Question about Dryers
Have ge dryer DPXH46EAZWW drum is turning although loudly is not venting venting system clear pulled off top coil in back is red hot like burner on stove on high what is causing this
    Scholar:
  • 57 Answers
Can you verify the model number because I can't find anything matching what you sent. How old is the dryer?
Posted on Oct 19, 2013
Testimonial: "model DPXH46EA2WW"
3 Suggested Answers
reg501
  • 413 Answers
SOURCE: Dryer stays hot hours after using it
The heater has failed and/or is shorting to the case. Remove the rear panel. The heater is on the right side, attached to the heater housing with two screws.
Posted on Jun 26, 2008
SOURCE: GE 5 Cycle Automatic Heavy Duty Extra Large
Dryers not getting hot at all.
Posted on Nov 30, 2010
Dryer runs, can see burner is firing but heat setting seems stuck on ;Delicate cycle. Taking 3 hours to dry a load of towels.
gas coil condensors may not be working properly as they set the gas pressure needed to keep flame going hot. can check them with a multi meter however if flames stays on you may want to check the venting system first u might be surprised bad venting can slow down drying. check in machine and at exhaust to home. Again Each time you see the glow bar igniter come on it should ignite the gas burner. If you find the glow bar igniter glowing red for a short time and then fading off without any burner ignition would indicate weak solenoid coils. The coils are mounted on top of the gas valve and they both will need to be removed and replaced. In order to access the solenoid coils will require removing the lint filter, removing the two screws which was hidden by the lint filter and raising the top and removing the front panel.
Jan 28, 2015 | Dryers
Dbsr463eg7ww no heat
First check to see that the exhaust venting line is clear (not full of lint) as well as the path in the dryer to the line. This is the most common cause of no heat.
Second set the knob to heat turn on dryer with the lights off and the door open but the "open door" switch so that it still rotates with the door open. Look at the back of the rotating drum for a orange/red glow behind the drum (the heater coils). If there is no glow the heater coils are probably broken.
As the dryers age, the amount of thermal cycles the heater elements go through until the point when the coil wire breaks. There usually two heater coils behind the rotating drum (one hotter than the other and when combined the hottest heat temperature setting. You will need to pop open the top where you see the belt that turns the drum. The belt is removed from the spring loaded tensioner pulley at the base of the dryer. Then you can lift the drum out to get to the heater coils. Since no heat, both should be broken and will require replacement.
Nov 05, 2013 | GE DWSR463EG Electric Dryer
Dcvh660ghbb dryer wont heat
Sep 05, 2013 | GE Dryers
No high heat in dryer
This type of dryer has 2 rows of elements. If one is out then you will not have high heat.
Basically to get into ge dryers your start by popping the top then removing the front. Then the drum comes out.
Dec 05, 2012 | GE Dryers
Dryer does not heat
Might be a limit or a the heater element.MY REPAIR PAGE
Aug 15, 2012 | GE Dryers
Dryer blowing cold air . No heat!
Check the "Bias thermostat" for continuity with a multimeter. IF it is bad, replace with this part.
Nov 29, 2010 | GE DBXR463EDWW Electric Dryer
How to replace ge dryer heating element
you will need to remove the drum for this one.  once it is out, the element is mounted on the back of the unit.  not a hard repair, just lay out the parts as you take it apart to give you some order as you re-assemble it.
Aug 03, 2010 | GE Profile Wizard DPSE592EAWW Electric...
Dryer does not get hot
There are a number of things that can go wrong on an electric dryer that will make it not heat...
Check out this tip that I wrote about that problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Mar 31, 2010 | GE DBSR453EBWW Electric Dryer
Dryer vibrates with exhaust hose attached
Doubt this has anything to do with the drum replacement. Your model has an independent variable speed blower motor (not linked to the motor which turns the drum) and speeds up when it senses a vent restriction. You may have a problem with the vent motor or blower wheel, or just a vent restriction issue.
May 21, 2009 | GE Profile Harmony DPGT750EC Electric...
Kenmore dryer, electric
forget temp ck..first ck air flow at rear of dryer be sure strong air flow present if not remove back ..remove 4 screws holding blower housing to inside wall remove the 2 screws under lint screen on top ..clean blower housing if housing clear ck vent line all the way to end outside for restrictions ..reinstall line to dryer be sure not to crimp or flatten hose when pushing dryer back to wall ...quick ck dry a load with rear vent hose disconnected if cks ok definite vent restriction
Dec 05, 2008 | Kenmore Dryers
Dryers Logo
Top Dryers Experts
