Question about Refrigerators
My gfi plug in my garage keeps opening up. Nothing is plugged into any outlet connected to the common breaker. Replaced the gfi outlet with the same result.
  • 83 Answers
You are sure there is nothing plugged into the circuit anywhere? Have you checked outside the garage? You could be getting water into the plug outside, you could have a nick in the wire inside the wall. this could be caused by a staple pinching the wire. If you are able to follow the circuit wiring and go back to the beginning of the circuit and install the GFCI in the beginning plug outlet. Do not connect the rest of the circuit just the wire from the breaker to the first outlet. If it holds then your problem is between the first and last outlet. narrow down the are this way. You can also buy a cheap "dummy" tester that has 2 yellow and one red light on it. The tester will tell you what problem you may have.
Posted on Nov 09, 2013
4 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Everytime I plug in the power cord, it trips the breaker.
Refrigerators are not designed to run on a GFCI. Try a heavy duty extension cord to the fridge from a outlet that is not GFCI protected. If it still trips you probably have a short circuit in the compressor.
Posted on May 13, 2009
  • 103 Answers
SOURCE: GFI outlet is tripping because of refrigerator in the garage.
Hi: Yes, replace the GFI outlet. A refrigerator should not be plugged into one for what you are experiencing and food loss. This was an easy answer for me, but unfortunately not for you The owners manual covers this, but us men don't read them (Well I had to as I worked with them for 30 years). Good luck, Jeff
Posted on Jun 01, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Fridge keeps tripping the circuit breaker
Unless there is a dedicated circuit of 20 amps to the refrigerator this will continue to happen When your refrigerator goes into defrost and other things like lights fans air conditioners are on the same circuit it will have no choice to not trip the breaker. Try this turn the breaker off and how may thing in your house stop working? You need a 20 AMP circuit or this will possibly damage the compressor or weaken the breaker because it has tripped so many time. Thanks, Please rate my solution, I have done this work for 30 years. Thanks, Sea Breeze
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Posted on Aug 29, 2009
Home electrical
Hi Sammy,
It sounds like there is a direct short on the circuit. Before going any further, check other outlets on this circuit and make sure they do not have anything plugged in that is not expected and does not work. Check OUTSIDE your home, basement, garage, etc. as these locations require GFI protection - and may be fed from the bathroom outlet. After removing devices that are plugged into the circuit, attempt a reset of the breaker once more.
It is not likely that the circuit breaker has failed (but is a possibility). The outlet in the bathroom is probably a GFI type. You can determine this if it has "Test" and "Reset" buttons on it. You should be able to press the Reset button in fully even with power off. After resetting, you can attempt the resetting the circuit breaker as you have described above. If it stays on, try pressing the "Test" button on the outlet. Doing so should trip power to the outlet (and causing the "Reset" button to pop out) but leave the circuit breaker "On". If the breaker also trips, the GFI outlet is suspect and might need to be replaced.
At this point, a qualified electrician should be consulted to locate and clear the wiring fault.
Apr 24, 2013 | Hammering
Home fuse box breaker issue
Hi Rex,
It sounds as if the upstairs bathroom outlet and the outdoor outlet are on the same circuit. There's a very good chance that these are GFI or "ground fault interrupter" type outlets, as these locations (and others) have required this type of protection for over 30 years. It was a common practice to run a circuit from the panel to one of these locations (or another) and then run from here to the next outlet and then on to the next. Since the GFI outlet could be purchased for around $10 instead of $30 for a GFI breaker, electricians would install outlets instead - both offered the same protection. A "regular" breaker would supply power to this circuit - but the very first outlet would get a GFI type outlet. It would be wired to the LINE terminals and the cable that feeds the rest of the outlets on this circuit would be connected to the LOAD terminals. If there was a ground fault condition, this GFI outlet would trip, but the circuit breaker would remain on. You would locate and RESET the tripped GFI outlet to restore power. The only time the circuit breaker would trip is if the circuit was overloaded. Overloads would NOT cause the GFI outlet to trip.
Now that you understand how it was typically wired years ago (and still a lot of times today), you should check all the outlets outside your home, in bathrooms, basements, garages, and inside your home next to doorways that lead directly to grade of your lawn or deck. These are required places for GFI protection. Press the RESET on any tripped GFI outlet to restore power. If the outlet will not RESET, there is a condition where the hot wire (black, red or blue insulated wire) is in contact with ground, or a device or appliance connected to the circuit has a problem. Unplug anything connected to the circuit and attempt to RESET again. If still unable to reset, open the outdoor outlet again and carefully pull it out and away from the box. Inspected for damaged or crushed insulation and repair / tape as needed. Before reinstalling, try to reset again. If it holds, trip the GFI by pressing TEST button. The RESET button should pop out. Reinstall the outlet and make sure the wires are not crushed or cut. Press the RESET button again. If it trips, you will have to remove the outlet again and take more precautions against damage to the insulation. it is also possible that the GFI outlet itself has failed, in which case it should be replaced.
GFI circuit breakers and outlets are supposed to be tested monthly by simply pressing the TEST button and then the RESET button. Replace any GFI device that does not test correctly if wiring and devices / appliances connected are OK.
I hope this helps & good luck! Please rate my reply - thanks.
Jan 05, 2012 | Hammering
Refrigerator light was off this morning, when I plug it into the outlet, nothing happens and it shuts the outlet off
If its plugged into a GFI, plug it into a another circuit, GFI and motors do not get along. If its a breaker that is tripping, hard to guess what it could be.
Jul 01, 2011 | Refrigerators
My Whirlpool ciello only has a 2 prong plug. How do I ground the tub?
You can go to any metal part of the tub or electrical part (motor - valve - connection) and fasten a ground wire to that part using a nut and bolt or screw. I would suggest you use a screw that is already on the motor. Run the ground wire to a known good ground. The ground doesn't necessarily have to be the electrical outlet (a cold water piper, for example). There is that possibility that there is nothing metal that you will find exposed. That makes it a little tougher. If this tub came this way from the manufacturer (two prong plug), it is probably exempt from the grounding requirement. I would suspect that the manufacturer wants you to plug this device into a GFI. You can get a GFI at any store that sells electrical parts. A separate ground is NOT required for full protection when using a GFI. All consumer grade GFI (they look like a regular, rectangular outlet) come ready to accept a three prong plug and there will be a place to fasten your house wire ground to the device. As I said, the ground it not a requirement for correct and complete function of the device. If you don't have a GFI available where you are connecting the plug, change it or get a qualified electrician to change it for you. DO NOT, UNDER ANY CIRCUMSTANCES, PLUG THIS DEVICE INTO A STANDARD OUTLET . Use it only on a GFI protected circuit. The outlet you are considering may already be protected by a GFI breaker. You can only prove this by finding the breaker, turning it off and checking the outlet in question. If it is a GFI breaker, it will look different from the others - and have a test button on it. If you are unsure, replace it with a new GFI breaker. I suppose I should also say here that you should check with yout town building inspector as to the requirements before you proceed, so you will meet any local code requirements. If you live in North America, I am certain the GFI is a requirement for this installation, as the National Electrical Code requires it, (Canada and USA).
Thanks for your question here @ FixYa.com today.
Jan 06, 2011 | Whirlpool 5"x36" White Bathroom Drop-in ...
Will sometimes trip breaker when starting
Your compressor may not be unloading completely. Check for leak at intank check valve. Follow the airline from pump to tank. Remove the airline from he brass valve, with air in the tank spray soapy water to check for leak, replace as needed. If no leak the examing the pressure switch where 1/4 tubing connects. There you will find a small lever that opens a stem to unload air from airline. You can test the function by running the pump then switching off at the pressure switch, listen for release of air. If works ok then not enough power is reaching the compressor. Use very little or no cord and do not overload plug with other tools.
Nov 02, 2010 | Makita Mac5200 138a 3 Hp 5 Gal Wheeled Air...
Is a refrigerator usually plugged in to a GFI outlet that's connected to multiple other outlets? Is it mere poor practice or should it never be done?
A GFI outlet (Ground Fault Interrupt) is actually designed to provide extra protection from electrocution in wet areas where water can come into contact with a hot wire, and as long as the refrigerator is plugged directly into the GFI outlet and is not plugged into the GFI outlet by using any extension cord then there should not be any problem as long as the GFI outlet is not over-loaded with other appliances or large electrical demands. If the GFI outlet is tripping then either there is a faulty appliance or electrical device plugged into the GFI outlet or the GFI outlet is simply over-loaded with too much electrical demand, or the GFI breaker could be faulty. Plugging a refrigerator into a GFI outlet is not bad practice, however over-loading one is and that is what should never be done.
Oct 06, 2010 | Frigidaire Refrigerators
When i plug in my kenmore stovetop the other electrical outlets trip, i unplug it and reset the outlets and the outlet works but i can't use the stovetop unless i light the gas with a match now. what is my...
you, or your electrician has pulled power from one of the gfi outlets to power the electric sparker on the stovetop. If you can figure out which gfi that the power was pulled from, open up the box and find the wire that runs to the stove and remove it from the gfi outlet and connect it to the power before it goes to the gfi.
Dec 26, 2009 | Gb Electrical 1 30 Amp Ground Fault...
Jun 01, 2009 | Whirlpool ES5FHAXS Side by Side...
Like it has no power
hello, is it plugged into a gfi outlet ?in most newer kitchen with in the past 15 years most outlets are gfi in your kitchen,thay have a breaker build into the outlet that you can reset on the cover of the outlet also check your breaker on your main power breaker panel and try a different outlet to make sure the wiring for that outlet is'nt bad, also check the plug wires make sure there not loose if nothing then you'll have to take your blender apart to check the internal components.
Mar 31, 2009 | KitchenAid KP2671 Professional 6 Series...
Freezer GFI reset
no what rpobebly happened is that your freezer fillefd up with humidity and now its shorting out and tripping the breaker. make sure that theres no ice in the freezer also you should not really have it plugged intoi a gfi outlet.if its in the garage near the breaker panel i would add a dedicatefd outlet for the freezer from the electrical box.
Jul 01, 2008 | Frigidaire FRT15G4B Top Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
