Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
Kohler ignition module test - Kohler CH25 PA-CH730-0040 Command Gasoline Engine
Changed everything for tune up still no spark
What make , model an year vehicle ? Is it coil on plug ignition system or dis ignition . Did you test for battery voltage at the coil or coils ? Is the powertrain control module controlling the coils ? Does it have a ignition control module ? Automotive Engine Ignition Coil Testing Repair How to test an ignition coil and ignition module with test light
Mar 17, 2015 | Cars & Trucks
Is the small wire on the ignition module to ground out the ignition to stop the engine?
Yes most times except on systems with points. It be ungrounded except when you the ignition system killed.
Dec 20, 2014 | Kohler Engines Command V-Twin Horizontal...
At beginning of season I replaced the ignition modgel on my cubcadet 2 c ylinder kohler due to it shutting down when hot worked fine all summer but at end of season shut down and have no spark should
First off, do not use a standard spark plug tester, Kohler uses a special one. Don't try and short the plug wire on the engine, doing either one of these tests will burn out the ign. mod. Make sure you use the plug that Kohler requires.
Dec 20, 2014 | Garden
My welding machine will not idol down. Only stays in high idol . Why won't my machine idol back down when not welding? Yes I have the switch on run /idol lol 225 bobcat miller Kohler engine
put 12 volts to the coil and see if it pulls in. Could be coil, idle module, ignition switch, or wiring. Get a 12v test light and trace it.
Dec 15, 2014 | Welding Tools
How to test engine coil on 19 hp kohler engine
Get yourself a test spark plug for small engines
There is a small engine one & one for car with HEI
Ignition
Looks like a spark plug with an alligator clip on it
Look on the internet for one similar to KD 2757
Has to be for small engine & std ignition-- not electronic
ignition systems
Oct 11, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I have a kohler model cv16s in a lawn tractor, sears model 944.608961. The problem is that the ignition is intermittent. I have replaced the spark plug and turned the engine over, plug out, it may spark...
weak spark could be a ground problem or it could be module itself check the wires that go to the module for nicks or cuts if none exist I would lean more toward the ignition module
Oct 19, 2012 | Garden
I have a 1 year old kohler command pro ch740s. i pulled plug wire off one side and cant get any spark. i pulled other side off and motor dies. can you tell me what would cause one side not to get any spark
hi there, pauly46 here
from your model type ch730 25 hp 0040 it seems that
this model does not need or use a smart spark ignition module
please check that you dont have a kill wire from your coil groundin somewhere between kill tab on your coil and the ignition switch
then if you still have no spark replace the ignition module
that has no spark - your engine has been running one 1 cyl
as soon you pulled the h t lead off the firing cyl the engine died
that tells you no fire on other side
i am sure these units do not use any diodes fitted between l/h and r/h kill wire tabs leading back to ignition switch , i think these are mainly on briggs vee twin
here is web site for service manual
http://www.kohlerplus.com/main_frame.asp
enter as guest on the site
go to command pro twin
go to service manual section
select SM-24-690-07 ( replaces tp-2450c) from the list
download a copy and print
cheers hope it helps
pauly46
May 01, 2011 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler small engine problem
1989 Kohler 20 backfires through the exhaust. What are the possible causes?
Jun 02, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
46 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
Wayne McNeil
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
