Question about Panasonic KX-TG5671 Phone
Voicemail greeting - Panasonic KX-TG5671 Phone
How to record a new greeting
  1. Go to Google Voice.
  2. Click the gear icon at the top right of the Google Voice window and select Settings.
  3. Click the Voicemail & Text tab.
  4. In the 'Voicemail Greeting' section, click Record New Greeting.
  5. Enter the name for the greeting you're going to record and click Continue.
  6. A "Record Greeting" box will appear. Select one of your forwarding phones from the "Phone to ring" drop-down menu.
  7. Click Connect.
  8. Google Voice will call you on the forwarding phone you selected. Pick up the call and record your voicemail greeting when prompted.
  9. Once you've recorded your voicemail greeting, make sure it's selected in the 'Voicemail Greeting' section of your Settings.
  10. Click Save changes at the bottom of the page.
Mar 17, 2016 | Lands Phones
I need to change the greeting of Iphone 3. Where to go?
I'm assuming you mean the voicemail greeting message.
iPhone 3GS How to Change Your Voicemail Greeting GROK Knowledge Base
This article should help. Has step by step instructions on how to change your voicemail greeting on your iPhone 3.
How to Record Voicemail Greeting for Your iPhone
Here's another step by step guide.
Hope this helps!
Feb 02, 2016 | Apple iPhone 3G
How to change voicemail greeting on Mitel 5330
If you want to change your voicemail greeting, go into your voicemail and press 4 on the keypad. This is usually the number for personal options such as Voicemail greeting, name in the directory, and changing your voicemail password. If you need more specific instructions just let me know and I'll be happy to help.
Apr 16, 2014 | Mitel 5330 IP Phone
Voicemail change message
How To Change Your Personal Greeting:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
How To Record Your Alternate Greeting (Used when on vacation or out of the office.:1. Press the Check Voicemail key or press the Feature button, then 981
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the Choose softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting.
Nov 21, 2013 | Nortel T7316E 2-Line Corded Phone
How do I set up voice mail on an iphone
Adding Voicemail for the First Time
  1. Tap the "Phone" button on your iPhone.
  2. Select "Voicemail." The iPhone will prompt you to create a password for accessing your voicemail, then will allow you to record your first greeting.
  3. Click "Save" to set your recording to your voicemail greeting
Recording a New Greeting
  3. Choose "Greeting > Custom."
  4. Select "Record" and begin recording your voicemail greeting.
  5. Hit "Save" to set your recording to your new voicemail greeting
Dec 06, 2011 | Apple iPhone Smartphone
Can receive and answer calls but greeting announcement is silent.how do I turn on greeting.
Please tell me the model of your phone.However,you can do this with the use of your phone profile i.e from the phone click on it the screw down to the profile then click on it screw to setting or turn setting from there you will be able to get to greeting setting or turn from this step you will be able to activate the turn again .
Good luck.
Thanks for using fixya.
Sep 06, 2011 | Cell Phones
Trying to listen to voicemail grettings.
If your talking about listening to the individual mailbox greetings without calling into the system then you could use feature 980 (leave message)
enter in the mailbox number you want to check and press ok.
Jul 09, 2010 | NorStar M7310 Corded Phone
Setting up your voicemail
I bought and Uniden Dect 6.0 phone and the other day I had a voicemail msg but I can't retreive it how can I do that the book doesn't show how to set up for voicemail
Nov 15, 2009 | Lands Phones
Voicemail reset
Norstar Common Voicemail Features To Check Your Voicemail:
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
10. Press the ChOOSE softkey
took this from a guide i found, helped me out
Apr 30, 2008 | NorStar M7310 Corded Phone
Resetting company voicemail
4. Leave message
took this from a guide i have, might help you guys out
Jan 07, 2008 | NorStar M7310 Corded Phone
Panasonic KX-TG5671 Phone Logo
19 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
