Question about Stoves Cooktops
I need a manual for a Westinghouse PGH658 kitchen stove
How do I clean under the electric elements on my basic westinghouse stove
Hello friend, thanks for your post!
I understand that you would like to clean under the cooktop on your Frigidaire range. Could you provide me with your model number please? You can locate the serial tag (which lists your model number) on the storage drawer on the right hand side. With this information I can better assist you. -Matt
Sep 16, 2014 | Electrolux White Westinghouse Stove Range...
Kitchen aid cooktop got wet wont ignight?
Usually Spark Switches might get shorted out or spark module went bad, but first unplug your stove and let it sit for a while (1-2 days) then try it again, if still nothing, then You will need to open up stove to check. Here is the video I made. Screws would not come off, so i had to replace almost all components on it. Hope It Helps.
May 28, 2014 | KitchenAid KFGU766VSS Cooktop
Can you advise me on gas connections needed and how to fit connections
I think you are better off going to a Home Depot or Lowes or a plumbing supply house and ask for a gas stove hook-up kit. Then you ask all the questions you need, and ask questions over until you have a good knowledge of what to do and how to do it. There is a great safety factor here, so you need to be clear on how to do the hook up. You can take some pictures of the gas line and of the stove hook up pipe. If you do not have a gas line coming into the kitchen for the stove hook up, then get a qualified technician to install the gas feed.
May 26, 2014 | Cooktops
I have a new viking stove slide in electric top range that was installed in our kitchen with existing granite counter tops. But there seems to be a small gap between the stove and the counter. My previous...
If you are talking about a gap caused by the height of the stove, You can lower the height of the stove by adjusting the threaded leg posts on the bottom of the stove. A more difficult fix would be in raise the height of the countertop and cabinets by shimming the bottom of the cabinets.
If your gap is not a height issue, then you can experiment with some type of trim around the stove itself. Local granite dealers has an assortment of trims for issues like this.
I was able to find a number of trims for a back gap on my granite countertops and backsplash from my local European Marble and Granite.
Mar 15, 2013 | Cooktops
Westinghouse freestyle 521 stove ceramic top.elements wont turn down no matter where switch is. burns food. Have used different size pans etc,
there is a problem with either the elements or the controls,i doubt it is the elements as its unlikely that all of them are faulty at once.the control knobs or control panel is more likely the problem.
May 29, 2010 | Cooktops
Gaggenau Cook-top VG 352-812 problems
Hi, interesting. I have the same units on my GasHob and my problems are exactly reverse. To turn the burners on it takes about 15 clicks and with some luck you'll get gas! Sorry, wished I could help.
Claus.
Jun 08, 2008 | Cooktops
Kelvinator stove
The stove has its own sepeate circuit breaker and power supply from the rest of the kitchen. Possible issues are a bad circuit breaker, power cord, outlet, or power connection at the range. Easiest checks to make first are visual burns at all these places.
Apr 07, 2008 | Cooktops
Cooktops Logo
67 people viewed this question
Top Stoves Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Stoves Cooktop Expert? Answer questions, earn points and help others
