Question about Saws
I have a Jonnesway JAG-6612 Air Angle Grinder that looks to be in good condition, but little power. What parts commonly fail in a grinder? Where can I get a manual? ( the Jonnesway website has no Tech. support section, and the Contact & INquiry pages are both broken and don't work) Who sells parts?
danny_murray
  • 55 Answers
SOURCE: ryobi angle grinder broken locking nut
You should be ablt to find it at anylowes or home depot.If for some reason thet do not have one I would call the local industrial distributor like grainger or msc
Posted on Dec 04, 2008
  • 61 Answers
SOURCE: dewalt dw474 grinder quit
you need new brushes. carbon is meant to be touching the armature not the contact from the spring. Its worn down
Posted on May 15, 2009
  • 42 Answers
SOURCE: dead DW400 angle grinder
Some of those double insulated power tools have a remote switch. By remote I mean that the piece you push, or pull does not actually have a switch on it, but has an arm or rod that could be several inches long, and that arm or rod actuates the switch.
If that 'arm' which is usually plastic breaks, the unit won't turn on (or in some cases off)
I have had a Dremel tool and a haircutting clippers that did exactly what you describel
Make sure it is not plugged in, then remove the phillips screws holding it together. Many times there is one hidden and you have to look for it.
Gently -- Gently separate the two pieces of the body. I like to do this over a white beach towel so that any pieces that might jump out at me won't go far and be easy to spot on a white background.
Look for an arm that reaches towards a switch --if it is broken it will be obvious.
I repair that kind of break with JB Weld. Don't get the quick dry JB, but the 'normal' product. Quick dry gives you almost no 'open' time.
Just mix a tiny dab of material from each tube together on something non-porous e.g. a piece of scrap ceramic tile, broken dish, glass, mirror and put a little of the mixture on each part of the broken area.
Put the two pieces together and let dry -- for 24 hours.
Re-assemble and you are home free!
I always have a plan for clamping or propping the repaired part so that it won't move BEFORE I mix the epoxy. That way I am not scampering around trying to find what I need whilst trying to hold it together.
Many times I use a tiny screwdriver and dip it into the mixture and apply it with the screwdriver. As long as you wipe the screwdriver clean with a paper towel it will be fine.
good luck.
Posted on May 18, 2009
brewerstool
  • 141 Answers
SOURCE: Carbon brush sizes
They are exactly the same brushes. Part number 316041640 .
Posted on Sep 15, 2009
  • 313 Answers
SOURCE: Makita Angle Grinder not working
check inside for any loose connections plus check the brushes. if like you say it is smoking it could be a trip to the wheelie bin for that one.
Posted on Jul 29, 2010
Replacement carbon brushes Ryobi AG402 angle grinder
You can purchase replacement carbon brushes on amazon Amazon com Ryobi carbon brushes. I hope this was helpful. cheers
Jul 12, 2013 | Saws
What is the part number for the makita cordless angle grinder spanner wrench
The Makita part you are looking for is:
782424-9, Lock Nut Wrench 28 for the BGA452
Sep 18, 2012 | Makita Bga452 Lxt 18v Liion Cordless Angle...
I have a dewalt dw818 angle grinder when i press the trigger it starts spinning but if i tilt the grinder a little it stops spinning done the brushes already help please
Check your power cord. Turn the grinder on, then pull and twist the power cord, especially by the boot coming out of the grinder. If there's a break in the line, it's possible for it to work in some positions but it will die if you change the orientation of the cord to the tool.
Jul 21, 2012 | Heavy Duty Dewalt Dw818 Heavyduty 412"...
I have a 7" angle
There are 3 versions of the 7" grinder model 4074. Sears Parts Direct has the manual for sale http://www.searspartsdirect.com/partsdirect/part-number/BLACK-DECKER-Parts/Grinder-Parts/741333-00/0009/900/Model-4074/1228/0721050?keySuffixId=NA&productTypeId=x&searchModelNumber=4074&subCompDesc=Unit%20parts&brandDesc=BLACK&DECKER&modelDesc=7 .
Black and Decker has pdf versions of the manuals for many of their products are here: http://www.blackanddecker.com/manuals.aspx . However, check the model number on the grinder. 4074 doesn't come up as a valid model. The usual model numbers start with alphabetic characters to indicate the type of tool. The site lists where to look for model numbers.
I hope this helps.
Apr 26, 2011 | Black & Decker Garden
My makita grinder was working just fine wile I was grinding it just quit on me and now it will not even start
You can try removing brush covers and brushes to check and clean as needed.I have a makita grinder and have to change brushes about every two years but I use mine a lot in very dusty conditions.I think that I would probably check on/off switch about first as I have had mine do exactly what you have and I replaced the switch and it's still working.I have had mine for 15 years.Great little grinders. If you feel comfortable doing so you can bypass swith to make sure motor is good. Best of luck and thank you.
Apr 17, 2011 | Makita Angle Grinder 4.5" 9524NBX
PWS 8-125 (european 800W 5"
Yep - probably dust build up - have you tried one of those cans of compressed air used for blowing stuff out of computers and stuff. They have a bit more blow than you and a small nozzle to get right it.
Mar 25, 2011 | Bosch 5" Small Angle Grinder
Can i change the brushes on my cordless grinder?
Hello u2okay, it is a little challenging but, Yes you can. I have done it myself some time ago. I no longer have the information available, but, I went to the manufacturers website and got a list of their authorized parts dealers. That was 8 or 9 months ago and she's still running strong. Well worth the effort. GREAT TOOL!
Good luck my friend!
Jan 16, 2011 | Makita Bga452 Lxt 18v Liion Cordless Angle...
Grinder runs about 2 minutes then shuts off. I replaced the heat sensor- no change. What else could be the problem?
check the condition of the brushes, make sure not sticking in the brush tube and also look at the commutator for a really dirty surface.
Dec 21, 2010 | Metabo 01451 We14 150 Quick Electronic 6...
Converting a LHD JAG S-type 2001 model to RHD
This question is under air conditioning repair. Mark the question as solved and move the question to another category
Jan 04, 2008 | Heating & Cooling
Saws Logo
80 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
