Question about Car Audio & Video
I installed an aftermarket radio in my car. The car's speakers sound pretty bad when I play some of my music off of my iPod. Is there something I can do to improve the quality or would I be better off replacing the speakers too? Steve
    Master:
  • 482 Answers
1st rule of audio, make sure you have a high quality source material, 2nd, make sure you have decent speakers in which to hear that material, 3rd, make sure you have a quality device to play said material, 4th, have sufficient amlifying power to hear the material at the desired level. if you have all these things, you are well on your way to bliss my friend!
Posted on Oct 21, 2013
SOURCE: Speaker Distortion
YOU WOULD DEFINITELY NEED MORE POWER FOR DOES SPEAKERS . WHAT YPU SHOULD UNDERSTAND IS ONCE YOU HAVE AN AMP. THAT RATES HIGHER THAN YOUR SPEAKERS U WOULD ALWAYS HAVE GOOD SOUND RESULTS BECAUSE U DONT HAVE TO MAX OUT YOUR AMP VOLUME .
Posted on Nov 20, 2008
SOURCE: Replacing factory speakers in a 2-door 97 Cavalier
Just make sure they are the same size as your stock speakers and they should just fit right in no customizing needed. For a 1997 Cavalier it's 4X6 in the front and 6X9 in the rear. Shouldn't be too hard just a couple screws and hooking up the existing wire to your new speakers.
-Tyler
Posted on Feb 05, 2009
  • 57 Answers
SOURCE: left front and rear speakers sound muffled when playing cd's
after you play a cd while the cd is playing go into your audio settings and adjust theres settings foe each part on a stereo if u set the audio for AM//FM then play a cd the stereo changes to the cd settings
Posted on Jun 01, 2009
  • 9 Answers
SOURCE: My Music in my car is not playing from the speakers.
I had the same issue in a Ford Explorer. I switched out the factory amp in the back and the sound returned. I feel that you are having the same issues I did. Good Luck
Posted on Feb 17, 2010
  • 185 Answers
SOURCE: Hi, We had a directed video
It sounds like (forgive the pun) the speaker wiring is crossed. To determine this, try using the fader and balance controls like this. Front right speaker only, then fade to back right, back left, then front left. If the music clears up or you do not get a proper balance and fade (only the speaker selected should sound) then there is a wiring problem that the installer has to repair.
Posted on Feb 10, 2011
Has aftermarket amp and special unit that allows an ipod to show what song is playing on the regular factory radio. The problem is the radio lights up normally but no sound from speakers. Zi did hear a...
Something has been mis-wired. Ensure the speakers are in the speaker slots and the power (Neg and Pos labeled as well) are properly connected. It is fairly common to get the speaker pos and neg mixed up with the power pos and neg. Hopefully, no permanent damage was done. The problem is between your factory radio and the aftermarket power amp.
Mar 12, 2015 | Cars & Trucks
Tip
How to change speakers in your Ford vehicle (may work for other makes and...
In this short video I show how I replaced the terrible sounding 5X7 speakers in a Ford Contour. There's a reason these speakers sounded so bad. If you listen to mostly talk radio it probably doesn't matter as much but if you enjoy good sounding music it's usually a good idea, in most cars (unless yours sounds good to you or you already have a premium sound system), to upgrade the factory speakers with aftermarket ones. Age can be another reason it may be time to upgrade and these were almost 19 years old.
18+ years on the factory speaker on right.
on Aug 09, 2016 | Ford Cars & Trucks
Tip
Connecting an iPod Without a Car Stereo
<p>Newer cars often come with adapters to connect an iPod to a car radio, but you can still listen to your favorite lists, if you do not have a car stereo at all. Portable electronics can be used to connect the iPod to speakers, and play it on your car. <br /> <p><br /> <p>1. Purchase an adapter FM radio transmitter for your iPod. It will stream music from your iPod to a low-frequency power, which can be captured by a radio in your car. For best results, use a transmitter with a power adapter 12 volts, you can power adapter car "cigarette lighter" power outlet instead of batteries. <br /> <p><br /> <p>2. Place a "boom box" radio in your car stereo. For purposes of the iPod, the older model, if you have done. All you need is a working radio and decent speakers. Again, it is best if you turn the car to avoid the use of batteries. <br /> <p><br /> <p>3. Set your transmitter to a radio frequency is not used in the stereo field, and tune the same frequency. Adjust the volume on the stereo halfway. <br /> <p><br /> <p>4. Place your iPod within reach of the driver or passenger. When the iPod is playing, the sound will be transmitted to the radio. You can adjust the volume on the iPod itself to control the music changing. When the iPod is off, the radios go silent, although you will hear a static noise. Turn on the radio to get rid of noise, and to save battery when not running the car's power. <br />
on Aug 09, 2011 | Apple iPod touch
My ipod plays songs and i can hear the music but when i switch to radio there is no sound speakers do not work on radio..what is wrong????
Hi Fay
You need to clarify what you are saying....
Your iPod plays songs and you can hear music?
Where is sound coming from... Earphones?
How do you switch iPod to Radio....
Is there a cord connecting both together?
I would then suspect cord or connector type not matching up with radio input connector.
Connectors can be Sterio or Mono
Look at spacing on connector....
Earphone Adapter may help here
Mar 03, 2015 | Audio Players & Recorders
Sony ICF-DS11iP doesn't play my Ipod touch. Radio, Alarm, Ipod Charging functions work. Pls suggest a solution
Please check the iPod connector on the Sony. If you can wiggle it, it is probably a bad connection. These models Sony radios have the connector directly soldered on a PCB and it tends to get loose after a while due to connecting/disconnecting the iPod. If it is loose, the connector needs to be resoldered back into place.
I have had the following circumstances when there was a bad connection:
- iPod will not be charged
- iPod can not play music through the Sony
- iPod will play music through the Sony, but an iPhone won't
Sep 03, 2011 | Sony ICF-C1IP (Black) Docking Station
Thebestplayert@269My Factory Radio display has stop working.But it still plays sound.Can i replace this with an aftermarket stereo or do i need to buy the same stereo that is in it now?
First make sure the key is pushed all the way in the ignition, I have had other cars that if the key was not pushed in all the way the radio display would not work. If this is not the problem, I would replace the radio with an updated aftermarket radio/cd/mp3 player. I have a newer Grand Marquis and the radio went out so I priced used replacement radios and they cost as much as an aftermarket radio. You can find these at any car salvage yard (junk yard). A used radio would be easier to install as you would just have to plug it in using the same cables in the back. To install an aftermarket radio you will need one or two adapter cables and will require splicing wires. I have installed quite a few radios and I opted to do it myself. You can have the radio installed by a dealer but installation cost run from $75.00 to $125.00 depending on type of car and radio. If choosing an aftermarket radio make sure the look will fit the car. You may not like the look of something with widly glowing LED lights a few month down the road. I am very pleased with the unit I purchased as it looks more like an OEM radio and doesn't shout steal me at car thieves. I can play mp3's and plug in both ipods and other compatible electronics.
Mar 04, 2011 | 1999 Lincoln Town Car
Very little sound coming from driver side front and rear speakers, checked the balance and fade nothing is helping.vehicle is 2003 hyundai tiburon with infiniti sound system
the chance is maybe the speaker is blown, or wires crossed, if it is an aftermarket head unit, and or you use an aux cord to listen to an ipod or something like that as your music, that is most likely the auxilary cord is bad or cheap, happened with my car also
Jul 27, 2009 | Car Audio & Video
Car Audio & Video Logo
53 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
