Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Where is motor m1 - i have to change it - Konica Minolta bizhub C250 All-In-One Laser Printer
  • peter
    peter Oct 19, 2013
    error code c5102 - changing mainmotor m1 - found it now- changed it - its all fine - c252 runs
    Scholar:
  • 78 Answers
where is motor m1 - i have  to change it - 1a93f223-4c41-4109-b03b-02bd40521a76.pngSee the image
Posted on Oct 20, 2013
Error code 5102 on konica minolta c253
According to the service manual, Code: C5102 Code C5102 Description Transport motor's failure to turn
• The motor lock signal remains HIGH for a predetermined continuous period of time while the motor remains stationary. Remedy 1 Check the M1 connector for proper connection and correct as necessary. 2 Check M1 for proper drive coupling and correct as necessary. 3 Check the PRCB connector for proper connection and correct as necessary. 4 M1 operation check. 5 Change M1. 6 Change PRCB.
The technical sites say that there is probably a paper jam. If the jam is cleared but the error persists, the transport motor will probably need to be replaced. This motor has a pretty high failure rate. A qualified copier technician should be able to change it out in 30-60 minutes.
Aug 30, 2015 | Konica Minolta Office Equipment & Supplies
Konica bizhub C451 error code c 5104
Transfer belt motor's failure to turn.
1 Check the M1 connector for proper connection and correct as necessary. 2 Check M1 for proper drive coupling and correct as necessary. 3 Check the PRCB connector for proper connection and correct as necessary. 4 M1 operation check PRCB CN13PRCB-3 (REM) PRCB CN13PRCB-6 (LOCK) K-11. 5 Change M1. 6 Change PRCB
Oct 10, 2013 | Konica Office Equipment & Supplies
Bizhub 164 error code c-5102
Code
C5102
Description
Main motor malfunction
- The main motor (M1) lock signal remains HIGH for a continuous 1-sec. a period at any time 1 sec. after the main motor has started turning.
Remedy
1 Check the connector between M1-PRCB CN6 for proper connection and correct as necessary.
2 Check M1 for correct drive coupling and correct as necessary.
3 M1 operation check.
4 Change PRCB.
5 Change DCPU.
I’m happy to assist further over the phone at https://www.6ya.com/expert/latoya_8ed1bf3dc615c15d
Oct 03, 2013 | Konica Minolta bizhub C250 All-In-One...
Canon ir 2520 error code E000010
Unstable rotation of the Main Motor (M1)
Detection is executed every 100 msec after the start of motor rotation; however, the drive detection signal is absent for 2 sec.
1.Replace the Main Motor (M1). 2.Replace the DC Controller PCB (PCB4).
Jan 23, 2013 | Canon Office Equipment & Supplies
Error C-5102 minolta C450
C5102: Main Motor's failure to turn
Relevant Electrical Parts
Main Motor (M1) Mechanical Control Board (PWB-M)
DC Power Supply (PU1)
Step Action
WIRING DIAGRAM
Control Signal
Location (Electrical
Component)
Check the PWB-M connector for proper
M1 operation check PWB-M CNDM1-5 (REM)
PWB-M CNDM1-8 (LOCK)
L-2
5 Change PWB-M - -
6 Change PU1 - -
thanks&regards
Sep 06, 2012 | Minolta Di3510f Bizhub Copier
My konica minolta bizhub 7145 b/w copier is showing error code F-51-5 The copier will power up and then seize. The copier is about 5 years old with a total count of 320,000 copies
Hi the problem is going to be with the M1 motor most of the time replacing this motor will fix the issue However in rare cases if it still gives you the same error after replacing m1 motor then you will need to change CB Main Body control board my advice is to replace the motor and if it still gives error code replace the cb board but it will fix your problem
Mar 09, 2011 | Konica Minolta Bizhub 222 Black and White...
I am facing a problem code 0000
if this is the error code C0000
the Main Drive Motor M1's failure to turn.
The lock signal remains HIGH for a continuous 2.0-sec. or more period while M1 is energized.
Checkthe main motor or call for tech.
Nov 14, 2010 | Minolta EP4000/5000 CS/PRO Copier
Konica minolta bizhub 162 have error C0000(main motor malfunction) i try with another motor but same thing! any ideas?!
could be master board (pwb-a) or power supply unit (pu-1) or something that the motor turns is locked up try to you turn the motor by hand whil it is installed in the machine if you cant turn it by hand something is locked up
Nov 30, 2009 | Office Equipment & Supplies
Minolta ep3000 service m1 ? and how to reset ? can you help
M1= main motor
1. Does the transport motor (M1) operate during power up?
NO, Ensure the connection of the connector (PJ21A) is secure.
2. Replace the transport motor.
YES, Check if there is excessive load on any of the rollers,gears,etc.
3. Replace PWB-A.
Jan 22, 2009 | Office Equipment & Supplies
Error code c-5102 in Konica minolta c252
Here’s your GEEK-steer …
This thread appears to cover the solution to your problem related to error "C5102: Main Motor’s failure to turn":
http://www.copytechnet.com/forums/konica-minolta/15515-c252-m1-operation-test.html
In addition, here’s the link to “Bizhub C250P” related support downloads:
http://kmbs.konicaminolta.us/content/support/supporthome.html
Hope this helps, and please post back with a status report and/or any further assistance you might need.
"Today's the best day of my life...and NOW you're part of it!"
Dec 15, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
800 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
