing.
Jan 15, 2013 | Toshiba Satellite L655d-s5050 2.1ghz 3gb...
The keyboard doesn't work. it does not have any fall or hit or liquid
If you are using the Windows 7 try to open Command prompt while booting the computer go to the advanced recovery option and try to open command prompt and see if the keyboard is working , if it is then load BIOS setup default and restart the computer
or else
Shut down your computer and disconnect the battery and also the Ac adapter which is connected to your laptop, and then once your computer is Off just press and hold power button for at least 15-20 sec and yes do not lift your finger from the power button Reconnect everything Battery as well as your Ac adapter, and try to see if the issue is resolved or not
Nov 28, 2012 | Toshiba Satellite L655D-S5050 Replacement...
Toshiba Satellite L655D s5050 when turn on power comes up charging light comes up disc drive works but nothing on screen and the vga port didnt work as well
Nothing on internal monitor screen, and nothing on external VGA monitor?
You have a bad graphics chipset. This = replace motherboard.
Before you rush out to buy a motherboard, let's review on how to properly connect a VGA monitor to that Toshiba Satellite L655D-s5050;
1) Laptop OFF, monitor OFF, connect the VGA monitor to the RGB port on the side of the laptop.
2) By DEFAULT, the display should show on the external VGA monitor.
DOES NOT mean it will.
No display on external VGA monitor?
Press, and hold down on the Fn key, tap ONCE on the F5 key.
(O-N-C-E. NOT repeatedly!)
Still no?
Hold the Fn key down again, and tap once more on the F5 key.
Still no?
Hold the Power On button down until the laptop turns off.
Remove the VGA cable, and all external cables/devices.
Close the laptop, turn it over on the table in front of you.
(I recommend a soft, static free cloth on the table, to prevent scratching the table, and laptop)
Remove ALL power. Remove the AC adapter (Charger), and Battery.
Remove the Memory Compartment Cover.
(Middle of laptop on bottom. Rectangular cover with three Philips head screws)
Make SURE your body is free from Static, and remove all ram memory modules. (Slot A, and Slot B, IF, there are two ram memory modules)
Handle the ram memory module by the BODY. The body is everywhere, but the gold plated contact pins on the bottom.
The body is coated with a see-through protective plastic.
Refrain from touching the gold plated contact pins.
Clean EACH gold plated contact pin with a pencil eraser.
BOTH sides.
If using a pencil eraser on the end of a pencil, and not a solid eraser, refrain from letting the metal band contact the gold plated contact pins.
Just rub up, and down on each pin.
When finished use air to remove the eraser dust. You can use a can of compressed air for computers if available, or air pressure from your mouth will be sufficient.
Reinstall just one ram memory module, (If you have two), in Slot A.
Make SURE it is in Slot A. The Processor reads Slot A first. If no ram memory module is in Slot A, the laptop will not work.
Put the Memory Compartment Cover back on.
Reinstall the Battery. Turn the laptop over, and open it back up.
Plug the AC adapter (Charger) in.
WAIT 1 minute, turn the laptop on. Still no?
Turn the laptop off, and attach the external VGA monitor again.
Try it. (Don't forget you may have to use the Display Toggle-Over key)
Still no?
I suggest the graphics chipset is bad. Motherboard replacement.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 23, 2012 | Toshiba Satellite L655d-s5050 2.1ghz 3gb...
Hard disk not detected i'm using toshiba satellite L655D-S5050 windows 7.
Please provide enough information regarding your problem. The system fails to detect the HDD due to so many reasons like dropping the laptop, viruses or loose connections to the motherboard or anything around that. A detailed information about your problem will probably help me to provide the solution.
Aug 09, 2011 | Acer Aspire One PC Notebook
I have a toshiba satellitr L655D-S5050 and when I try to use my web cam it says locked out by another app. ??
Goto Run-> MSCONFIG-> in startup tab -> Diable all applicaitons except antivirus. then restart the system and check the fucntionality of webcam.
Even the problem not solved please right click on the task bar, Goto TASK MANAGER. please close the application related to webcam or any application related to webcam .
I hope it might help you.
Jun 16, 2011 | Toshiba Computers & Internet
The sound on my toshiba satellite l655d-s5050 laptop has stopped working i have updated drivers and all those shenanigans but it still didnt resolve the issue
Go to control panel and look for sound and devices and check what sound device is selected in properties. select the installed sound card and check the SHOW VOLUME CONTROL ON TASK BAR... try it
Nov 26, 2010 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
