Question about Hitachi P50H401 50 in. Plasma HDTV
Replacing capacitors I replaced the capacitors but now the tv is not getting power, it will not turn on at all. No lights or anything.
  • 3 Answers
Check upper and lower buffer boards for blown chips
Posted on Jan 16, 2014
LT-46133 FLICKERING BLUE LIGHT
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 18, 2012 | Mitsubishi LT-46133 46 in. HDTV-Ready LCD...
My samsung tv model number ln40a55op3f 8. havin troubles getting it to turn on...it wont turn on for like five min, then it will just keep turnin itself on and off until we unplug it...you never see...
The tv have a dying power supply board,that the board where the tv power a/c cord plug into it.U have all the tools and the understanding of basic electronic and also can do basic soldering works too?Yes,take all the Philip screws out of the tv backcover,take the tv aparts and now check the tv power supply board carefully for dying and soon to be dead components parts that are call capacitors.These dying and soon to be dead components capacitors parts are alway bulges up or puffing up onto it tops.These capacitors components parts are dying and soon to be dead must be all to be replaced.After u replacing all the defective capacitors components parts.Now the tv power supply board will be fixed and working correctly again and the tv will not have anymore power delaying like about 5 mins. or flashing LED power light indication,require unplug,replug again awhile before it will turn on.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Jul 15, 2011 | Samsung LN40A550 LCD TV
We have a 46 inch sharp tv model number 46SB54U won't turn on. The green timer light is flashing. We just replaced the power supply board thinking that was the problem. TV still won't turn on...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will helpout ......
Jun 25, 2011 | Sharp LC46SB54U 46 in. LCD TV
My 50" samsung projection tv
Your power supply board is dead, you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem.....
May 13, 2011 | Samsung PCJ522R 52" Rear Projection...
TV Turns itself off with power light flashing
It is broken capacitors. Olevia used cheap quality capacitors for this model. Open up the back cover and examine the capacitors on the board closely. You will find a lot of capacitors oozing capacitors.
May 11, 2010 | Olevia 237T 37 in. LCD TV
TV just turned off while watching. standby light flickering red 7
Ur power board have dead capacitors.U Know how to solders?Take the tv aparts,check these capacitors in the power board for dead capcitors like puff up or burst open.Replaced these capacitors to get power back.Or buy and replaced the whole reburbish power board at Shopjimmy.com,Ebay.com.
Jan 21, 2010 | Televison & Video
TV wont turn on at all. I have read alot of forum posts about the capacitors. I took off back of TV and nothing appears to be out of order with capacitors or anything in power supply. I am not gettting...
I had the same problem. The power supply had a bad capacitor on the 5.3V output. The value of the cap is 2200uF / 10V. The top of the cap was swelled. With the cap changed the TV now turns on again. I hope this helps.
Jan 03, 2010 | Samsung LN32A330 32 in. LCD TV
Philips T.V. turning off, when blinking red light won't turn on
at power supply, filter capacitor, indication bulk,should be replaced..note:little knowledge is dangerous, so if you wish to do it yourself an sop here. 1unplug the unit,2discharge the current in the large capacitor, now you can do the replacement...polarities also, should be observed....
Dec 31, 2009 | Philips 42PFL5603D - 42 IN. LCD HDTV
19 code
Do this first please.
Replace capacaitors in power supply area
Replace capacitor cp150 (2200mf 16v, ) capacitor CP120 and capacitor cp112
Replace this capacitor too: CP114 (330uf @ 35V ). Upgrade to 35 V all capacitors.
For me is a power supply.
I will be here for any questions.
Thank you
Jul 31, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
SVA HD4208 42INCH Plasma will not turn on. Hi! My TV will not turn on. I have a red light lite up by the remote control sensor. When I hit the power button on the remote the red light blinks. Then I hear a...
The issue with these TV's are the boards internally go bad, for Power the three capacitors get round at the top and either you replace the whole board from SVA fro 300.00 or buy three capacitors and replace them
May 05, 2007 | SVA-USA HD4208TIII-VR 42 in. Plasma...
Hitachi P50H401 50 in. Plasma HDTV Logo
57 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
