Question about Electrical Supplies
1963 ONAN SPEC#705JB 3R/1G GEN DATA #705 JB3N1B HAVING PROBLEM WITH VOLTAGE OUTPUT UNDER LOAD ONLY.200 VOLTS ONE PHASE 40 VOLTS ON THE OTHER.FOUR LEAD GEN 120/240 VOLTS.ANY THOUTS,BRUSHES LOOK FINE.
    Prodigy:
    An expert who has answered 500 questions.
  • 573 Answers
First remove any loads, is the voltage still unbalanced? If not check the grounding of the load, if yes check generator N/G leads are tight. Check the stator windings to make sure they are in tolerance for L1 L2. If you need help let me know. This unit probably has a reactor, so check for any loose connections. Also check the diodes, you may have to lift one end out of circuit to test properly, or else your meter will not read correctly
Posted on Nov 18, 2013
4 Suggested Answers
  • 1388 Answers
SOURCE: Powermate PM0496500.02 No voltage output
Here is a simple test to check field and other wiring. With engine off apply 12v ac 1 amp to 110v outlet plug on generator. This will energize the field windings and should cause the armature to produce dc voltage at the brushes and produce a nice magnet. If there is a short in the field or broken wire or shorted capacitor there will be no dc reading at the brushes. . This test is the opposite of what actually occurs when the engine is running. That is the armature produces a magnet fed thru the windings, regulator and brushes. If dc voltage is present at the burshes, remove 12v ac and start engine to check for output. enjoy
Posted on Dec 01, 2008
Tunneler
  • 27 Answers
SOURCE: My yamaha 2400 gen.does not run smooth at idle,
I'm not quite sure if your issue may relate to most inverter and auto-load sensing generators or some gas-powered equipment.
Most power cutters/grinders such as Stihl or Husqvarna, specially the higher cc models do sound crappy without load, you'd think there's something wrong with it from day 1. This is normal. Well, some of these machines lack the load sensing capability thus does not adjust throttle variably according to load.
Modern generators, specially the inverter ones along the 1000 to 3000 watt range where the Yamaha 2400 falls into category, have a switch where you can choose to let the unit sense and adjust throttle according to load. If this is off, the unit might sound like its not running smoothly on idle. Depending on you, this can be alarming or not. On a Honda EU2000is, for example, it is noticeable when the auto-load sensing button is off but not be like its choking or sputtering.
Anyhow if it is idling roughly, I can only come up with 2 possible causes, if I may suggest:
1.) the cable that gradually pulls the throttle (to open wide or close) on the carburetor - normally called governor cable (although it has different configurations on different engine types) needs to be adjusted/tightened. Or replaced, if worn out. Before new cable, put lithium grease on cable - it helps a lot.
2.) throttle adjustment might be necessary. At most Yamaha servicing dealers, it is included when you have a carburetor tune-up. They will check the diaphragm for blockage or holes, gaskets for leaks and filters, well, the entire integrity of your carburetor. This resolves most rough idling issues.
I know it would probably save you at least $65.00 if you have to check this yourself and buy the spare parts. However, going to a servicing dealer may be the best solution but always be sure the repairs are warratied. Hope this helps.
Posted on Aug 16, 2009
Testimonial: "Thank you...I will check all that you mentioned."
  • 905 Answers
SOURCE: Gen starts and runs with rocker start button pushed in..stops....
Cleaning the brushes is used to address an AC output problem. If the generator would run for a few seconds after letting go of the button, then this might apply.
But, since yours is dying as soon as you let go of the button, that tells me that you are probably looking at a low oil condition, or a sensor / sending unit failure for oil level.
Without spec number, hard to remember if the sending unit is for low oil pressure, or low oil level. Either way, the ignition is being grounded. First, double check your oil level, make sure generator is reasonably level. If still not resolved, then locate the sending unit, and remove the wire that is on the end of it. There should be a connector either a few inches from the sending unit, or a few inches from the control board (coming from big white plug). Disconnect at either place. Try starting again. If it starts this time, double check oil levels. If those are fine, then sending unit has failed, or oil pump (if pressure unit) has failed. In either case, don't run for very long until sending unit is replaced, just in case.
Posted on Aug 25, 2009
Output of generator is lower voltage than it should be usually 440v now 395v? reasons?
possible that the rpm of the gen set is lower than normal
there is an adjustment screw that adjusts the spring tension for the governor and it can be adjusted to bring the voltage back to normal
Note here--- if you run the set with a load of around 1/2 capacity set the voltage to on the 440 volts
if you run it at near capacity set it above voltage (445) because as it comes under load the rpms drop and the voltage comes back to normal
Nov 08, 2016 | Electrical Supplies
Voltage gauge drops alternator squeals. When using plow
INSPECT BATTERY ELECTROLYTE LEVEL
INSPECT BATTERY CABLES/TERMINALS
LOAD TEST BATTERY,_______VOLTS @ 150 AMPS (Min SPEC 10.2 VOLTS @ 150 AMPS.)
INSPECT BELT(s),
TEST ALTERNATOR OUTPUT (ON THE VEHICLE,'NOT' BENCH TESTED),
1 _____AMPS @ 12 VOLTS @ 2500 RPM w/PLOW not ENGAGED
2 _____AMPS @ 12 VOLTS @ 2500 RPM w/PLOW ENGAGED ALT OUTPUT SPEC ????
Feb 04, 2014 | GMC Sierra Cars & Trucks
Looking for fuel filter for Onan HDKAK=1046 rv generator. Anyone have the product number
You didn't indicate a Spec number for your gen that would be required. Any RV place can get this part it is Cummins part # 149-2513 but a Spec number would help.
Oct 09, 2013 | Onan Cummins 8.0 HDKAK/1046 RV QD 8000...
Commercail Onan 4.5BGDFB SPEC M GENERATOR
replace the Voltage regulatot.
Jun 21, 2012 | Hammering
Need to know what the volts should be on the starter side of solinoid on a onan 4.0bfa r.v. gen.
Typically near full battery voltage. During starting this may fall to around 10 volts due to the high current once the starter motor engages.
Oct 31, 2011 | Watts Onan Portable Generator - 4000 ,...
I have a Yanmar 4.5 KVA Generator running into a Trace 2.5 KVA inverter/charger, the inverter requires 205-220volts to operate,once the inverter connects the voltage drops on the genny over a ten second+-...
try adjusting the gen voltage at no load to run at 240 volts
when the load comes on it will drop back to 220-235 volts
check the load output from the inverter as 2.5 kv is nearly 80% of the genset duty cycle
4.5 KV is start up KV and the duty KV is around 3..8 kv not the plated 4.5 kv
to get constant 4.5 kv you will need a 5.5-6 kv unit
if the current draw from the inverter is excessive , the engine may not have enough in reserve to over come the load and will not pick up the rpms
take the gen set and the inverter to a shop that has a calibrated load bank to test accurate power output to determine if the engine needs an overhaul
May 28, 2017 | Electrical Supplies
How do you calculate low phase voltage of a three phase four wire system without useing voltmeter?
u can take three incadescent bulbs of same rating, connect them in 3 phase star connection, means 3 phase 4 wire connection..connect it across supply..the bulb connected across low voltage phase will glow dimmer than other two
Jun 19, 2010 | Zenith ZTG Nema-3R, 400 Amps Three Phase,...
Have a 100 amp integrated 12 circuit load center. The top coil burnt bad. The main power is three phase four wire in the distribution panel but we only supplied emergency power to lighting circuits and...
Yes, if ANY load circuits on the third phase was ALSO connected to the transfer panel circuits, a sneak path would allow the third phase from the power company to backfeed this [panel causing damage.
Sep 26, 2009 | Generac Guardian 100 Amp Transfer Switch...
67 votage display on generator output.
Please stop making new problem threads each time you answer, instead post a comment to one of the 5 threads you already have open for this problem. It's getting hard to follow the conversation :-)
OK, now to the problem. You say you have checked 67 volts is displayed on the generator output, I think this means that you see 67 volts on the control panel display when the generator is running. This can be several different problems:
a) a bad CT/PT module that tells the controller the wrong voltage
b) a bad A/D module inside the controller itself
c) a bad voltage regulator
Get a real DMM meter and measure the voltages at the top side of the output (large) circuit breaker of the generator. Put the black lead of the meter on the neutral wire and then measure to each of the phase wires on the circuit breaker. If you get normal voltages then you probably have a bad A/D, if you get 67 volts on all 3 phases you have some other problem.
You still haven't told me what model/spec of generator this is, look on the data sticker on the generator cabinet.
Peace,
Carl
Dec 14, 2008 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
163 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
