I have a JustCom USB Cable KVM & Audio adapter, model number JC-102CUA. I want to be able to use this to view 2 monitors at the same time. One monitor would be my desktop monitor, the other is my tv. The tv is a Samsung smart tv. Right now, I can hook it up to view one or the other but not both at the same time. I do not have a manual. I do not know how to post pics on here, but I'll attempt to describe the JustCom cable. It has a main section (box-like) with a monitor input, speaker & mic input and 2 USB inputs; their are 2 cables coming off this (A & B) each one has a monitor output, a USB output & a mic output and a speaker output. I have the JustCom monitor cable hooked into the PC monitor port, I have the JustCom "B" monitor cable hooked into the PC monitor & "A" into the tv. If I hook the JustCom "A" USB cable to the PC then the tv works (I can use it as the PC monitor) or if I hook the JustCom "B" USB cable to the PC then the PC monitor works. I want to have both monitors (tv & PC monitor)working at the same time, (both showing me the PC destktop). Is this possible? How do I do it?
MrBob84
  • 90 Answers
SOURCE: No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
Posted on Feb 13, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Motorola DCT 6200/1000 seems to only have one audio output?
There are three options:
1) Connect the Tivo using the coax output of the cable box into the cable input of the Tivo
2) Exchange cable boxes with your cable provider for one with composite output jacks. It may require you to use a Motorola box that isn't High def depending on what your provider has. I know Comcast has a Motorola HD tuner that has composite outputs as well as component.
3) Upgrade to a Series 3 Tivo. Those units are designed for High Def. Use HDMI cable hookup.
Posted on Jan 17, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Posted on Mar 01, 2009
Testimonial: "Thank you. I forgot to thank you when I first read this response. Works fine now though :)"
SOURCE: GCS632U - Speaker issues
The only solution for great quality is to spend $150 more and purchase the higher end "Harmony" IO-Gear KVM switch, this works great! But if you don't want to spend that much, this is what I did with my IO-Gear GCS632U. I did RMA the first one and when the second worked the same way I realized I would have to live with it since I didn't have more to spend at the time! The video quality is terrible at high resolutions with this KVM, no MATTER WHAT!!! Playing with refresh rates helped a little, but I still saw some ghosting and interferance at times (most likely due to the lack of ferrite beads on the ends of the already "too small to carry a good signal" video cables), otherwise it looks and works great with resolutions under 1280x1024. The sound also suffers, obviously but I found out (using a multimeter) that the sound issue is due to the KVM unit trying to amplify the sound a little so to solve it I simply turned sound down in windows and increased the volume on my speakers until it sounded ok (if this doesn't work for you, try it vice versa).
Hope that helps!
Posted on May 14, 2009
  • 64 Answers
SOURCE: My Samsung 913t says "Check Signal Cable." HELP PLEASE!!!
Cheap CRT monitors can be picked up at Thrift Stores, quick and cheap way to test your computer output.
Posted on Sep 22, 2009
Have both computers connected but only have acces to one why
replace your cables replug them.if not solve then replace them or re configure the settings or drivers
May 02, 2010 | JustCom jc-102cp 2-port KVM Switch
Justcom kvm switch with audio?
Scroll Lock - Scroll Lock - F1 for first PC
Scroll Lock - Scroll Lock - F2 for second PC
Dec 15, 2009 | JustCom JC-102CPA KVM Switch
I have a justcom jc102cpa kvm switch and I need the hotkeys
KVM <====> Keyboard, Video, Mouse
Note that 'AUDIO' is not part of the "KVM" switching feature.
Dec 11, 2009 | JustCom JC-102CPA KVM Switch
Lost the directions, need the hotkeys information.
I would go to the manufactor website and do a search for hotkeys on there website.
Nov 21, 2009 | JustCom JC-102CPA KVM Switch
Jc102cp lost manual what is the key combination to switch between computers
Scroll Lock / Scroll Lock / Up Arrow switches to next (2nd) computer. Also, Down Arrow.
Jul 12, 2009 | JustCom jc-102cp 2-port KVM Switch
KVM 2 PORT SWITCH
Yes try uninstaling the kvm switch reboot pc's install the kvm again and try another key and see if that works
Jan 29, 2008 | JustCom jc-102cp 2-port KVM Switch
What's the deal?
Is it possible that there is a problem with the button? Try wiping them down with a damp paper towel or blasting it with canned air. Also, most of the time KVM's have a keyboard shortcut that will change the input also, perhaps give that a try.
Jan 07, 2007 | JustCom JC-102CUA (JC102CUA) KVM Switch
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
