Question about Black & Decker/Dewalt/Porter Cable Dewalt 4 1/2" x 1/4" x 5/8" -11 High Performance Metal Grinding Wheel DW4523
Bench grinder flanges not precision enough, would like to get some precision flanges.
How do I operate bench grinder?
A murphy, A bench grinder must be used with a lot of caution and respect while using this equipment, Check the attached links,instruction and guides, Good luck work safe.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
OSH Answers Fact Sheets
Pedestal Bench Grinder Safety
Bench Grinder Basics
Mar 21, 2016 | Bench Grinders
Need belt for bench grinder belt #lb-12
To find the correct belt you will need to know the Brand and Model Number. Is the number on your old belt or on the grinder? Once you have the correct info you can get parts list by google searing for that. here is what I got just using the bench grinder belt #lb-12.
Just cut and paste the link in a new browser window.
https://www.google.com/search?q=bench+grinder+belt+%23lb-12&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
Hope this helps..
Nov 04, 2012 | Grinders
What are the power source requirements for a DeWalt #756 Grinder?
My experience of bench grinders suggest 15 amp will be enough, certainly at 240 volts . If you are 110 then I think it will still be enough but you dont make clear what the wattage of your machine is.
Jun 06, 2010 | Dewalt 6" 5/8 Hp Heavy Duty Bench Grinder
Need an on/off switch for a buffalo bench grinder model B-6CB 1/2 hp. 41/2 amp. serial #775713
I had the same problem with a Northern Tools bench grinder. These are made in China and parts are hard to come by. I had enough room after removing the old broken on/off switch to install a single pole 15 amp light switch like you use in your home. I simply installed it horizontally and then put the switch cover on. It works perfectly. If you do not have enough room then look for any 15 amp or larger switch that will fit in the housing. Any on/off switch will work. You could even mount the switch on the bench in a switch housing and run the wires from the grinder to the switch and back if need be. Just be safe and make sure there are no exposed wires. As a last resort you could remove the switch connect the wires, eliminating the switch and use a plug in wall switch such as this. 4147a14.png
Apr 23, 2010 | BUFFALO 10" Bench Grinder
Bench Grinder blown fuse
try the fuse first then try the red reset button under the base.
Mar 05, 2010 | Clarke Power Products Cast Iron Bench...
Grinder wheel wobbling
check bearing for play and or race for wear on wheel
Oct 06, 2009 | Grinders
Bench Grinders Objects
our bench grinder can be used to keep your chisels, knives, gouges and other similar cutting tools sharp, which every woodworker knows is vitally important. Also, bench grinders are handy for sharpening lawn mower blades, drill bits, gardening shears and more. Additionally, a bench grinder can be used for honing and shaping metal objects when modifications are needed. For instance, perhaps you need to modify a door hinge to make it fit in a certain application. No tool is better for this task than a bench grinder.
Aug 27, 2008 | Dewalt 6" 5/8 Hp Heavy Duty Bench Grinder
Bench Grinders Usage
Grinding is the fastest way to deburr a sharp corner or dress the end of threaded rod or bar stock that's been cut to length. Fit a grinder with a wire wheel, and you have a handy tool for removing rust. Then switch to a buffing wheel and you're ready to polish metal to a mirrorlike sheen. But for most of us, grinders are essential for shaping and sharpening hardened tool steel and high-speed steel.
Aug 27, 2008 | Black & Decker 3/4 Hp, 8" 205MM, Heavy...
Precision work question
Bench grinders aren't designed for precision work. In fact, they're really freehand tools that rely on a good eye and careful touch. And while you can take some tools, like drill bits or turning tools, right from the grinding wheel to the work, it's common for grinding to be a relatively coarse, preliminary shaping procedure, followed by careful honing on a whetstone.
Aug 27, 2008 | Black & Decker 5/8 Hp, 6" 150MM, Heavy...
Grinder Types
Bench grinders are perfect for sharpening cutters, bits, blades and hand tools. Any piece that needs smoothing, shaping, or polishing can be done at the bench grinder. Straight grinders or angle grinders are portable, handheld tools with wheels that range from 4 to 9 inches. They are the best grinders for working on pieces that may be too large to fit at a bench.
Aug 27, 2008 | kawasaki 7" or 9" Angle Grinder
Black & Decker/Dewalt/Porter Cable Dewalt 4 1/2" x 1/4" x 5/8" -11 High Performance Metal Grinding Wheel DW4523 Logo
Top Black & Decker/Dewalt/Porter Cable Grinders Experts
DrBogo
Level 1 Expert
Tom Chichester
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Black & Decker/Dewalt/Porter Cable Grinder Expert? Answer questions, earn points and help others
