Question about Kitchen Ranges
2008 kia low beam not working not blub - Kitchen Ranges
  • 31 Answers
The low beam can burn out and still leave the high beam working because we seldom use the high beam. I've seen new bulbs not be good bulbs too. Same goes with fuses. You can take a tester to the bulb plug to see if the is current to the bulb. It is much like checking the volts on your battery... Good luck!
Posted on Jan 12, 2014
04 Honda vtx1300c low beam not working blub looks fine
thats a motorcycle
check
that honda may have a high and low beam relay for the lights
may be an earth wire problem at the bulb holder
it could be the low beam toggle switch fault
if you handle the bulb glass ..finger prints can blow the bulb when powered up
Jan 13, 2017 | Honda Cars & Trucks
My high beams work and low beams dont had lights ckecked and they are good
Firstly start at main on/off switch then main beam/dip switch failing that have a look at the lighting relays..Good-luck.....
Jan 05, 2013 | 2002 GMC Envoy XL
2006 Hyundai Tycson GL Headlight Problems
Could be a defective headlight relay, Located in the fuse block in engine compartment,
Nov 29, 2012 | Cars & Trucks
Low Beam headlight not getting power? swiched blubs both worked on passanger side no so on driver side.
i had this same problem on passenger side low beam--trouble was wiring from headlamp back to underhood fuse box located at rear of battery.
Oct 26, 2011 | 2001 Buick Century
Have headlight problem 2002 chevy malibu v-6 on the dim side have electria current on both wires to the blub bright beams function normal
if you have power to both headlight plugs for each low and high beam filaments and the ground is good as you say the high beams function normally then you either have bad low beam bulb filaments,poor or dirty connection or you have a daytime running headlight relay on the car and that is the problem with the low beam lights.yes the high beams will work but not low beams if it is the relay.
Mar 04, 2011 | 2002 Chevrolet Malibu
Does a 1987 ford f150 have a low beam relay? neither of my low beams work and the bulbs look good
you can run a wire to head light from batt to check if blub is good , if good then dis connect batt and test wires for break, then switch.
Feb 03, 2011 | 1987 Ford F 150
Have High beams, but right low beam doesn't work
yes you are right it is the blub that need to be relace
Feb 01, 2009 | 1987 Toyota Camry
How can I change the headlight on a 2001 optima
You may have to take out the battery, there are 2 round gray colored covers that screw out located in front of your battery that correspond to the location of the head lights, one is for the high beam and the other is low beam. once the covers are off, unplug the wire that is attached to the blub, there is a retainer spring that holds the blub in, take each side and push down and out and the blub should come right out. be careful not to touch the new blub with your fingers, only touch the base.
Jan 04, 2009 | 2001 Kia Optima
Headlights, high beams
No as a rule they don't fail at the same time, in fact it is unusual for the hi beam to fail ever, the problem is most likely in the turn signal/multifunction switch, this does cause your problem, have seen it many times.
Oct 14, 2008 | 2003 Ford Mustang
Kitchen Ranges Logo
93 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
