Question about Gateway EV 910 19" CRT Monitor
Ev910 monitor. How do you increase the brightness. I go to the flywheel and select brightness and then the fly wheel just goes away and my picture is still too dark.
    Champion:
  • 220 Answers
You may not be saving the settings.
Samir
Posted on Oct 21, 2013
2 Suggested Answers
  • 36 Answers
SOURCE: Gateway monitor FPD2275W TFT LCD powers on,
The back lamps that provide the illumination of the
colors, is shutting down there are feedback circuits when there is a problem
with the lamps it will shut down the lamps. Replacing the lamps should alleviate
this problem. For more information on this email me at Sprint6@zoominternet.net
Posted on Mar 23, 2011
Why does video blink on and off?
Video off may be sparking current of fly back or high tension voltage (Anode in 22400V) also need to check Ground cables from CRT Tube .
Need to check chaining resolution and H sync /V sync to low 60Hz
by display properties /Resolution section.
Reduce/increase brightness and contrast to check screen resizing when display bright white -there may be a fly back problem.
Also need to dry sold to remove burned lead joints of circuit board and nec board.
Feb 25, 2016 | Samsung Computers & Internet
Should the coil and flywheel touch?
Wouldn't have thought so as the fly wheel spins it will wear away anything that it touches. You will need to adjust the position of the coil away from fly wheel.
Oct 29, 2015 | Garden
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
I am tring to fix my fly wheel I think it's the fly wheel any ways I think there is a bolt loss where is the dam thing on this and anyways i just need a web site to be able to find it and how to take it...
Perhaps we are thinking of something completely different to each other. The flywheel sits slap bang between the engine and the gearbox and either, usually the gearbox, has to be removed to gain access to the flywheel. Here is a picture of what goes up to make up the flywheel and clutch assemblies, the flywheel is the part on the left and is bolted to the crankshaft through the six holes near the middle. Come back to me if you need anymore clarification.
images?q=tbn:and9gcsrvbgx14s0yhqqthg-bzqlsoqml2ols1fwh1yqkzcjco_gofjgy7v7qyu0
Apr 14, 2011 | 2001 Ford Focus
My b/f has a 1990 Fleetwood Cadillac...He believes the fly wheel may be broken...Where is the fly wheel and are they easy to replace?
Flywheel is between the motor and transmission the starter actually runs the flywheel to start the motor. To change it you will have to pull the transmission away from the motor to get to the bolts that hold it to the motor. Not the easiest thing to replace by any means.
Jan 05, 2011 | 1990 Cadillac Fleetwood
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
Negative effect on Bright areas of Monitor/TV
Try demagitizing the moniter. In the monitor's menu it will have a picture of a magnic , select it. Sometimes it is listed as degrous. After selecting this, your screen will seem to spin then settle. If your still have problems, a magnic may have come close to the moniter while it was being stored, and that will ruin the picture.
Sep 21, 2009 | Computers & Internet
The brightness adjustment bar appears on the screen all the time
Press the menu button on monitor select the brightness press the menuside button increases or decreases.after select exit oress the exit button on monitor.
Jul 13, 2009 | Compaq CV 7500 17" CRT Monitor
Low brightness
I did not understand the term 'normal', but you can try increasing the screen from the FBT Potentiometer knob.
May 02, 2007 | SAMTRON 55V 15" CRT Monitor
Gateway EV 910 19" CRT Monitor Logo
43 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
