Question about Garden
I just got this 20/42 murray ultra runs good but is very slow moving forward. Is this normal? I would think for a 20hp vtwin it should go faster than 5mph. No the belt is not sliping. The forward reverse pedal is (adj) correct.So I'm I to beleave that this mower is this slow.
SOURCE: Hydrostatic mower goes in reverse but not forward. Only 73 hrs on it!
On my hydrostatic there is an adjustment on the forward/back lever which can be made to run all reverse or all forward. Normal setting gives both of course. Look at that adjustment. Maybe something let go.
Posted on Oct 14, 2008
SOURCE: Murray Riding Mower will not move forward or back
my murray Riding Mower will not move forward or backward
Posted on Sep 03, 2009
  • 396 Answers
SOURCE: wont move forward or reverse-- transmission??
Does it have gears or a hydrostatic (automatic) transmission?
If it's a gear model, sounds like a loose drive belt.
If it's hydrostatic, it could be a belt problem or a problem inside the transmission. If it's a tranmission problem, this is not good. Many of the transmissions on riding lawn mowers are not serviceable - they are just replaced.
Posted on Oct 10, 2009
SOURCE: Sears ZT 7000 mower, engine runs, mower will not move
Same problem. The drive belt pulley tensioner spring broke. Replaced and everything worked great.
Posted on Apr 05, 2010
  • 33 Answers
SOURCE: MTD riding mower does not move forward or reverse.
this is a belt driven transmission. from the engine driven pulley going aft towards the xmission differential there is another smaller variable speed pulley, there is a long belt between these two, from the variable speed pulley there is a larger xmission pulley that sits kitty-corner to it with a belt between these two. This larger "xmission pulley" is what drives the differential and depending upon which gear you have selected, makes it go forward or reverse. Check that both belts between pulleys are on, check that pulley's hardware is completely secured (nuts tightened down) The heads of these pulley's are splined to align to the shaft(s) and if they aren't tight, they will just spin and not engage the transmission. If your battery is under the seat, remove it and you should be able to see and access the aft pulleys. If both belts are on and engaging the pulley's and the shaft is turning on the transmission pulley than you have transmission differential failure. Bet it's the belt off or pulley head loose. Good luck, hope this helps
Posted on Apr 14, 2010
My Murray 20hp Briggs and Straton runs with choke on but stops when choke is turned off
carburetor needs to be taken apart and cleaned real good with carb cleaner. try to change the fuel filter first.
Apr 20, 2017 | Briggs Garden
My murray riding lawn mower stops moving in forward and very slow in reverse after about 20 minutes of mowing.
the balts are probably wore out. if they look cracked or thin in spots replace them both at the same time. should be back to new.
Jul 09, 2016 | Murray Garden
Not running up to speed, very sluggish
Check the carbon brushes under the black screw caps on the sides.
Dec 03, 2013 | KitchenAid KSM90 Ultra Power Series Stand...
Troy bilt 20hp, 42", moves slow
not knowing if it is shift on the fly or it has a automatic trans makes it a little harder to help a shift on the fly has a pulley in the center of the machine that gets stuck and doesn't change size as it should a automatic look for fluid leaks and puddles of fluids low fluid level could cause slow movement if you need more help add make and model numbers
Jun 16, 2012 | Garden
Husqvarna riding mower modle yth20k46 that move very slow
The link rod from the petal to the transmission straightened out at the rear bend. Take it off and bend it slightly further to make it go forward faster. The 1/2" nut above where the rod connects to the transmission is adjustable to set it where it doesn't move when your foot is off the petal. Loosen it a bit and you can move the petal slightly forward or backward to adjust it. Depending on how much you bent the rod it won't take much adjustment. Re-tighten and try it out. It may take a few tries. Good luck!
Mar 17, 2012 | Husqvarna Garden
Bell & howell 356 projector runs slow
You have this posted in the car and truck forum, please re-post in the correct product category.
Feb 21, 2012 | Cars & Trucks
Murray Peerless transaxle slow forward speed. Drive belt was changed and linkages where adjusted. Very slow forward and no reverse.
I think the only logical conclusion is that your hydrostatic transmission is shot. If you know the model number, I think they
are stamped on the bottom, you can look over on ebay. There are some NOS vendors over there and they may have one. There are also mower junkyards around, believe it or not, and if you can find one you may find a serviceable replacement.
Sep 23, 2010 | Garden
Murray 20 hp
probally trash in the carb or fuel filter partially clogged. try replacing the fuel filter if no go the carb will need disassembled and cleaned.
Jul 14, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Murray belt manual for a 20hp 46" rider lawn mower
here is a link to all of the murray manuals, for free. pick out your model and enjoy your manual.
Jun 02, 2009 | Computers & Internet
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
