Question about Haier Refrigerators
My Haier HNSE05-RBG just quit cooling. Acts like it is low on coolant. Motor does not kick in.
    Sergeant:
  • 304 Answers
Check your relay if your compressor is not kicking on
Posted on Oct 19, 2013
4 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: Haier HNSE05 shuts off on it's own.
Sounds like the thermostat is bad which is temp. dial.
Posted on Oct 06, 2007
  • 306 Answers
SOURCE: not cooling, compressor kicks in for 3 seconds then back out
No the PTC relay on the compressor is bad. Need to replace it.
First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Posted on Apr 05, 2009
  • 1156 Answers
SOURCE: Haier frig., model HNSE05, continues
Hi,there
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Hope this help out....
Posted on May 07, 2011
Relay keeps kicking in and out
take everything out and defrost it for a day with doors open if you can
cleaning up the coolong fins on the bottem of it 2
Nov 01, 2012 | Haier HNSE05 4.6 Cu. Ft. Refrigerator...
Fans only kick on when I run my ac. I replace my coolant sensor still nothing. I have checked the fuses. Where do i go from here?
Sounds like this may be a faulty fan motor, the low speed in these fan assemblys go bad, but the hi speed works when the a/c is turned on. I would check for the cooling fan relay first... you can usually switch this relay with another relay of the same and see if that makes the fan kick on, if it doesn't then i would go with replacing the electric cooling fan motor. Hope this helps
Oct 27, 2012 | 1998 Plymouth Voyager
A/c dosnt cool
it does sound like the coolant leval is low does the compressor kick in and out very quickly if it does it is low if it dosen't engage you may have a leak in the system or it maybe a bad relay or fuse see if it work partially then recharge if it dose
Jun 30, 2012 | Chevrolet Silverado 2500HD Cars & Trucks
My cadi 1988 is running ruff and quit running feels like over heating but no leaks, just smells
REPLACE THERMOSTAT AND RADIATOR PRESSURE CAP.MAKE SURE COOLANT NOT LOW.IF ALL IS GOOD CHECK FOR LEAKING WATER PUMP WEEP HOLE IF LEAKING REPLACE WATER PUMP.MAKE SURE COOLING FANS RUNNING.IF ENGINE RUNNING HOT WHILE SITTING LONG TRAFFIC LINE AND COOLANT NOT RUNNING.CHECK COOLANT FAN RELAYS AND FUSE.IF ALL IS GOOD HOT WIRE MAKE SURE COOLING FAN MOTOR GOOD IF COOLING FAN DONT RUN WHEN HOT WIRED FAN MOTOR BAD.IF FAN MOTOR OKAY AND FUSE RELAYS GOOD YOU HAVE FAULTY COOLING FAN WIRING.YOU COULD HAVE BAD ENGINE COOLANT SENSOR OR FAULT IN ECM CODE SCAN TO CHECK THEM BOTH.CHECK ENGINE OIL.LOOK LIKE MILK SHAKE YOU HAVE LEAKING HEAD GASKET.IF OIL LOOKS OKAY.YOUR ENGINE BLOCK, RADIATOR AND HEATER CORE NEED FLUSHING.
Sep 20, 2011 | 1988 Cadillac Sedan DeVille
Haier frig., model HNSE05, continues to cool till all contents are frozen. Can not reduce temperature to aceptable levels.
Hi,there
May 07, 2011 | Haier Refrigerators
The cooling fan on my 2001 ford escort SE will not work normally
Check the coolant temperature with the car stopped. At idle with the hood up keep the thermometer in the coolant. Confirm if the coolant is not overheating but the engine is!!
Run the A/C keeping the thermometer in the coolant and allow the fan to kick on.
If with the A/C on the engine doesn't overheat then it confirms that the low speed on the fan motor is not working. Read the description of the Taurus where the low speed is used for normal operation when temperature is required but the high speed is activated when the A/C is on. The circuit is simple.
In your case the low speed has to be activated for the A/C to go into the high speed. The fact that the high speed is working and low speed is not indicates the low speed of the fan is defective.
Other problems such as the thermostat or plugged cooling system(radiator clogged) could be the root problem!
Hope this helps?
Jun 24, 2017 | Ford Escort Cars & Trucks
Won't "kick" on
need a little clarification but will try to answer....if the fan is not spinning or no air is coming out, then try taking off the front cover and spinning the fan by hand (With unit unplugged). it should spin freely and not feel rough or stop suddenly. if so the fan motor is bad. now if the fan motor works but the air does not cool then the compressor is not turning on in which case either 1. you are too low on freon (leak), 2. the compressor has gone bad, or 3. there is a wiring problem or bad run capacitor. i find it odd that this would happen to 2 units over the same storage period, any out-of-the ordinary environmental situations there? water damage? it could simply be a wiring short also.
Jun 09, 2009 | Haier ESA306 Air Conditioner
Sep 19, 2007 | Haier HNSE05 Refrigerator With Ice Box
Refrigerators Logo
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
