1984 Sportcraft Cross Country RV. Does it have a dual pickup fuel pump? If so, if it's not working. what might I try to fix it. I have no voltage to my pump
  • 1,869 Answers
With the key in run position; run a 14 gage wire from your battery positive post to the hot side of the fuel pump if the pump runs that's the problem if it doesn't find the fuel pump ground wire it should be attached to a metal part by a screw remove the screw and sandpaper the screw hole untill no paint or dirt is present then reattach the screw and test the pump again
Posted on Oct 31, 2013
My RV has dual gas tanks, with a dash-mounted selector switch. I had it repaired a couple of years ago, but now one of the fuel pumps does not work. I need a color-coded wiring diagram.
MICHAEL, ON THE 80 AND EARLY 90's FORD PICKUPS AND CHASSIS WITH DUAL FUEL TANKS, FORD OFTEN USED AN ELECTRIC "Y" VALVE NEAR THE FUEL TANKS AND USUALLY, IF MEMORY SERVES ME CORRECTLY, A SINGLE FUEL PUMP. YOUR CULPRIT IS MOST LIKELY THE ELECTRIC VALVE UNDER THE MOTOR HOME NEAR THE FUEL TANKS. WHEN IT'S SWITCHED FROM ONE TANK TO THE OTHER, THE ELECTRIC VALVE LOCATED NEAR THE TANKS IS NOT RECEIVING THE SIGNAL FROM THE SWITCH TO CLOSE ONE SIDE AND OPEN THE OTHER SIDE OF THE VALVE. FORD HAD A RECALL ON THE 1992 FORD TRUCKS FOR THIS REASON.
May 16, 2016 | RVs
Isuzu not starting
what country car is this. why must we guess,?????
Isuzu's are gone here , USA>?????/
and data hard to find, due to that rarity.?????
i have no ideal at all what 84 tld 56 means... nor wiki !
and is an engine question and they use lots of engines world wide on all isuzu.
and must be a CARB fuel system , right, or is it a DIESEL>>>????
56 is the hard part, there is no 5.6L engine. so >????
wiki never head of TLD.
gas engines, check spark yet. , good try test fuel yet.
diesel , clean fuel , clean filters., glow plugs work.
try test fuel yet?>
see why I must guess wildly,,
what car?
what country?
what engine.?
Jul 11, 2014 | 1984 Isuzu Pickup
454 fuel pump hits cross member
Sounds like a broken engine mount
Feb 11, 2014 | Cars & Trucks
I need a steering column for a 1984 Dodge Ram Prospector...where would I go for parts on the internet?
What I would do is type in 1984 dodge ram steering cloumn and hit search.The most common hits will be e-bay and probably kijiji or craigslist. You could also call your local salvage yard. Most of them are on a cross country intranet with other yards and could find one that way.
Oct 22, 2013 | 1984 Dodge Pickup 4WD
1984 toyota pickup 22re fuel injection is not getting fuel to the cylinders
Most likely a fuel pump problem, locate the diagnostic check connector under the hood and turn the key on then put a jumper wire between the terminals FP and B+ if it start then the fuel pump is ok and the problem may be the EFI relay or efi fuse
Sep 28, 2012 | 1984 Toyota Pickup Deluxe
1984 pickup, not getting fuel to carb. was told to replace fuel pump, replaced, still no fuel, from what i can see this has an auto choke replay, inhibitor relay, and a fuel pump control unit, so does this...
IF THE FUEL PUMP YOU REPLACED IS ON THE ENGINE BLOCK IT IS A MECHANICAL PUMP AND THERE IS NO RELAY OR PUMP IN THE TANK. NEED MORE INFO TO CORRECTLY HELP
Feb 05, 2011 | 1984 Nissan Pickup
Nissan sentra fuel problem. Put new filter and fuel pump but no gas getting to filter to get to pump. Gas line problem from tank?
I believe this is a manual fuel pump and you may have lost the prime, no fuel in hose to tank. If the hose from rear frame to tank has a break or hole, it will **** air and not fuel from tank. If this is not the case, possible clogged fuel hose, tubing, or pickup tube in tank assuming you have turned the engine over serveral times and there is enough fuel in tank. Some tanks do not pickup from very bottom because of water laying in bottom of tank from condensation.
Dec 12, 2009 | 1984 Nissan Sentra XE
1984 nissan pickup fuel pump relay location
If it's like mine, the relay is located on the passenger side fender wall. You should see a set of 5 relays together. It is the first one in the back.
Nov 29, 2009 | 1984 Nissan Pickup
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
