Question about Vacuums
Wertheim 4435 powerbrush reset button
The powerbrush has stopped working the motor has stopped but the lights on the brush are still on
reddevil6
  • 1673 Answers
SOURCE: premalite vac brush stopped turning
Not familiar with thi sbrand, but a reset is for when the brushes get jammed pr stalled, it will trip the reset. Make sure that the brsuh roll turns easily, also for a broken belt and/or bad brush roll. Some resets are for when the vac motor over heats, it will trip saving the motor. Usually this is for a jammed brush roll or a clog.
Posted on Apr 24, 2008
odiebugs
  • 949 Answers
SOURCE: Miele SEB-213 powerbrush stopped working
Pull the head cover off to check the belt, if the belt is ok then it might be the power connection between the handle and the power head shaft. If the red light is on the power head, then its not the connection
because its getting power. Now some heads have a reset button on them,you could check this also.
With the cover off the power head, remove the belt, now turn it on, and be careful, but try to make the motor shaft spin,with one finger, because if it does start to spin you do not want to hurt your finger.
If the motor starts to spin,put the belt back on, if it does not spin again, the motor is too weak.
If it does not spin at all, the motor is bad.Hope this helps you,and you get it working.
Posted on Mar 24, 2009
SOURCE: wertheim model 3280 brushes not
KippaRing shopping centre Vacuum shop undertook to repair the werthmodel - As a result
I no longer require your assistance. I appreciate your responses thank you - Geoff Franklin
Posted on May 05, 2009
SOURCE: powerbrush stopped working
My brush is working and the left side comes down more than the right as well. There is a piece or red plastic on the side that does not come down as much ?????
Posted on Aug 16, 2009
  • 26 Answers
SOURCE: The rotator brush stopped turning. it turns fine
The brush roll will only spin when your handle is not in the locked upright position, once the handle goes upright - the brushroll de-activates
Posted on Dec 23, 2009
Miele 228 power brush stopped working
Does the motor on the Head Run but the Brush does not turn... change the Belt, the brush head is operated by a rubber belt this is so it has no direct drive so if you suck up something then you ruin a belt and not the motor. Besides you should change the belt as per MFG directions. I change ours at Least 2 times a year and if you do.. say Pull in a Rug corner and it smells like Burnt Rubber? ... you just decreased your life of the Belt.... you'd be surprised on how well a New Belt helps your Vac pick up things. Change the bag often too, do not wait till it can pickup no more. The bag is Not meant to be FULL to be changed, besides it keeps Mites in the trash where they belong and not a breading ground in your closet... If you have a bag-less clean and rinse (All Filters Every Vac has a Filter even the Bag-Less ones) and let dry after a day of vacuuming follow MFG directions, Hope this helps.
Jul 22, 2014 | Miele SEB 228 Powerbrush
I have a bosch bagless jet 12 amps/1450 W which I got secondhand. the switch to operate the powerhead (the rug brush) no longer gives me any results. I don't have the right tools to unscrew the plates and...
quite likely it has no actual motor .many of these newer machines use an AIR MOTOR that when the suction is great enough it spins the brush quite well . dog hai and human hair wraps around the ends of the brush shaft and eventually get tight enough to stop the brush totally .
Dec 05, 2017 | Bosch Vacuums
Powerbrush stopped working
Aug 13, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
I have a Bissell Pro Heat 2X carpet cleaner and the brushes spin, then stop. I turn it off and when I re-start, the brushes do not spin until I push foreward. The it spins and stops again. Both belts are...
The reason for the brushes to stop when it is above any surface is there is a switch in the handle that stops the brushes so it dont burn your motor up it may have a faulty switch.
Jul 14, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Reset Button on my Dyson DC 25 Animal
What do you want to reset? Do you mean the motor has stopped working? There is no "reset button". The motor has an automatic cut-out, which will operate if the motor gets too hot and will reset itself when it cools. If the motor will not work when it's cool, then you have an electrical problem which will probably need professional attention.
Apr 09, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Mar 24, 2009 | Miele SEB 213-2 Vacuum
How to open the case of a wertheim b20 vacuum cleaner
Take out all the obvious screws around the base and coloured top using the appropiate driver.   There is one screw under the flap used to hold the dust filter in place.   The flap is spring loaded and can only be removed (as I see it) once the top is taken from the base.   To remove the screw I used a pair of long nose pliers and some patience.   Once the top is clear of the base, other screws can be easily seen and removed.
My problem was a badly worn bearing at the commutator end of the motor.   There was so much movement that the brushes would not follow the commutator with a result of excessive noise and sparking.   The brushes had dug into the commutator segments and chipped etc.
The bearing is permanently pressed into the motor end and cannot be replaced.   This means a new motor which, in my part of the world, was quoted as $250.00.    My neighbour will be purchasing a new vacuum cleaner but after 15 years with the old one he hasn't done too badly!
Mar 24, 2009 | Vacuums
Wertheim vaccum 3180
most vacuums use a belt that runs from the motor to the front brush. and when the brush gets jammed the motor continues to run and burns the belt (probably what you smelled).
you'll have to turn it over and remove the base plate and replace the belt.
use the old belt to find a match
hope this helps.....jay
Mar 21, 2009 | Vacuums
Premalite vac brush stopped turning
Apr 23, 2008 | LG Electronics Premalite Vacuum Bagless...
Vacuums Logo
43 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
