Question about Kenmore Refrigerators
Received error code f1 - Kenmore Refrigerators
    Sergeant:
  • 308 Answers
Er1F code is for refrigerators made by lg but sold under the sears name ken more. Your ice fan is frozen up and not blown air to the ice maker
Posted on Oct 19, 2013
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    What foes Error code f1 mean?
    Error Code Definition
    • According to Appliance Parts Quick, the error code is defined as a "Primary Control Failure." This means that the small computer installed in the washer has failed to send, receive or communicate with any other part of the washer.
    Reset the Code
    • To stop the flashing and beeps on the washer, hold down the "Start" and " Stop" buttons for 60 seconds. If this does not work, unplug the washer for 30 seconds and plug it back it or leave it unplugged since it is inoperable.
    Parts
    • The main problem is with the machine control assembly. This whole part needs to be replaced. Depending on your model, prices range from $150 to $260, as of 2011.
    Process
    • The installation of the new machine control assembly, requires manual installation and opening the washer itself. If you have never taken apart or repaired a washer, a professional should provide the service and care. Contact Whirlpool support for more information on repairs and warranty.
    Read more : http://www.ehow.com/info_7936847_whirlpool-washers-error-code-f1.html
    F1 means the central electrical control unit, i.e. the onboard computer, has fatally failed. Unless you have both the skill and tools to test the guts of this computer, you're stuck replacing it. Good news, three screws at the rear to expose the control panel, then unplug one unit; plug in the new one. Just to be on the safe side, color code all the plugs and receptacles. At wholesale, the part is $175.00. CODE 083009 part W10189966 CNTRL-ELEC
    Read more: http://forum.appliancepartspros.com/washer-repair/10337-whirlpool-f1-code.html#ixzz3dvEIxJdx
    http://forum.appliancepartspros.com http://forum.appliancepartspros.com/washer-repair/10337-whirlpool-f1-code.html#ixzz3dvEIxJdx
    Jun 19, 2015 | Kenmore Washing Machines
    What does it mean for screen to flash f1
    Hello friend, thanks for your post!
    From my understanding your Frigidaire range is displaying an "F1" error code. "F1" typically means that your wall oven has detected an issue with the runaway temperature (overheating). Sometimes resetting your appliance can correct this issue but in the case that it does not and you still receive that error code I would recommend having a professional come out to properly diagnose and repair. At that time you could be having an issue within RTD (Resistance Temperature Detector) sensor probe or the EOC (Electronic Oven Control) having a professional come out would reduce the cost of unnecessary parts. Hopefully this has been helpful. -Matt
    Oct 12, 2014 | Frigidaire Kitchen Ranges
    A fi error message on a fridgeaire oven
    Good Afternoon Leif, thank you for your post!
    Typically error code F1 indicates that your range has detected an issue with the runaway temperature (overheating). First, try reprogramming your range by flipping the household circuit breaker to the off position or by unplugging it. It is important to wait approximately ten minutes and then turn your range on. This often clears most false error codes. If the error code does not clear, then more than likely the RTD Probe (Resistance Temperature Detector) or the EOC (Electronic Oven Control) will need replacing. This is not a typical DIY.o connect with a local technician to determine the exact diagnosis. I hope this helps explain the error code you are receiving.
    Feb 21, 2014 | Ovens
    I have a Kenmore Elite Oasis HE (Model# 110.27086603). I receive an F1 error code after starting the machine. It takes 2 stop & starts to reset. I then receive the F1 error code again at the rinse...
    F1 Error Code
    There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure that the diagnosis is correct and the proper repair is completed.
    A) Air leaks in the air pressure switch/sensor hose.
    a. Inspect the hose for cracks, pin-holes or loose connection.
    b. Replace the hose and harness assembly (W10058730) if it is damaged.
    B) Moisture in the air pressure switch/sensor hose.
    a. Inspect the hose for evidence of water.
    b. Replace the hose and harness assembly (W10058730) if water is detected.
    C) Lint or flashing in the air dome hose connection port.
    a. Inspect the air dome hose connection port for lint or flashing. Blow through the hose to clear any lint that may be trapped in the hose.
    b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on the tub.
    D) The control board needs to be replaced.
    a. Replace the control board only after the prior steps have been performed, and not fixed the problem.
    Feb 27, 2011 | Washing Machines
    What does F1 fault code mean?
    Whirlpool Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
    2. Re-apply power and observe for at least one minute.
    3. If code re-appears, replace control board (also called ERC or clock).
    Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
    Jan 08, 2010 | Kitchen Ranges
    Whirlpool Cabrio top loading washer F1 Error
    F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
    Nov 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    KitchenAid KESS907 Electric Range E1 F1 Error Code
    F1 E1, replace Electronic Range Control.
    In other words, the controller board has failed.
    Jan 29, 2009 | KitchenAid KDRS807SSS Dual Fuel (Electric...
    Dead control panel
    No F7 or E7 in my tech sheet could it be a F1 F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad let me know thanks
    Jan 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
    Refrigerators Logo
    96 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal De
    Jim Goldsmith
    Jim Goldsmith
    oldblindman
    Level 1 Expert
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
