Question about Zonet KVM3122 2-port KVM Switch
Connecting 2 monitors using the JustCom usb cable KVM & audio cable
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 96 Answers
What is your question? or the problem?
Posted on Oct 20, 2013
  • 1 more comment
  • Jennifer Hale
    Jennifer Hale Oct 23, 2013
    Sorry, I thought I was just typing in search here. My first time on here, anyways I did put it in a question form also:
  • Jennifer Hale
    I have a JustCom USB Cable KVM & Audio adapter, model number JC-102CUA. I want to be able to use this to view 2 monitors at the same time. One monitor would be my desktop monitor, the other is my tv. The tv is a Samsung smart tv. Right now, I can hook it up to view one or the other but not both at the same time. I do not have a manual. I do not know how to post pics on here, but I'll attempt to describe the JustCom cable. It has a main section (box-like) with a monitor input, speaker & mic input and 2 USB inputs; their are 2 cables coming off this (A & B) each one has a monitor output, a USB output & a mic output and a speaker output. I have the JustCom monitor cable hooked into the PC monitor port, I have the JustCom "B" monitor cable hooked into the PC monitor & "A" into the tv. If I hook the JustCom "A" USB cable to the PC then the tv works (I can use it as the PC monitor) or if I hook the JustCom "B" USB cable to the PC then the PC monitor works. I want to have both monitors (tv & PC monitor)working at the same time, (both showing me the PC destktop). Is this possible? How do I do it?
  • Jennifer Hale
    Someone gave this cable to me, they knew nothing about it as it was given to them, I basically have no idea what can be done with it!
What is the best way to connect 2 computers to this monitor
If you have two separate computers for different purposes, such as personal and work use, you may find it convenient and necessary to connect both to a single monitor. Many monitors have dual inputs, making such a connection simple. However, you might need a keyboard, video and monitor switch to accomplish this task if the monitor lacks a second input. Dual Inputs
Step 1 Examine the back of your monitor for the presence of dual video inputs, such as a single VGA and DVI or HDMI output.
Step 2 Connect the VGA cable to one computer. Plug the other end of the cable to the matching input on the monitor. Rotate the retaining screws until tight at both ends of the cable.
Step 3 Plug the DVI or HDMI cable into the back of the second computer. Insert the other end into the monitor's digital video input. Screw down the retaining screws if you're using DVI.
Using a KVM Switch
Step 1 Ensure both computers are turned off. Place the KVM switch on your desk where it is within convenient reach.
Step 2 Locate the video output port on the back of the KVM switch. Plug a VGA cable into this port. Plug the other end of the VGA cable into the monitor.
Step 3 Plug the VGA monitor outputs from each computer into the inputs on the back of the KVM switch. Tighten the retaining screws down for each connected VGA cable on the computers and the KVM switch.
Step 4 Plug the keyboard and mouse cables into their respective outputs on the KVM switch. Plug each set of keyboard and mouse cables from their ports on each computer into the matching inputs on the KVM switch. Plug each cable in sequentially to avoid mixing them up between machines.
Step 5 Double-check that the mouse, keyboard and monitor cables leading from each computer all correspond to the right machine. Plug the KVM switch's power cord into a nearby AC outlet or power strip.
Step 6 Turn the computers and monitor on to verify the connections are correct.
Required Items
  • VGA cable
  • DVI or HDMI cable
  • KVM switch
  • Power strip (optional)
Jun 13, 2014 | Acer 22" X223w LCD Monitor
Bridgeview 2-port USB/DVI KVM Switch not seeing the Kybd
With under $30 price, the DVI KVM switch with all-in-1 cable attached is a steal if it works. However, this kind of KVM switch is based on low-end USB hub structure or emulated USB structure.
For Windows 7 or newer OS, it will cause more compatibility issues. It is not driver issue. A hardware-base KVM switch 99% of them doesn't need driver.
My suggestion to you - looking more solid KVM switch technology - DDM based KVM switch. They are more expensive but in a long run, it is a better deal.
Jan 11, 2014 | Bridgeview br-u1021da 2-port usb-dvi kvm...
Have both computers connected but only have acces to one why
replace your cables replug them.if not solve then replace them or re configure the settings or drivers
May 02, 2010 | JustCom jc-102cp 2-port KVM Switch
Justcom kvm switch with audio?
Scroll Lock - Scroll Lock - F1 for first PC
Scroll Lock - Scroll Lock - F2 for second PC
Dec 15, 2009 | JustCom JC-102CPA KVM Switch
I have a justcom jc102cpa kvm switch and I need the hotkeys
KVM <====> Keyboard, Video, Mouse
Note that 'AUDIO' is not part of the "KVM" switching feature.
Dec 11, 2009 | JustCom JC-102CPA KVM Switch
No vga by pushing port buttons
In order to fully answer your question, a number of needful things must be inspected, reinstalled, confirmed, & tested:
  1. Reset. Try the reset button. You could use a paper clip to reach the reset button through the pin hole in the lower front left of the Zonet KVM unit.
  2. Inspect connectors. Each data/input/power connector/port requires all of its pins to be present & straight for full functionality.
    1. Inspect the entire length of each cable & cord to ensure that each has no damaged area.
    2. Seat each connector in the appropriate port of a computer that will be accessed via the KVM unit.
  3. Electricity. Inspect all affected devices & confirm that each has sufficient, uninterrupted electricity.
    1. It is possible for a Zonet KVM unit to display channel lights without direct power to the unit, but you should confirm that the unit is getting sufficient, uninterrupted electricity-directly through its own power cord. Unplug the KVM power cord & every connector & reseat each one (this performs a power reset on the KVM unit)-making sure that each connector is in the correct location (not just where it originally was). Thus, make sure that the keyboard, video display (monitor), & mouse are on the output side.
    2. Press the power button on your monitor. If it does not turn off the monitor's power status light (Off/On/Standby), then remove the power cord from the monitor & reseat it-to reset the monitor's hardware. If it does not turn on the monitor's power status light, then the monitor is either not getting enough electricity or it has a malfunction which requires troubleshooting & fixing (possibly through a fixya.com thread for that monitor model).
    3. Unlike USB devices, PS/2 devices usually require device connection prior to turning on that device. With that said, connect the keyboard & mouse KVM channel cable connectors to the computers & then turn on those computers that you intend to display through the KVM-connected monitor & then turn on these computers.
    4. Any computer that does not turn on has an issue that requires resolving (just like a monitor that would not turn on).
    5. Sometimes a keyboard/mouse interface issue can be resolved by replacing that interface device.
  4. The KVM Unit. When all else properly connects & performs, what does not properly connect & perform has the issue &, hopefully, that can be repaired without having to replace it.
Nov 09, 2008 | Zonet Computers & Internet
Belkin KVM STandard 9 pin mouse/keyboard to USB COnversion
You need to have the keyboard connecter (purple) connected to your computer in order for the KVM switch to recognize it. The computer is providing some power through the keyboard connector and this is what the KVM switch is feeding on.
If you have a USB keyboard, you may want to change your KVM for a USB compatible one. If you just want to use the KVM to switch your monitor, you may plug the keyboard (purple) connector of the KVM to your computer's keyboard PS/2 port and also connect you USB keyboard directly to your computer. It should work.
Feb 08, 2008 | Belkin 2 Port KVM with Integrated Cables -...
KVM 2 PORT SWITCH
Yes try uninstaling the kvm switch reboot pc's install the kvm again and try another key and see if that works
Jan 29, 2008 | JustCom jc-102cp 2-port KVM Switch
Zonet KVM3122 2-port KVM Switch Logo
50 people viewed this question
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
KG John Justin
KG John Justin
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
