Question about Whirlpool Washing Machines
My new Whirlpool Cabrio Washer is very loud. Repair person said as it is used belts will loosen up and loudness will go down. This has not happened. For this machine is Loudness normal. Purchased 9/3/13 at Lowes,
  • Official Brand Answer
  • 345 Answers
Hi, there. While we cannot assist with repairs I can offer links to our troubleshooting, use and care guides, replacment parts, parts lists, and service line should that be necessary. We hope this helps.
http://bit.ly/zkfnZd
http://bit.ly/112Lu7q
http://bit.ly/LrNZiS
http://bit.ly/yLv4Z5
Posted on Oct 20, 2013
4 Suggested Answers
  • 641 Answers
SOURCE: Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Posted on Jun 29, 2006
It sounds like the bearings are going bad. Try spinning the drum with your hand while it is empty. It should spin nice and smooth. If the rotation feels a little rough and noisy, you might have a problem. You can double check by taking the drive belt off and try shaking the pulley. If there is "play" when shaking the pulley, the bearings are most likely toast. The inner stainless drum rides on two bearings which sit in the rear of the outer plastic drum. The whole plastic drum and bearings come as one piece and go for $150. It would cost about the price of a new maching to have someone come out and repair it for you. It sounds like kenmore has had a bearing problem which is pretty rediculous considering how much these things cost. Sears said, "those tend to go in a few years", which is criminal especially since the warrenty is usually conveniently exopired by the time this problem happens. If you are handy, have a spare day, and can remember how to put a washing machine back together, go for it. I did it and it was not a fun time. There is a lot of sharp metal edges in the machine so wear gloves. good luck
Posted on Nov 14, 2006
  • 35 Answers
SOURCE: Knocking noise during agitation cycle - GE WNSR2100T8WW
I believe you must have one of the bottom of the line cheapo washers, as I do--the one with the plastic, rather than steel wash tub and basket? These are pretty poor machines. They cut corners drastically in every part of the design. I've replaced the aluminum hub that supports the spin basket ( the hub is bare aluminum and corrodes within about 5 years use from the highly alkaline detergent, then it fractures under mechanical stress. Then the motor burned out. I was able to get a nearly new motor on ebay for $90 incl. shipping. (BTW, if you need appliance parts try GOOD Appliance on ebay for new and salvaged parts--they're excellent! 100% feedback rating) However, I now have the same problem--a fairly loud knocking noise during the agitation phases of the cycle. This is cause by a really crappy transmission design that does not wear well. My advice is just ignore it as long as it works and isn't leaking oil and the tub seal is still good. If it does finally go to pieces get one on ebay--that is if you feel up to doing the job yourself since a repair person would charge more than it's worth to install it. I believe new ones can be had on ebay for about $80, some are sold with seal kits. Bottom line is--if you want a machine that will last you for 15-20 years--don't buy a cheapo model. The front loaders are better as they use far less hot water (energy and water savings) but a good one is going to be anywhere from about $800 to $1600.
Posted on Sep 17, 2009
Cabrio washer wtw5500xw0 loud spin and grease on floor
FIXED Cabrio has loud noise during spin - ApplianceBlog
www.applianceblog.com/.../16339-Cabrio-has-loud-noise-during-spin
Aug 21, 2009 - 10 posts - ‎5 authors
Help Jake I have a Whirlpool Cabrio model WTW6600SW2 it is almost 2 ... a week just started making a very loud noise only during spin sounds like ... size washer (110.297) (loud whirring and grease splatter) and am trying to ...
How to tell if your bearings are bad on a Whirlpool Cabrio ...
? 1:01
https://www.youtube.com/watch?v=5rHn13lKjzc
Jan 19, 2012 - Uploaded by RenewAppliance
http://washerdryerrepairhelp.com/whirlpool-cabrio-maytag-bravo-and-kenmore-oasis- ... My floor under the washer machine hasgrease/oil marks. ... and make the suspension bad when it spinsmine has been like this for about 2 months now ... Noisy WhirlpoolCabrio washer during spin - Duration: 0:54.
Jan 16, 2016 | Washing Machines
Tighten belt on duet whirlpool front loading washer
There is no adjustment for the belt of WP front load. If you hear loud noise when the drum is spinning because the drum bearing was loosen. If you have insurance cover tell them to replace. Else, a cost of repair is expensive.
Oct 20, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool cabrio loud noise
Check your bearings. This post will show you most of what you need to know about your bearings:
http://www.squidoo.com/how-to-replace-bearings-in-a-whirlpool-cabrio-maytag-bravo-or-kenmore-oasis
Nov 06, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio makes excessive noise during spin cycle
Your model has a bearing under the tub which is probably going bad and needs to be replaced. cabrio washer bearing replacement YouTube
Oct 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool cabrio washer makes a loud noise when it spins
The bearing is probably going bad, spin it with your hand if it makes noise or you feel a vibration its bad Parts for Whirlpool WTW6600SW2 Motor Basket and Tub Parts
May 27, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a whirlpool cabrio washer WTW6600SW2. The washer makes loud thumping noise during spin cycle and then uL code flashes and it stops until you open the door. After moving the clothes around and...
ON SOME CAPBRIO IF YOU HAVE SOME LIME ONTHE WATHER THE TUB IS A FREE FLODING AND WILL GET STUCK ON THE UP POSICHONAND WOND GO INTO SPIN. TRY TO RUN A CLEANER YOU CAN VUY AT ANY BIG WALL MART. IF NOT TRY TO LIFT TUB AND PUT BACK DOWN . IT SHOOD BE VERY EASY TO PULL UP IF NAT YOU BEST BET ID TU BUY A NEW WASHER. PARTS ARE PRICY.
Jun 30, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I hate my Whirlpool Cabrio washer- I've had it for almost 4 yrs- digital display board broke at 2 1/2 years and cost $450 to repair. Now I have leak under the washer who knows how much it will be to...
I also hate hate hate my Cabrio washer and dryer. I've been a loyal whirlpool customer for over 25 years with ALL my household big appliances. ThWhirlpool doesn't care about loyalty. I bought this washer and dryer set in Sept. 2010. The clothes don't get clean....the darks have white streaks on them. I have to re-wash about every other load. I washed a pair of jeans and they still had dirt on them when I pulled them out. I called Whirlpool and their response was "What do you want me to do about it?" They said they can't do anything bc the washer is an energy saver.. I will NEVER buy another Whirlpool appliance.
Sep 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My Whirlpool Cabrio WTW6200SW1; spin cycle loud roar
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 07, 2010 | Washing Machines
Whirlpool cabrio-buzzing noise when water runs
i think the problem that you have is one of the electric coils from the entrance valve from water. Check if there the vibration comes from there.
Oct 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
