Question about Garden
20 yr old husky 359 seized it's piston. I replaced piston and cylinder and didn't have any parts left over :-). Now it won't start. I have spark and getting fuel to carb (took off hose to carb and laid saw on side, fuel flowed out the tube). Even a whiff if starting fluid did no good. It seems to pull nicely so I'm sure there's compression. Ideas?
  • Bill
    Bill Oct 19, 2013
    Thanks Steve, i just replied to you but i don't know where it went. I didn't split the case. Could taht still be a problem? Where are these seals?
  • 181 Answers
Check the crank case seals. One may have come out and its not getting fuel.
Posted on Oct 19, 2013
  • steve
    steve Oct 19, 2013
    the seals are under the flywheel and under the clutch. When you say it pulls over nice, does that mean it's easy to pull, or is there some tightness in the pull. For good compression,the saw should be able to be hung from the recoil. It should drop very slowly if the compression is right.
  • 398 Answers
SOURCE: 353 husqvarna chain saw won't start.
did you try adjusting the throttle cable? does it start at all then die ?
Posted on Feb 27, 2009
  • 83 Answers
SOURCE: 46 cc Sears/Poulan chainsaw will not start
Four things I can think of:
1) There is a short in your spark plug wire. When you bend it to connect the plug in the machine it allows the exposed cable to contact the engine block. Examine the wire all the way to the coil.
2) Flywheel key is sheared ( you obviously know how to take off the flywheel since you checked the seals).
3) Flywheel air gap is not set correctly. Loosen the coil. Put the cover of a notebook or the cardboard piece of a cigarette pack between the magnetic portion of the flywheel and the coil. Tighten the coil down. This will get you the proper gap.
4) Your cylinder/piston or rings are scrubbed out. Even though it passed a compression test, on rare occasions it will loose compression only when it fires. So do the following:
Remove your exhaust manifold. Look into the cylinder with a flash light. You are looking for scratches. Anything larger then a light fingernail is definite proof you need a new cylinder/piston assy.
If it passes that test do the following:
Pour mixed fuel straight into your cylinder until 1/4 full. Slowly pull your saw over while looking into the cylinder. If you see bubbles after the ring/rings go by then you need a new cylinder/piston assy. On rare occasions if no scratches are present on the cylinder wall or piston, you may be able to change just the rings.
First if you can get a inline spark tester so you can see if your getting spark with the plug installed.
Posted on Mar 31, 2009
SOURCE: I have a husky 142 lent it to a buddy came back
The piston on a 142 looks a little scored normally on the exhaust side. There could be several things. Make sure the fuel line has no holes and isn't pinched and the fuel filter isn't stopped up. Pour some gas in the carb to make sure it will run. If it don't the piston is shot or you some how got a bad plug. Take the plug out and stick it against the cylinder and see if you see any spark. Maybe if it don't start with gas poured in the carb bad ignition module.
Posted on Apr 26, 2009
  • 4088 Answers
SOURCE: poulan saw wont start has spark and fuel
Look for a pinched/bare stop-switch wire (I assume that you don't have spark now). Also, check the ignition coil core gap to the flywheel magnets (I use card stock to set the gap). Make sure the plug wire was not damaged again.
Posted on Sep 01, 2009
SOURCE: What should compression be on husky 359?
This saw needs aproxamitly 150 psi. Any less than 120 and you will have problems with the saw breaking up at high rpm and stalling under load. Pop the muffler off and take a peek at the piston and the cylinder walls for scoring. If its scored it will need a new jug and piston, the kit from Husqvarna, includes everything you will need, should run from $175.00 to $200.00. Hit us up on eBay MorganPower is our user name. http://www.morganpower.com/ is our website. Or you can email me at ebay@morganpower.com
Hope this helps, feel free to email me with any other questions, we are a Husqvarna dealer/repair center and can help you out with that saw. It is a great saw all the features of the XP line at a fraction of the cost. It has the 3 piece crank and magnesium case. It is definitely worth putting the money into this saw!
-Steve
Posted on Sep 12, 2009
A 359 husky. What is the size engine in mm.? Do they make a cylinder, piston kit that Inc gaskets. YEARS IN PRODUCTION?
2001 thru 2011
aprox 47mm
Piston and Cylinder kits from Husky do not include gaskets, but can be purchased individually.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Dec 04, 2016 | Husqvarna Garden
Won't start ; i have spark, fuel
It takes 3 things for an internal combustion engine to run... compression, spark, and fuel.
First perform a compression test. If its under 90psi the compression is too low and it would cost more to repair than to replace.
Sidenote: A unit that is extremely flooded will give a false low compression reading. Remove the spark plug, turn unit upside down so that spark plug hole is facing down and slowly pull the starter rope. If fuel drips out then the crankcase is flooded with fuel.
Next, be sure that your fuel is fresh and free of water. If the fuel is more than 20 days old it is stale.
Also, holding the spark plug against the head is not an accurate test for spark. A failed spark plug or weak module will fire when not under a load but will not fire when in the cylinder environment under compression. A spark tester is the best way to know for sure that you have a good strong spark.
Lastly, something you can do which requires no special tools is check the condition of the cylinder/ piston. Remove the spark plug then remove the muffler and look into the cylinder. You can pull the starter rope slowly to move the piston up and down. Observe the wall of the cylinder and the side of the piston. They should be smooth and shiny. A dull grey appearence indicates debris ingestion, grooves ( also called scoring) indicate metal to metal contact caused by a break down of the oil due to heat or lack of oil. The presence of scoring means that the unit is not cost effective to repair and should be replaced. Dull grey usually means low compression too.
Oct 08, 2012 | Homelite 30cc Piston Cylinder Kit Assy...
I put a new barrel and piston in my 288 and it seized
Have you used a geunine OEM cylinder and piston. Cheeper aftermarket parts are a waste of money.
Mar 21, 2012 | Husqvarna Garden
Piston seizure in Husky 359 chain saw-how to remove old top end, evaluate damage and install new piston and ring or all new top end.
Probably going to be a paired piston&cylinder http://www.ebay.com/itm/HUSQVARNA-359-357-CYLINDER-AND-PISTON-KIT-47MM-/140580138020
you will need to replace both.. remove your muffler and see scorched(black streaks) piston, fused rings. Remove air filter and carb to see scored cylinder wall(on hot side)
Aug 23, 2010 | Husqvarna Chain Saw 20" Bar
HOW DO I REMOVE THE CHAINDRIVE CLUCH ON A 359 SAW
My 359 has 3 detents rather than 2 but other than that is like the video.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If you need them, part numbers for Husqvarna and Oregon rim sprockets can be found below.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 27, 2010 | Husqvarna Chain Saw 20" Bar
How do I remove the clutch assembly on my 359 chain saw
Hello ****;
HusqvarnaUSA.com
06 1500198
Lou
Mar 15, 2010 | Husqvarna Chain Saw 20" Bar
Every time I cut more than 20 mins it wants to stall and then doesn't want to start again...I cleaned the air filter incase i was overheating (which it does) and still a problem. Now it is cold and just...
You don't give us a model or serial number, nor the age of your saw. Has it ever been tuned by a chainsaw mechanic? A tune up replaces the spark plug and a few other items. It includes a visual inspection and perhaps a pressure test or two. The final thing is to adjust the carburetor for better operation. My Husky 359 gets tuned about every 3 years by the local Stihl dealer at a cost of $40. I have a Husky dealer closer to me but I prefer the Stihl mechanics.
Heat is an indication your saw may be lean, in extreme cases it causes metal transfer from the piston to the cylinder wall and can destroy your saw. It should always be operated with a clean air filter.
The one thing you might try is once your saw attempts to stall is to rotate it enough to loosen the fuel cap. If it smooths out your fuel vent is plugged.
You can find an Operator's Manual and IPL here:
HusqvarnaUSA.com
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
I'm concerned about the heat, If my saw the local Stihl dealer would have it. Explain the problem you are having it may aid in repair or diagnosis.
HTH
Lou
Nov 07, 2009 | Husqvarna Chain Saw 20" Bar
Won't start after running on straight gas
Parts of the piston are probably adhered to the cylinder wall.
· Remove the spark plug wire and plug.
· Remove the muffler, hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears?
· Pull the starter slowly, inspect the piston as it rises and falls. Is it a dull gray without scratches and gouges?
· Hold the light at the exhaust port and look through the spark plug hole, inspect the cylinder above the exhaust port. Is it shiny and smooth or speckled with gray spots or smears?
Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by the independent saw shop should be considered.
Bailey's.com
http://www.baileysonline.com/category.asp?catID=258
P&C kits for Huskys range from $100 to 350±. GL
Lou
Oct 25, 2009 | Husqvarna Chain Saw 20" Bar
Garden Logo
143 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
