Question about Atwood Mobile Products Atwood Water Heater Ignition Control Module Circuit Board 93865 - 93865
Atwood water heater g6a8e lights but flame goes out after 5 to 10 seconds. I replaced igniter / thermocouple and it worked for a while but problem is back. So I need to replace circuit board?
  • Atwood Mobil... Master
  • 6,674 Answers
Make sure you pull connector off and clean it and contacts on board. Be sure igniter is in flame good too. Does it have the thermal cut off in-line? Its the little resistor looking piece inside the plastic cover. If it does, and still running a few seconds and going out, remove it from the circuit, and connect wire end to where you removed cut out from, thus eliminating it from the circuit, and test it. If that cures it, replace that cut-out, as it is a safety device in case of flame up, it cuts gas off to prevent fire. Just leave it out long enough to test it.
Posted on Mar 23, 2014
    Top Expert:
  • 8,177 Answers
Make sure blue flame if orange clean burner tube and flame sensor the flame sensor is connected to the ignitor
Posted on Nov 25, 2017
Pilot will light after 30 seconds when you try to move knob to on position the pilot goes out and heater won't ignite.
You need to replace the thermocouple.
When you light the pilot it is supose to heat the thermocouple.
the thermocouple produces a small electric current which allows the gas valve to open and keep the pilot going. and allowing the main burner to come on.
Jun 21, 2011 | RTO Atwood Water Heater - 6 Gal LP
I have an Atwood 6 Gallon (model-G6A-7) water heater in my travel trailer. My pilot wont stay lit, but looks strong, I've changed the thermocouple but still have the same problem. It goes out once the...
Make sure flame is good under thermocouple probe so that it gets proper sensing of flame, and if that's o.k., before you change gas control, remove thermocouple fitting where it attaches to gas control and spray wd-40 in the hole and twirl up some steel wool and push it in the hole and twirl it to try and clean the surface inside there as well. Then spray it out with WD-40 once more to flush out shavings etc, and if you have compressed air, blow it out as well. Now re-attach fitting and snug it, then re-try pilot again. If it works, great if not replace gas control. Let me know the results. You do realize that it should be a certified technician who changes that gas control if necessary, correct?
Jan 06, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
Atwood gas waterheater with white rodgers gas valve pilot hard to light and not a big enough flame to touch the thermocouple
I think you need to reposition the thermocouple, or adjust the pilot gas pressure by adjusting the pilot screw make sure it is still the recommended gas pressure of the system... please contact a HVAC tech if this things did not work.
Aug 18, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
The pilot on My atwood water heater will not stay lit after I release the knob. I have replaced the thermocouple and have a nice blue flame.
Did you make sure the connection between the thermocouple and the control is tight and that the tip of the thermocouple is in the flame?
Jun 28, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have an Atwood 6gal hot water heater with a 37c14u-5 controller. The pilot light will not stay lit. I have replaced the thermal coupler twice and the pilot tube with orfice once. It's still not...
Try removing the thermocouple where it attaches to gas control, and spray a little WD-40 in the hole, then spin a rolled up small piece of steel wool in the hole as well, then blow it out with compressed air if you can. Then reconnect thermocouple. Make sure thermocouple tip is getting good flame under it, and if that doesn't cure it, then it's time to replace gas control.
Jun 23, 2010 | RTO Atwood Water Heater - 6 Gal LP
Atwood GC6AA-9E water heater isnt working properly
The ignitor is also a flame sensor. If it's not working to ignite, good chance it's not sensing flame to keep gas flowing as well. Could also be board.
Sep 09, 2009 | RTO Atwood Water Heater - 6 Gal LP
Atwood Mobile Products Atwood Water Heater Ignition Control Module Circuit Board 93865 - 93865 Logo
107 people viewed this question
Top Atwood Mobile Products Water Heaters Experts
Paul Carew
Gil Shultz
Are you an Atwood Mobile Products Water Heater Expert? Answer questions, earn points and help others
