Question about shareme.com
FYTtek firmware A4 update 1.12 - shareme.com
On my double din stereo it shows **FYTtek firmware A4 update 1.12** Error... Do you guys know how to fix that? It asks to insert a SD card with this firmware.
Go to the manufacturer's site, download the firmware update and put it on an SD Card and plug it into the head unit, and it should upgrade/reinstall the firmware. It may take a while, so leave it alone until it tells you it has completed. It sounds to me like the process was at one time attempted and interrupted. Hence the error message.
Oct 18, 2013 | Cars & Trucks
Can not get my documents a4
Hi Charles,
There is a Firmware update available for HP Laserjet printer on HP website. Check the details about the Fixes it has on your printer. Download the Firmware and try to print, it should fix the issue.
HP Laserjet Firmware
And regarding the printer not accepting A4 Size document. I would recommend you to uninstall the software and reinstall it on your MAC.
Regards,
Suhail
May 16, 2012 | HP LaserJet 3050 All-In-One Printer
I can't get my printer to enlarge my copies
You need to update the firmware and then reinstall the print drivers then go to printer properties and edit the settings it will definitly work and deselect the A4 to the size you are looking
May 17, 2010 | HP PSC 1410 All-In-One InkJet Printer
Error c6020
Raggy2010 posted on this toppic Order the modified fuser plug connector. There is also a later firmware update to fix this code. This code happened to me on a few selected machines after I did firmware upgrades to add the interrupt button on the touch screen and to speed up the loading time. The thermistor is not guilty!
Feb 23, 2010 | Kyocera FS 1030D LASER 22PPM A4 PAR,USB...
What grade/brand of A4 paper will work in the printer? When I tried some "inkjet compatable" paper the machine does not recognise it.
Dear Sir/ Ma'am,
Any 80 GSM paper will working in the printer however I recommend you peform the following steps:
I kindly request that you do a Firmware update from the Kodak website and then proceed with the re-calibration of the unit . The link is as follows: www.kodak.com/go/drivers
Installation Instructions:
This firmware version improves the following:
a.. Error recovery
b.. Scanner performance
c.. Calibration for media detection
CAUTION: Turning your printer on or off during this procedure will render your printer inoperable. Wait for "Upgrade is complete. You may now use your printer." to appear on the computer screen.
1. Download the firmware file to your desktop.
2. Verify that your printer is:
a. Connected to your computer and turned on.
b. In the Ready state.
3. Double-click the *.exe file on your desktop, then follow the on-screen instructions.
4. Wait for "Upgrade is complete. You may now use your printer." to appear on the computer screen. This may take several minutes and the printer will turn off and on during the process.
It will require you to also recalibrate a media sensor in the printer after you perform the firmware update. To recalibrate the media sensor, you will need to do the following:
a) Load ONLY ONE sheet of Kodak Bright White Inkjet Paper, if not available please use another high quality inkjet paper. (A4)
b) Press the COPY & CANCEL buttons on the printer simultaneously.
c) The printer will feed the single sheet of paper through the printer.
d) The Media Sensor will be re-calibrated, however it will not give any indication that it was. There will be no message saying that it was successful.
Yours sincerely,
CViveiros,
Oct 19, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printing and picking the papers problem
HI there,
This issue occurs when the setting on the firmware of the machine does not match. Generally we use A4 / Plain paper, whereas the default setting on the firmware of the printer is Any size / Any type.
Hence if the printer is connected via USB, open the HP Toolbox and got to the paper handling section, set
Tray 1 = Any size / Any Type
Tray 2 = A4 / Plain
If the printer is connected via network, access the IP address of the printer and got to the settings tab > paper handling change the setting as shown above.
Let me know the next update.
Rgds,
Nikhil
Sep 10, 2009 | HP LaserJet 1320n Printer
Too long to copy
Try to do a firmware update (see brother homepage of your country). Anyway the scanner runs down the whole A4 size and sends the data to the printengine, which isnt the fastest one on the market.
Dec 26, 2007 | Brother DCP 115C All-In-One InkJet Printer
Can Scan A5 size duplex
The software on my X4500 unit allows duplex scanning of A5 paper. Updating the firmware and software is fairly easy if you need to.
Nov 20, 2007 | Lexmark X4500 MFP Flatbed Scanner
shareme.com Logo
345 people viewed this question
Top shareme.com Computers & Internet Experts
David Payne
David Payne
Are you a shareme.com Computer and Internet Expert? Answer questions, earn points and help others
