Question about Lakewood 7101 Oil Filled Radiator Heater
Need to replace 600W switch and thermostat. Where to purchase parts and cost? Switch is intermittent and thermostat does not control heat, stays on full power.
2 Suggested Answers
  • 43901 Answers
SOURCE: I need a 600w/900w switch for a Lakewood oil filled heater 1500 watt. It has a yellow light on the 600w side. and red light on the 900w side. I need the whole switch. Where do I get one?
Fixya is unable to suggest sources for Lakewood switches.
Posted on Mar 19, 2018
Replace fuse dryer model GEQ8821LLO
Hello;
My name is Peter. I am a retired field service appliance technician.
You never explained what the problem was. Dryer not running? No heat? Dryer shutting down. It could be as simple as cleaning out your dryer hot air distribution manifold. A dryer will not run if you do not have good air flow due to lint blockage. A dryer will not run if you have a bad door switch. You can Ohm components out with a multi-meter, setting the meter to the lowest Ohms (Omega Symbol). You should get a reading of "0" if the component is good.
1.) Dryer Door Switch - This switch replaces your dryer door's switch.
  • You may need to remove your dryer's lint screen and lint screen housing before lifting its top panel to reach its existing switch.
  • Be sure your dryer is unplugged during installation.
This Dryer Door Switch part #3406107 Cost $20.00
Dryer Door Switch - Unplug the dryer before replacing the door switch.
This Dryer Door Switch part #279782 Cost: $22.00
Thermal Cut-Off- This component is located on your heating element housing,. you may be able to access it at your hot air distribution manifold in the back of your unit.
  • When replacing your dryer's fuse, replace its thermostat, too. The thermostat should have prevented the dryer's existing fuse from blowing. The high-limit thermostat is functional to 250 degrees (Fahrenheit) and the thermal cut-off fuse to 360 degrees (Fahrenheit).
  • Install the fuse in your dryer's heater element housing box. Be sure your dryer is unplugged during installation
  • Part #: 3977394 Cost: $33.00
    25432459-jpgjqed1aonpcy4b0i04xdgb-5-9.jpg Cost: $34.00
    The high-limit thermostat replaces your dryer's thermostat.
    • The thermostat is functional to 250 degrees (Fahrenheit).
    • Install the thermostat in your dryer's heater element housing box. Be sure your dryer is unplugged during installation.
    This High-Limit Thermostat part #3390291
    Hot Air Distribution Manifold:
    This is in the back of your dryer and easily unbolted. If you are plugged up with lint your unit will shut down. Remove this component and clean the lower discharge end.
    25432459-jpgjqed1aonpcy4b0i04xdgb-5-14.jpg So, tell me what the problem is, and I will tell you how to fix it.
    Peter,
    Glen Burnie, Maryland, USA
    Feb 15, 2015 | Whirlpool Dryers
    Heat Pump will not shut off
    flow switch timer in the unit. its a part on the pcm board. tell the pump to stay on for 10min after heat up. and does other times as well depending on setup... its not really a switch its a chip but it works as a switch.
    Mar 08, 2014 | Honeywell Programmable Thermostat Heater
    Lightolier 3 way remote wiring
    If you have determined the wiring to be correct, then yes, the remote is probably defective..
    According to Lightolier literature, your Lightolier OS600 is called a "strap dimmer". Having 540W on a 600w rated switch is pretty close to the limit (90%) of the switch, and will cause the switch to fail sooner than say a 300w load. The 600w rating of the switch applies only if all the heating sink fins are in place. Often times, when installing in a box with another switch or dimmer, fins must be removed to allow the switch to physically fit. If any fins are removed, the rating of the switch is reduced. Page 30 of the manual shows that a 600w strap dimmer that has a single fine removed is reduced to a 500w capacity dimmer, and if both fins are removed, it is reduced to a 400w dimmer. You may find that you will need a 1000w dimmer to reliably gain control of your 540w load, as it will control 600w even with both fins removed. This derating is required due to the heat created by the dimmer. Heat is a killer for electronics, and solid state dimmers are no exception.
    Check out page 32 of that manual. On it, are wiring diagrams for dimmers and switches. I believe your is figure "G" that shows the 120v "hot" (black) connected to the black wire of ALL switches, the yellow wires of ALL the switches are connected together, but are not connected to anything else, the 120v neutral (white) connects to the MASTER white wire AND light fixture white wire and finally, the MASTER red wire connects to the light fixture black wire.
    It is also important to note that these switches are for standard tungsten incandescent and quartz halogen lamps ONLY. They are NOT suitable for CFL, Fluorescent or other types frequently found in commercial / industrial buildings such as neon or other gas lamps such as Metal Halide, Mercury Vapor, High Pressure Sodium, etc.
    I hope this helps & good luck!
    Jun 01, 2012 | Philips Lightolier Onset 600W Incandescent...
    My heater would only work on hi and even then the heat was not as warm as it should be. Then today on the way home I noticed a small amount smoke coming from the switch area where you turn it on and adjust...
    The operating only on HIGH is most likely a problem with the Blower Motor Resistor - this part costs about $30 The problem with the smoke is most likely the Blower Control Switch - Saturn has had problems with both of these. Most aftermarket parts houses have replacement switches for around $60. You have to remove and disassemble the A/C - Heater control head to install the new switch. (About 1 hour of labor if you have it done professionally - about 1.5 to 1.9 hours for both the switch and the resistor)
    Apr 08, 2011 | 2001 Saturn SL
    The rolling feet are missing. Any idea how to find replacements
    I have a Lakewood 7096 heater. We purchased it used and got 8 to 10 years of service out of it. It was never heavily used while in our possession, just to heat the bathroom for showers.
    The 900W switch quit working after used it and showered Sunday. The 600W switch still works fine, but the unit doesn't produce much heat at any speed.
    After looking at various posts on fixya today, I decided to pull the pair of switches out. The 900W switch is burnt. The wire attaching to the 900W switch is burnt and bare!!! I don't know what happened. I would be scared to use it again, even if I replaced the switches and the bare wire. I don't know if it's even safe to use the 600W setting.
    Anyway, I purchased a sunbeam radiator heater this morning. The ol Lakewood has the wheels you are missing. If were to come to an agreement on price, I would be happy to ship them to you. They are in good shape, just a little squeeky, which a little oil would fix.
    Jan 17, 2011 | Lakewood Oil-Filled Electric Radiator...
    I have a Jenn Air radiant glass cooktop, model CCE3401B. The left rear burner will not heat. Howver the indicator light under the control knob stays on continuously, regardless of the position of the...
    If the light circle around the knob stayed on, then you have the same problem I just had. I purchased a OEM replacement switch via ebay for $38. Very simple replacement, but take your time so you understand how it works. It took an hour to install and works fine now. Here is the link to the parts list:
    shared.whirlpoolcorp.com/assets/pdfs/literature/Repair Part List - CCE3401B.pdf
    If you can, take pictures with your phone of how everything is assembled before you take it apart. It will save you hours of aggravation.
    I must say, Jenn-Aire (Whirlpool Corp) was less than helpful. I asked for some advice prior to purchasing the replacement part and all they would tell me is they were willing to schedule an authorized repair shop to come over. The closest was a 2.5 hour drive each way, and the travel time cost was $85/hour. Plus the part at list price ($90 something) and installation was going to cost $600. Give me a break.
    Dec 31, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
    Main blower stays on, burner fan on intermitantly,
    All gas furnaces have a fan control of some sort. Either a mechanical fan control where there is a temperature probe that reaches into the heat exchanger compartment thru a hole in the panel that separates the control part of the furnace(this would be the front of the furnace where all the controls are) from the heat exchanger. This type of control is either a small black plastic control about 4 inches by 2 inches and about 1 1/2 inches thick secured to the panel with 2 screws. Or it is a slightly larger silver colored control that should have a pull off cover. It may say Honeywell on it. Either way the control will need replacing.
    The other type of fan control is a solid state control board. This will most likely be located in the indoor fan compartment. It should be located under a covered control box. The box with all the wires going into it. This board will also need to be replaced if your furnace uses this type of fan control. You will need to bring your furnace model and serial number to a dealer that sells your brand of furnace or go online to a parts dealer that carries parts for your furnace. Hope I was of help to you! Good luck!
    Nov 28, 2009 | Heating & Cooling
    Intermittent heater control Marvin 2060
    On Monday, 1/21/08, I returned the Marvin 2060 heater to the store I purchased in 02/07 since the freeze guard stop working. The owner left me a voice message at home and said he after doing some research, he discovered Marvin went out of business in 12/07.
    And the heater is no longer covered under the warranty. The owner gave me a telephone number, 800.326.3690 which carry the parts for Marvin Heater. I have not called the number since I am looking for another heater with the freeze guard feature since it something I need quickly.
    Jan 18, 2008 | Marvin 2060 Compact Heater
    Indesit D61D getting stuck
    hi yes, well done! you fixed the problem by yourself now all you got to do is change the element buy a new 1 for this specific model and switch them a little more work then a light bulb switch good luck
    Mar 26, 2006 | Indesit 24 in. D61 Free-standing...
    Lakewood 7101 Oil Filled Radiator Heater Logo
    35 people viewed this question
    Top Lakewood Heating & Cooling Experts
    jay kaye
    jay kaye
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Mack Baxter
    Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
