Question about Denon DRA-697CI
PS3 Audio and Display Issues
Neither the screen and the sound on my PS3 is working.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 15 Answers
Check the HDMI cable type- try multiple cables.
Posted on Oct 24, 2013
I have a goodmans TV is having issues, sky box works fine through the hdmi but, ps3 no display or sound through the same port, my ps4 gets pic but no sound, both consoles have been tested on other tvs
1.Put your PS3 on standby.
2. Unplug the power lead.
3. Connect HDMI cable to HDMI out on PS3 and HDMI in on TV
4. Connect PS3 so that the red standby light is showing
5. Hold down the On/Off button until you hear a second beep. The PS3 will try and detect the display output settings on your monitor.
Dec 02, 2015 | PS4 Video Game Consoles & Games
My ps3 says the mode is not supported. you can only hear the audio
This sounds like a problem with the resolution on your TV. Which means that the PS3 is trying to display a resolution that your TV does not support. Try resetting the PS3 display settings by following the instructions on this link. Once done go through the display and sound setup in the PS3. The PS3 will detect what kind of TV you have and find the maximum resolution it can handle.
http://www.portfolioofpb.com/blog/ps3-blank-screen-switch-inputs-hdmi-to-composite-to-hdmi
Nov 25, 2010 | Sony Playstation 3 (PS3) Console
No sound going to tv from console
If the audio function is not working properly on your PS3, there are several steps you can take to properly fix these problems quickly at home without sending it out to Sony and paying over $100 for repairs. Here are some simple troubleshooting steps to help you identify what may be causing your PS3 audio problems and fix them.
1) If you have no sound at all, you should check and make sure that the mute button has not been pressed on the television remote. This may sound like an obvious thing to check, but you would be surprised how often this is the cause of no sound issues with the PS3.
2) Next, make sure all your audio cables are properly connected between the TV and the PS3. A simple loose cable can cause sound issues as well.
3) Check the audio settings for your Playstation 3 and make sure they are properly set and also set correctly for the type of television you are using (HDTV versus standard).
4) Check and make sure the disc you are using is not copy protected or otherwise unsuitable for use in your PS3. Try another disc if you are unsure.
5) Make sure that you are using the correct cables to connect your TV to your Playstation 3. If you have recently changed the cables you are using, this can often be the source of the problem.
If none of these five steps work, you may still be able to fix your PS3 at home with the help of a good PS3 home repair guide
Aug 20, 2010 | Sony Playstation 3 (PS3) Console
I am having connection issues with an LG 55lh40 television, a HD DVR from Directv, a PS3 and a DVD/VCR combo. The TV seems to be working good, but does not seem to be picking up an HDMI cable of any kind....
No picture
when connecting HDMI:
Check HDMI cable over version 1.3.
The HDMI cables don’t support HDMI version 1.3, it cause flickers or no screen
display. In this case use the latest cables that support HDMI version 1.3.
Feb 14, 2010 | Televison & Video
No picture or sound
Your display needs to be reset, Turn the ps3 off. Then turn the ps3 back on but continue to press the power button until you hear the beeps then it should work fine :)
Aug 05, 2009 | Sony Playstation 3 (PS3) Console
MX 3950D Philips - PS3 no sound
Aside from the xbox360 working via the coaxial digital cable. I got the PS3 to work this way.
I had to use the supplied SCART > (Y-video) (Red-Audio) (White-Audio) cable. Basically plugged this in from the PS3 directly to the MX 3950D Aux (Auxiliary) audio input.
On the PS3 audio settings menu, switched from HDMI to the 3rd option SCART.
Turn on the MX 3950D and set to Aux. Bang, got sound again.
I missed this cause I "assumed" the video/audio cable that came with the PS3 was a HDMI to Audio/Video cable, and didn't even see the SCART port in the back of the PS3. So I thought I didn't want to lose 1080p ..etc etc. Anyways. MX 3950D still good =)
May 18, 2009 | Philips MX3950 System
Toshiba 32AV500U HDMI issues
The Toshiba 32AV500U cannot display 1080p. Hook up your PS3 to your computer monitor, provided that it can display 1080p, or some other TV that can, then change your Video Output settings under Settings> Display Settings and uncheck 1080p, which will allow the PS3 to display in 1080i. Once you do that, then hook up the Toshiba via HDMI and it will work with no problem.
Jul 23, 2008 | Televison & Video
During DVD movie playback, screen goes black periodically
it could be that the disc is and ordinary dvd disc and cannot stand the capability with a high def tv because i have the same problem and when 1 put a bluray disc in its fine
Mar 10, 2008 | Sony Playstation 3 (PS3) Console
Audio Issues
Check your "Audio settings" in your PS3,you can make changes.I noticed in mine that it pick it up once I connected it,but then I had to go to the settings and set it up.
Jan 07, 2008 | Sony Playstation 3 (PS3) Console
Audio problem when connecting to a PS3
It seems the Denon and PS3 don't play nice together on DTS. If you take off the DTS setting, then the PS3 will use DD and you'll get surround for games and movies.
Nov 04, 2007 | Denon AVR-1803 Receiver
Denon DRA-697CI Logo
20 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
