Question about Denon DN-HC1000S Sub Controller
Denon dnhc1000s not working
It doesn't come on at all or light up
Only red light is blinking on my denon avr 1508
It sounds like you overloaded the Denon avr with too much resistence from the speakers. Please check the total resistence of the speakers before you connect them all. Also check that the speakers or their wires are not shorted!
Jan 20, 2013 | Denon Audio Players & Recorders
Apple tv doesn't work when hooked up to denon 2311 receiver. Apple tv is turned on but tv screen displays the word
http://usa.denon.com/documentmaster/us/avr-2311ci_lit527.pdf
This is the link to the probable box in question. The Apple TV needs to be connected to HDMI input port (pick on of the six available). Follow setup instructions.
Jun 08, 2012 | Audio Players & Recorders
Doesn't power up
Check the speaker wires for shorts, if okay! the audio output stage is shorted, all affected parts will need to be replaced.
Apr 11, 2012 | Denon DRA397 XM Radio Receiver
I am a comercial electrician. My company installed 2 Denon recievers on a job and 1 has gone dead. There is power to the unit but no power to the recepticals on the back. Is there a reset or a fuse?
Are they "switched" recepticles? I believe they are but, the picture I'm looking at is too small. This is the manual for the unit;
http://usa.denon.com/DocumentMaster/US/DRA-397-OM-E_103.pdf
This is the link:
http://usa.denon.com/US/Product/Pages/Product-Detail.aspx?Catid=3ae4a4d9-ae28-4018-bb66-611b99e1320d&SubId=0&ProductId=8e00bd6c-d3e2-466f-b5a0-c7ebe94e0bd9
Just glancing at the manual, of course it doesn't mention a fuse but, I'm quite syre if you pull off the cover, there is a fuse or two on the circuit board. Anyway, I wasn't trying to be smart about the "switched receticles and, you probably already knew but, if they are switched recepticles, they will only work when the unit is turned on.
Jun 06, 2011 | Denon DRA-397
Hi, I have a denon AVR 889 about 4 years old and the subwoofer suddenly stopped working,how can i check if its the amp or the sub thats the problem?
A Denon AVR 889 is not a sub so we don't know anything about the sub in question.
Maybe the existence of the sub is no longer set in the AVR. Look at the speaker definitions first before going to wild.
Try another cable to the sub.
OR, run the sub's signal supply cable to one of the Tape Outs on the receiver and tune in something on FM. If that works a) it will be loud, and b) go back to the SUB settings on the AVR.
Crack the sub open and access the terminals on the speaker itself. Disconnect them from internal components and run one of your amp channels directly to it. If it works, the amp or signal path are dead. If it doesn't work, it's a dead driver.
May 19, 2011 | Denon AVR-889 Receiver
Its working only in direct & stereo mode
maybe you need to replace a fuse?
is it hooked up correctly
Apr 23, 2009 | Denon AVR-1508 Receiver
No dish network sound through denon 1609 receiver
check the setting for the HDMI connection at the Denon you may have to assign the HDMI audio setting also on the front of the Denon while in the DVR mode press the input mode button on the front of the Denon to select auto and if that doesn;t give you sound you will have to connect a cable from the DVR optical.coaxial or analog audio output to the Denon and setup for that type of audio connection
Jan 19, 2009 | Denon AVR588 Receiver
Denon RC 969 Remote .Not Lighting up anymore ?.
These remotes are known to be weak, Denon is aware of the problem, here in the Netherlands they've sold out. Spare part no longer available. Try an older remote to an Denon AVR. these will work for say, 98% and are more reliable.
Nov 28, 2008 | Denon AVR-3805 Receiver
Denon DN-HC1000S Sub Controller Logo
Top Denon Computers & Internet Experts
David Payne
David Payne
Are you a Denon Computer and Internet Expert? Answer questions, earn points and help others
