Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
My Bissell Proheat carpet shampooer won't spray water thru the floor mode, it will for the furniture hose. I've taken everything apart, including the heater, and I've tried to prime the pump by the two means I've read about, but to no avail. Any more ideas, anyone?
  • mikadot
    mikadot Oct 19, 2013
    I used to own a commercial extraction machine and wand... I had to use a pin to unblock the jets more often than i used the machine. perhaps see if they are blocked
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
If no response when you put the switch on in the 'floor mode' check the switch. It might be partially malfunctioning.
Check for kinks or holes in the line.
Posted on Oct 19, 2013
5 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: bissell carpet shampooer
First check that the top cover on the back side hasn't come loose. Sometimes the plastic around the screws break away and the top starts to separate, raising the tank, and no spray. Make sure that the gaket is on the valve at the bottom of the tank and not sitting loose in the hole. Check the pump belt. The pump may be bad.
Posted on Jun 17, 2008
  • 3422 Answers
HI,
Please check these:
• tanks are not sealed into receivers
• faulty auto load receiver
• pinched/clogged line
• defective component allowing air into system
• pump not mounted so it can move freely
• defective bridge rectifier
• clogged heater
• defective pump
• defective circuit board
* spray nozzles are clogged
Posted on Jul 20, 2008
  • 37 Answers
SOURCE: My bissell carpet shampooer won't spray out water
The tubes inside the machine are probably clogged. Dismantle top hood and disconnect the three lines at the pump, open up entire top housing and inspect heater. Disconnect two tubes and heater and blow out with air compressor. That will spray all the junk, soap that has built up and your machine will be good as new. If you can't do this yourself, contact bissell and ask where your local repair center is
Posted on Aug 29, 2009
Testimonial: "many thanks for your help l will take a look at the shampooer and if I feel I know what Im doing I'll have a go myself if not I will contact service "
heatman101
  • 43501 Answers
SOURCE: my bissell proheat rug shampooer wont wet carpet at all
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
gfhjdhg
Posted on Sep 30, 2010
My Bissell Proheat carpet cleaner/hose for cleaning will not spray anything
My ProSeries Carpet Cleaner won't spray. What ... - Bissell
www.bissell.com > Support > Helpful Resources > FAQs
BissellLet's start by figuring out where your carpet cleaner can spray. If you have no spray at all, start below. If you have no spray at the floor but can spray from the hose, scroll down for the ... Turn the unit on after cleaning and see if water sprays to the floor now. IV. .... My ProHeat® Self-Propelled's Powerdrive isn't engaging.
Bissell Carpet Cleaner Won't Spray. Easy Repair - YouTube
? 1:48
https://www.youtube.com/watch?v=nccdrjpGp34
Dec 20, 2013 - Uploaded by Cecil Argue
You may have a bad pump, clogged hoses or a clogged heater. ... Just want to tell you that this was the perfect ...
Nov 30, 2015 | Bissell Vacuums
Bissell carpet shampooer
HI,
Please check these:
• clogged heater
• defective pump
Jul 20, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
My carpet shampooer is not sucking up water?
Hey Karen, having no suction when cleaning can be a bummer.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1117&cid=ccsocial
Feb 04, 2013 | Bissell 1699 ProHeat Clear View Upright...
I have a Bissell 2x Turbo 9300 shampooer. It won' spray from the carpet/floor position. I re-booted it and checked for blockage - nothing. I flushed the hand attachment and got it to spray some...
The heater is glogged trust me. It is the size of a dollar bill with seven screws. take it apart and clean the water path also take a small drill bit to the ports of the heater.
May 31, 2011 | Vacuums
My Bissell Pro Heat Pet will spray water but not pick it up when cleaning the carpet. Is there anything I can do to fix it? The furniture attachment hose picks up water well. It seems like it could be a...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
Sep 13, 2010 | Bissell Vacuums
The Water will not spray out(it just dribbles) of the shampooer
heatman101
ewrtwy
Nov 27, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Jun 15, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
204 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
