Question about Refrigerators
Ge lss25xsw It's on but not cooling to right temperature
How do you work temp control on GE Profile top freezer
The ACTUAL TEMP light will come on and the display will show the actual temperature. To change the temperature, tap either the REFRIGERATOR or FREEZER pad until the desired temperature is displayed. To turn OFF cooling system, access SETTINGS from the HOME screen. Page over and tap COOLING SYSTEM ON.
Sep 22, 2017 | GE Refrigerators
GE fridge and freezer running but nor cooling
You didn't give many details but if by not cooling you mean temperature is cool but not cool enough it could be that the cooling coils in the freezer section have iced up. This happens if the temperature sensor on the coils fails (among other things). Empty the freezer part and remove the cover to the coils, If they are full of ice/frost you have a defrost problem.
Dec 06, 2016 | GE Refrigerators
On my GE lss25xsw, the temp controls work fine, but the water, light , crushed and cubed ice stopped working. When i press lever for dispersement, the selection led goes out and the screen blinks. Thanks
i might be wrong but i have had to replace alot of main control boards because of erratic operation. seems to be a common problem with GE refig's
Nov 02, 2013 | Refrigerators
GE REFRIGERATOR FREEZING FOOD IN REFRIGERATOR SECTION MODLSS25XSW
try adjusting the refrigerator to a warmer settings, set it to normal
Jan 18, 2013 | GE Refrigerators
Not cooling very good anymore. its cool but not that good! all the settings work. one thing i did notice is that ice builds up on the cooling coil from compressor! ( ge room ac model # ast05lcs1...5500...
Your intuition is right, the ice buildup is why it's not cooling so well now: the evaporator isn't getting the correct air flow and surface area for heat exchange. The 1st thing you might want to check is to make sure that it's draining properly. The 2nd thing you might want to do is to check that the room is over 100 sqft. If you'r only cooling a tiny bedroom, the AC's basically oversized: your cooling already cooled air, so it freezes. The actual reason that is freezes is because the condition is just right for the immediate area near the evaporator to be at the saturation point. Think of it in terms of weather: warm and humid air collides with cool air and it begins to rain. The temperature drops further, and the rain turns into snow. One thing you could try to make it not freeze-up is to adjust the temperature setting a few degrees or change the fan speed.
Aug 04, 2011 | GE ASQ05LK 5,050 BTU Room Air Conditioner...
Not cooling and temperature lights are off
If you have a GE , then the main control board is bad . Model and brand would have been helpful .
Jul 26, 2009 | GE Refrigerators
GE monogram fridge: Poor Cooling after cleaning
Temporary solution.
Open the top hook. leave it open overnight.
Check in the morning if the temperatures comes back to normal. It works for me!
Jun 06, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Ice maker not working
you need to check the inlet screen on the solenoid down below for blockage, also make sure that the freexer is cold enough
Dec 26, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
I WANT TO BUY THE UNIT WHICH CHANGE HEATING AND COOLING AND TEMPERATURE UNIT FOR GE ZONELINE
WITH ANY OF THESE UNITS YOU CAN WIRE AN EXTERNAL THERMOSTAT WICH WILL ACOMPLISH THIS, JUST MAKE SURE YOU PURCHASE A T-STAT WITH A HEAT / COOL AUTO CHANGE OVER.
Jan 10, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
