Question about BenQ Computers & Internet
Have a Benq GW2750 LED screen and it is say "out of range" how do I resolve this?
    Champion:
  • 220 Answers
This problem is normally due to incorrect resolution settings.
Change resolution to 1024><768 and try or connect this monitor to another cpu or laptop to confirm cause.
If same problem occurs on a known OK CPU then mainboard in the monitor could be defective but chances are rare.Also this screen should be under warranty.
Samir
Posted on Oct 21, 2013
Change resolution benq v2410t
Hello qulli57
My published guide entitled How to set your Desktop Screen Resolution? will do the trick.
Thanking you very much!
damnor01
Feb 19, 2011 | BenQ V2400ECO LED 24"W BEIGE 24 inch...
My benq fp547 says its out of range...the image still shows up but there is a bar in the middle of the screen that says out of range...any ideas?
In windows change your display refresh rate to 60Hz. If you cant get into windows, boot into safe mode by holding f8 after a computer restart and change the settings from there.
Sep 09, 2010 | BenQ FP547 15" LCD Monitor
Hi there my benq dlp projector is showing white spots on the screen when the screen is black can you help me?
This is caused by dust on the lens assembly. If you can remove the lens, clean the surfaces with a lens cloth. That should resolve the problem. It is possible that the there is dust in the optical pathway inside the unit as well. If the cleaning of the lens does not resolve the problem, the unit should be brought in for a professional cleaning. It is not suggested that anyone open up these units as there are fine adjustments that can be changed internally easily that could result in convergence problems.
Dan
Jan 29, 2010 | BenQ PB6100 Multimedia Projector
Contrast decreases to Zero
Had the same problem recently with a Benq FP71G+. It was still under warranty so I called customer care and they sent someone who replaced the board inside that contained all the buttons. I saw that the board was very easy to remove. He just unplugged it, and plugged in the new one. And its a very small board so probably doesn't cost much in case your monitor's warranty period has expired.
Jan 19, 2009 | BenQ FP71G 17" LCD Monitor
BenQ Monitor ' Out Of Range '
check your resolution settings and change to 800><600 and try again.If it does not work at 1024><768 try loading monitor driver In display properties it should show BenQ FP731 instead of plug and play monitor.
Samir
Oct 29, 2008 | BenQ FP731 17" LCD Monitor
Can't find video signal
If screen says "Signal cable not connected " all the time till power led switches to Amber chances are monitor is ok and problem is with graphic card or cpu.Connect to Known working CPU and confirm that monitor is the problem.
If same problem persists on another working cpu after changing signal cable,the interface board in the monitor could be defective.
Samir
PLease rate solution and provide feedback.
Jun 09, 2008 | BenQ FP731 17" LCD Monitor
Blank scren, led stays green for only one second
Explicit enough to see that's this a a repair shop job. That also probably means a replacement- cost of which will not be much more than repair prices. One thing how ever- the power supply[which would appear to be the problem] is this built into the screen [that is does the screen have mains power direct? Or is it powered from an external 'Power Brick' If it is of the Power Brick type - then a new power supply is the answer - get on of the stabilized universal type with a fistful of connectors and a voltage selector switch.
May 24, 2007 | BenQ FP737S-D 17" LCD Monitor
Benq monitor
Change your monitor frequency to 75hz on the screen refresh rate on monitor
Oct 25, 2006 | BenQ FP567s 15" LCD Monitor
Computers & Internet Logo
53 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
