Question about Vizio VO370M LCD TV
I'm trying to remove the back panel from my Vizio VO37OM tv. I removed all the screws however, it is still getting stuck it seems at the cable socket behind the tv. I'm wondering if that also needs to be removed and if so how? I combed the back a few times making sure I removed all the screws. It seems it's just that one left, and the other end of the panel is lifting off but not that side.
  • Vizio Master
  • 933 Answers
Make sure you remove the washer/nut for the coax connector. Also make sure you remove all the screws for the video input terminals.
Posted on Oct 30, 2013
4 Suggested Answers
SOURCE: I need to relocate the audio output jack on a Vizio VX20L
No it is just a tough cookie to get apart. There are 8 screws in the stand and 4 screws on the case then it should be ready.
Posted on Jun 18, 2009
SOURCE: I need help with disassembly of Vizio GV42L LCD TV
remove all the screws and start at the bottom and push in the tabs, and work around the edges, being careful not to pry too hard, the cover has clips all around the tv. after the bottom is free and one of the corners the cover will kind of pop off if you use the palm of your hand and lightly tap as you apply sum upward pressure.
Posted on Dec 06, 2009
jdvillanueva
  • 2098 Answers
SOURCE: trying to remove/replace power fuse on a 2008
You can use the flat screw driver, place the flat side of the screwdriver under the stuck fuse and gentle turn the screwdriver to lift the stuck fuse on its holder. You can also use long nose plier to lift it up.
Let me know if you need further assistance.
Posted on Jun 20, 2011
How do I remove back cover from Vizio E601i-a3 60" tv once all screws are removed? Still seems tight around the edges? Thanks
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Disassemble procedure to many popular devices are given with illustrations.
Dec 28, 2016 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Change from cable to antenna on vo37om tv
This web site will direct you to the owners manual, then pages 10-24 should help you connect & switch between cable & antenna.
http://store.vizio.com/documents/downloads/hdtv/VO370M/182Manual.pdf
Apr 20, 2014 | Televison & Video
Can't seem to remove back panel from TV to replace the speakers. All screws removed, seems to be stuck on.
Check for screws on the interior of the back panel, not just around the edge. There are screw around the panel where the plugs are connect.
Oct 26, 2013 | LG 32LG40 32 in. LCD HDTV
When I turned on my vizio vo37om this morning, there was no picyture, screen is black. Sound is fine
Dim the lights in the room, turn on the set. Shine a bright flashlight on the screen, do you see a faint picture?
Feb 11, 2013 | Vizio VO370M LCD TV
Can the screen on vizio vo37om be fixed if it is splintered? it still powers on
You cannot fix a cracked screen. You can replace it but the cost of a replacement panel will be more than a new set. Although the screen is cracked, the set does still have some value. You now have whats called a parts set. If you choose not to replace the screen, list the TV as is on your local Craigslist. If you get $20-$40 for it, take the money and run
Nov 28, 2012 | Vizio VO370M LCD TV
Vizio VF550M volume stuck at 100
The 2 suspects are possible but there is a way to find it..try to get the control board and remove the vol+ button on it..then back the controller then power it on again try to push vol- on remote or TV..if no help you have faulty main board..
Mar 06, 2012 | Vizio VF550M 55 in. LCD HDTV
How do i get the back panel off a vizio vx42l tv?
Lay the tv on a bed face down to keep from hurting the screen. remove screws from base, remove base. Remove about 20 screws all around the back and beneath where cables plug in. Keep screws in neat stacks as some are different (you want to put correct screws back in right place). The back lifts off (it kinda takes some jingling to pop lose) after all screws removed.
Jun 20, 2010 | Vizio VX42L 42 in. LCD TV
I NEED UNIVERSAL REMOTE CODE FOR VIZIO VO37OM
i habve a vizio tv bought used need parental code for young child tv vo37om
Feb 20, 2010 | Vizio VO370M LCD TV
Jul 29, 2008 | Vizio GV42L 42 in. LCD Television
Vizio VO370M LCD TV Logo
384 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
