Question about Directed Dei Valet 561r Remote Start/Keyless Entry
My Valet CE0890 remote start wont work after having a new fuel pump installed. When I hit the yellow start button 2 times it makes my head lights flash and makes several clicking noises but will not try to turn the engine over. The keyless entry still works as well as the auxillary function. I had a mechanic tell me I just need to reprogram the remote start but I can't figure out how to do this. pplease help!
  • Amanda Kippenberger Oct 19, 2013
    Ive tried to find the little black box with some switch on it to reprogram it but I can't find the box anywhere.
etirbynnor
  • 655 Answers
SOURCE: 04 Escalade w / Valet Starter, all works but door locks
Hello 7suds,
Well, I'd go back and tell them about the doorlock problem. I know that 2 years is a little late to start complaining, but it's most likely a really easy fix.
The most probably causes are that the power doorlock output was either not programmed, programmed incorrectly, or it's not connected or improperly connected to the vehicle servos. Have the installer check the programming, especially the doorlock pulse duration. It's also possible that the remote is simply not sending the doorlock signal. Could just be a bad button. Have them switch the doorlock function to the right "AUX" button temporarily and see if that works. But in any case, the system needs to be tested to find out exactly what is causing the doorlock failure.
Hope this helps.
Posted on Jul 16, 2009
  • 6 Answers
SOURCE: I have a Valet 551R and the new keyless EZSDEI471
You need dei part # 473T. The EZSDEI471remote is for older systems.
Posted on Nov 09, 2009
  • 171 Answers
SOURCE: my dei your valet remote start turns the engine
Check tack wire it has to be programed
Posted on Jan 07, 2010
MECP Guy
  • 344 Answers
SOURCE: car trying to start but wont
put your key in the ignition leave it in the off position and try to remote start it, if it works the transponder loop around the ignition switch will have to be adjusted or if you have a key in the box under the dash it will have to be adjusted
Posted on Jan 17, 2010
  • 171 Answers
SOURCE: Remote start will not work after dealer programmed a new key.
Yes you need to reprogram your immobilizer bypasskit and depend the model you have it is the program mode, I sugest you go under the dash and try to find out the bypasskit box wich is a small black box like 2"x3"in. and see what model you have.
Posted on Jan 23, 2010
How to program a remote control viper 5900 for a chevy Tahoe
Should be a switch for overriding the alarm under the drivers side dash. Two wires going to it (grey black) with a push button on the end if it. Have the driver door open and turn the ignition to on not running,,,, push the valet button and let go and then push and hold valet button........ Hit lock on the transmitter one time while still holding the valet button down. You should get a chirp for entering program and then when you lock on the remote it will make another chirp. But the chirp will sound awkward. Let go of valet and and turn truck off. And test remote. If that's doesn't work you may need to follow all the same steps but instead if press once and press and hold you will need to push 8 times and hold on the 9th and hit lock on the remote. I'm pretty sure the it's sequence is for alarm security and 8 steps is for remote start only models. Food for though if my mind is working backwards. Best off luck. All else fails I'm sure a shop will do for about 20$
Oct 28, 2013 | 5900 SST 2-Way Security System / Remote...
Tip
Dei viper python valet hornet boa transmitter programming help
DEI REMOTE PROGRAMMING INSTRUCTIONS
Need a DEI Remote Replacement Now? Try our all New Remote Quick-Find
Not sure what type of Replacement Remote you need?
In order to enter Learn Routine, the Valet/Program push button must be plugged
into the main brain's Blue 2 Pin Port (Look for a small black push button located under
the drivers dash or drivers kick panel somewhere). If you do not have the Valet/Program switch, you may order it at www.lesscoelectronics.com or www.lesscosales.com
1)
Open a door and make sure the dome light is on.
2)
Turn the ignition on to the RUN position or you may also start car.
3)
Within 15 seconds press and release the Valet/Program push button
to select the channel you wish to program. For example, press and release
once for channel 1 (arm/disarm channel).
For Channel 2, press and release twice (trunk release).
For Channel 3, press and release three times (remote start).
(Some DEI systems require different programming for different channels. You
can get specific installation manuals with remote programming instruction)
Press and hold the Valet/Program push button once more. You should get a
confirmation chirp/horn-honk or a flashing LED light (If installed).
If you do not get a chirp/horn-honk the alarm may have a jumper in
the alarm that has the programming feature turned OFF (disabled).
4)
Once the alarm chirps/horn-honks keep holding the Valet/Program push button.
5)
Press the button on the transmitter that you would like to control the selected receiver
channel. A chirp/horn-honk will confirm that the code has been learned. If programming
more than one transmitter repeat step 5. Old transmitter codes will be dropped only
if programming 4 new transmitters.
6)
Once the code(s) are learned, the Valet/Program push button can be released.
Learn Routine will be Exited if:
Ignition is turned off
Door is closed
Valet/Program push button is pressed too many times
More than 15 seconds elapses between steps
One long chirp/horn-honk indicates that Learn Routine has been exited.
on Jul 29, 2010 | Car Audio & Video
Remote start wont start the car
try hitting function twice so its at level 2 code and hit the unlock button, that sends it into remote valet mode. if that isnt it make sure the valet toggle switch is on and connected
Dec 01, 2012 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Where is the valet switch on a 2004 chevy malibu LS?
There should be a key specifically for a valet.
1) Open one of your vehicle's doors and turn the ignition, using the car key, to the "Run" position. Check to see that the dome light comes on. Make sure that you have the dome light set to the position where it powers the light when the door is opened, as there are usually three settings: one for "On," one for "Off" and one for when a door is opened.
2) Press the valet remote push-button to access the channel that you want to program: once for "Arm/disarm," twice for "Trunk Release" and three times for "Remote Start." The valet push-button is usually located under the driver's side panel, and it must be pressed within 15 seconds of opening the door. The push-button may also be installed underneath the kick panel.
3) Press the valet push button once again and wait to hear a chirping or a honking sound. If you do not hear either of these sounds, your vehicle might have a jumper installed that has turned the valet programming feature off. Refer to your vehicle's instructional manual to learn how to set the valet programming feature to the "On" position. Keep holding the valet button pressed as you continue onto the next step.
4) Push the button on the remote that you wish to assign to a particular valet channel. Press the button on the hand-held valet remote that you wish to assign to a particular valet channel. If you wish to program multiple remotes, repeat this step for each of them. If you program four or more remotes, the old programming will be erased.
5) Let go of the valet push-button and exit your vehicle. Your handheld remote is now ready to use.
Tips & Warnings - Some valet remote channels require different programming individually, so refer to the owner's manual or to the link provided in the "Resources" section of this article, for specific instructions.
- Valet remote programming methods may vary, depending on the vehicle's make and model.
Feb 17, 2011 | Keyless Entry Remote Fob Clicker for 2004 ...
I reeplaced the fuel pump, fuel filter, and fuel pressure regulator. thinking that was the problem! But was told that the alarm might be the problem so i pressed the alarm twic and the truck started but...
You must put the alarm on a valet mode to see if the alarm is causing this problem
To enter or exit Valet Mode
1. Turn the ignition on
2. Turn the ignition off
3. Press and release the valet switch within 10 seconds
The status Led will light solidly if you are entering valet mode, and it will go out if you are exiting valet mode.
To enter or exit Valet Mode using the transmitter:
1. Open any vehicle door.
2. Press and realese lock and unlock buttons at the same time
3. Press and realese Aux button
4. Press and realese the lock and unlock button at the same time again
The status led will light solidly if you are entering Valet Mode and it will go out if you are exiting Valet Mode
Now when in Valet Mode try to start the engine, if the problem persist the alarm has nothing to do with it
Jan 11, 2011 | 350 HV ESP Security System 350HV ESP
I have a viper alarm on my car that wont shut off nor i cant start the car..and i have tried the button under my dash, how Can i shut it off??
was it a professional or shade tree install? the following is off vipers website:
disarming without a remote control
This feature allows you to disarm the security system without the
Remote Control should it be lost, damaged, or disabled. In order to
disarm the system without a remote remote control, you must have
the vehicle’s ignition key and know where the Valet button is
located. Be sure to check with the installer for the location and the
number of presses of the Valet button required to disarm the system.
To disarm the security system,
turn the ignition to the ON position.
Press the Valet button the
preset number of times (one to
five times) within 15 seconds. After five seconds the system will
disarm. If the system does not disarm, you may have waited too long;
turn the ignition off and on and try again.
if that doesn't work try this other
valet mode
You can prevent your security system from automatically arming
and triggering by using Valet Mode. This is very useful when
washing the vehicle or having it serviced. In Valet Mode, the
security system will not arm, even with the Remote Control, but
all convenience functions (door locks, trunk release, etc.) will
continue to work normally.
To enter or exit Valet Mode:
1. Turn the ignition on.
2. Turn the ignition off.
3. Press and release the Valet
button within 10 seconds.
The status LED will light solidly if you are entering Valet Mode,
and it will go out if you are exiting Valet Mode.
May 08, 2010 | 1994 Honda Civic
Trying to program 474v remote for viper car starter
Super easy
1. Make sure car is disarmed
2. Get in car turn key to IGN position
3. Push valet button one time and let go
4. Push and hold valet button.
5. While holding button push either lock or unlock on keypad of new remote.
6. Siren or horn should sound.
7. Let go of valet button and turn key OFF
8. Test remote
9. Smile and grab a shake ;)
Apr 01, 2010 | Viper Security and Remote Start System...
Hello I have a Orbit remote starter (model Hybrid) that was installed on my truck (automatic transmission) 2 years ago. As of yesterday, it won't start my car as it has always done (from the same...
the starter is in valet mode. your led on your attenna is probably on all the time right??? turn the key on and off 5 times or check your manual to see how to get the starter off of valet mode. read your manual
Jan 14, 2010 | Ford Sport Trac Cars & Trucks
My valet remote control RPN491 Starts vehiclr and unlocks doors but will not lock doors do I need to reprogram remoteto unlock doors?
Ok you said "unlock doors' but you said it already unlocks the doors. This remote should lock and unlock door on same button, if you are describing the 2 button remote. If it is not then it could be alot of things. Does the alarm lock itself? Does the alarm lock the door when you turn on the ignition? More info is really needed. Like what veh and what model alarm.
Sep 11, 2009 | DEI Valet Keyless Entry System
My Mustang Cobra has a Viper alarm system that won't set
Under the dash, Your installer that worked on your Cobra should have put an valet button under the dash, It is a small round Black button, Ok with the driver door open,,put your key in the ignition and go to the on position, Locate the black button before you do this, once the ignition is on hold the black button down for 3 seconds hit it once more and then turn the ignition off, the light should start flashing again and the chirp for arm and disarm with work again, What you have going on is called Valet mode which is designed to put the alarm side of the system to sleep which can happen from accidentally bumping it.
Hope this was helpful.
That Crazy Install Guy.
Apr 05, 2009 | Vehicle Parts & Accessories
Directed Dei Valet 561r Remote Start/Keyless Entry Logo
60 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
