Curtis dvd5029 home theater system only plays right front and center speaker
I have all the connections done correctly and I can only get sound from the left front and center speakers. I can get each speaker to work individually by moving the rca cable to the connection on the back of the dvd player that corresponds with the two speakers that are working, so I know the speakers all work. I am assuming that it is in the setup on the dvd player, but I am not sure.
  • Anonymous Mar 13, 2014
    wanted to know why the back speakers and the center not working i check all speakers are ok
  • 93 Answers
Some DVD players in SETUP MENU need to select AUDIO OUTPUT (i.e. STEREO 2 ch - SURR 5.1 - SUB ON/OFF etc.). Check this for start.
Posted on Oct 04, 2007
SOURCE:
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
Dec 12, 2015 | Audio Players & Recorders
Xbox360 not hooking up to Curtis DVD5091 surround sound through optical cable
try running the optical cable from your dvd directly to your tv and then select whichever input (eg HDMI 1/2 etc) you use to play the xbox on..In theory this setup should allow any audio playing on the tv to go through the surround sound..hope it works
Feb 11, 2013 | Curtis DVD5091 Theater System
Rear speakers are not working
So if you bought a Curtis Home Theater System Model DVD6091 and you can only hear the 2 front speakers working? Insert another DVD that's labeled 5.1 Dolby Surround and choose that 5.1 Dolby option in the menu before calling their tech support
May 30, 2011 | Curtis DVD6091 Theater System
Show me how to set up my curtis 5091 to my dvd and tv
The speakers should not be a problem. All the sockets are labeled left / center / right / left surround / right surround and subwoofer.
Connect the yellow composite video out to the TV's yellow composite video in . Along with video out of the Curtis you can connect two red and white audio out to the TV's audio in socket.
Mar 15, 2011 | Curtis DVD5091 Theater System
My home theatre was connected successfully playing the cd movie, but after turning off the dvd and go back to watching tv the sorroung system speakers do not give a sound to the television. is it that i...
hi,
select tv input on ur theater system. u can hear audio fro the frond left and right speakers. if u want to hear the audio from the surround speakers, then press the A-MODE button on ur remote to select different type of sound modes. press again and again to select different sound field. select one which suits u.
ok
Dec 27, 2010 | Curtis DVD5091 Theater System
So i just bought the coby dvd938 and i hooked it all up and all the colors are correct and the pocitives and negatives are correct but the only the front 2 speakers and the subwoofer work but i cant get...
Yeah I'm having a similar issue. Front speakers and center speaker working fine but rear speakers are very quiet and the subwoofer isn't working at all. Everything is connected correctly as well if you figure something out let me know.
Dec 06, 2010 | Coby DVD938 Theater System
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
Cracking popping type sound coming from front and center speaker
if u are trying to connect the audio of ur tv as input to flow out from the home theater; this is a common thing; u need to replace the audio cable that connects the tv to 3565 with a good quality cable
Apr 01, 2009 | Philips HTS-3565 Theater System
No voice sound through speaker with DVD system, only music?
first check the settings on the audio menu of the dvd player. make sur it is set to 5.1 (if available) otherwise set it to stereo and your system should decode it.
assuming the second step is okay : as other dvd you play seem to work) it still may be that your unit is decoding stereo inputs just fine and 5.1 is not working properly....
so if adjusting audio settings in dvd play back menu dont work,
check that the cables to the satellite speakers are connected correctly and all plugged in soundly ( voice is high frequency,- coming from satellites - the garbled noises you hear are the base ( low freq) elements of voice which are coming from the bass box ( that the X.1 part of 5.1) and so that is obviously working. ,
Mar 08, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
558 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
